Dejal
math problem problem
I posted a reply here earlier today as a guest, and was confronted with an anti-spam "math problem". There was a banner announcing that my answer was incorrect (it wasn't), but my reply was posted anyway. (I didn't try it with an actually incorrect answer.)
Re: math problem problem
As I recall, the third-party Captcha module I use has a bug where it gives a spurious error before you even answer the question, but otherwise works fine. I'm hoping for an update to fix it sometime.
It only affects guest site visitors, and is just a cosmetic issue.
