I'd like to be able to edit certain Test variables simultaneously. For example, I would like to set the automatically pause option on all my tests. I'd rather not have to manually go through every single one manually.
Thanks.
Re: Batch edit on Tests
Yes, that is a feature that I plan to add in a future version - maybe version 3.0, or one soon after that.
Thanks for your support of this feature.
