Dejal
Help to Restrict Search to Subject and Keyword
First, off I'd like to say "Thanks" for Caboodle. It helps me tremendously in my job. It's a great little product.
I currently have 288 items, and use the Search frequently to locate the exact item I need. Currently, the Search returns all items containing the phrase I enter - whether it's in the Subject, Keywords or Body. It would be great for me if there was a way to restrict it so it only looked in the Subject and Keywords (reduces the number of returns). I tried using all caps in the Keywords, and then typing my phrase in all caps, but the Search is case-insensitive.
If anyone has any suggestions for how I can restrict the Caboodle Search to only return entries whose Subject or Keywords match my search phrase, I'd appreciate it.
Re: Help to Restrict Search to Subject and Keyword
If I recall correctly, you can restrict it by prefixing the field name. For example, "subject: your subject" or "keywords: keyword". This would probably only work with the first words of the field, though.
In the future, I want to add more refined searching, like in the Finder.
