change PAUSE TEST default from 15 minutes?
Is there a way to change the PAUSE TEST default from 15 minutes to another time interval? thanks
Re: change PAUSE TEST default from 15 minutes?
No... though it remembers the value until you quit, so subsequent pauses will default to the same choice.
I suppose I could make it persist over quits, too; that could be a reasonable feature idea for a future release.
