Re: background color bug
I agree, it should continue to use red while checking, until actually successful.
Simon gets around this by having two status values internally: the current status, which may include checking or paused, and the last status, which is what it was when not checking. So perhaps I either need to expose that for the report, or use its value there.
I've made a note, and will look into this further when I next work on Simon.
Thanks for the feedback!
