Too many tests
I periodically get a message that says I have too many tests running, and that I should pause some of them to get the number to 7 or under; yet I have only 6 tests running...and 3 paused.
Re: Too many tests
That seems odd. Can you please provide a screenshot showing the tests and alert, in case I can spot an issue.
You can either edit your original post to attach it, or send via email.
