I have a couple of machines checking each other (with Simon). When I need to install OS updates, etc. I have to use Apple Remote Desktop (or screen sharing or VNC) and go to each machine to pause all of the mutual tests using Simon's GUI.
I might be missing something obvious, but is there a way to remotely control Simon from the command line? It would be great to be able to run a shell script (for example) that used ssh to pause tests on a remote machine. I don't see Applescript support in Simon or anything else obvious to me.
Thanks in advance for any ideas.
--greg
Re: remote command-line control of Simon?
No, that isn't possible at present. But it's certainly something I'm keen to add in the future.
Using a command-line tool is probably the best way to do this, but I have a few other ideas, including AppleScript, Jabber (chat with Simon), and other options. I might add more than one over time.
