Trigger on offline, or disable offline disabling
I'd like to be able to have a notifier trigger when a local network interface goes down, but Simon helpfully notices that it's offline and disables notifications. :/
Any way to disable the disabling?
Re: Trigger on offline, or disable offline disabling
Not at present, no. Generally people wouldn't want that, as it'd result in false failures. I'll make a note of the suggestion to make that a preference, though, and consider it for future releases.
Simon 2.3 adds the ability to disable the offline check.
