Simon Standard is in TheMacBundles: 12 great apps for only $49.95. Click here!
Simon and other Dejal apps are also included in TheMacBundles' innovative new BYOB (Build Your Own Bundle).
Simon Standard is also in VoteBundle: 20 apps started; 40,000 users cast 200,000 votes; 10 remain, for only $39.00. Click here!
Dejal now has a Facebook page; please Like it:
auto pause question and bug
David,
When setting up auto-pause on tests, what is the proper way to pause a test for a whole day? 00:00:00 to 23:59:59 ? or does 00:00:00 to 00:00:00 work? Maybe if 24 is entered as the hour, set it to 23:59:59?
Also there seems to be a small GUI bug here. It's possible to tab between hour, minute, second but not from the "from" input to the "to" input box.
If I set a test to pause from 00:00:00 to 0:07:00, will the test immediately run at 7am?
Also,
When duplicating tests, auto pause settings are not duplicated.
Re: auto pause question and bug
Yes, 00:00:00 to 23:59:59 would do. I plan to enhance the pause options in the future -- I'm currently thinking of merging the frequency fields and pause options into unified schedule options.
I know about the tabbing issue, and again will fix that in the future. In the meantime, just click on the desired fields.
The pause interval just says when not to check; the timer will keep on running regardless, so it'll just skip checks that fall within the pause interval. Therefore the next check after a pause interval will likely be a little after 7 AM.
