Re: Simon crashed and now I'm missing data
I'm sorry to hear that. I haven't heard of data loss like that before, but I suppose if the machine lost power at the precise wrong time, when the file was being saved, it could happen. Would be a major fluke, though: the data is written out in a way that should avoid that possibility.
Anyway, the data is stored in the ~/Library/Application Support/Dejal/Simon folder. You could perhaps revert this folder from a backup to get the data back, though of course you'd lose any changes you've made since then.
