{TestLastChangeTime} always sends "19:00:00"
For some reason, the {TestLastChangeTime} notifier variable is always sending a constant time, "19:00:00". It doesn't matter what time it actually is, that's always the time that appears in the notifier email.
Any ideas?
Re: {TestLastChangeTime} always sends "19:00:00"
This variable is the time that the test last had a change. If you don't have Smart Change Detection enabled, or it hasn't changed for a while (e.g. has only failed and recovered), the value wouldn't change.
You might want to consider using {TestLastEventTime} instead; it outputs the time of a change, failure, or recovery.
