When I go to add a new task on Simon running on my 2009 Unibody 13", the dialogue box is cut off and I can slide it up any further to press the Ok button.... can the layout of this box be corrected to fit on a 13" display?
Re: Dialogue box for new task cut of on 13" monitor
I definitely want to redesign this window to fit better on smaller screens. In fact, I have redesigned it, and came >thisclose< to implementing the redesign in version 2.6, but decided to leave it for the next version instead.
In the meantime, you can collapse sections until it does fit, or press Return for OK or Escape for Cancel.
