This service appears to use Plaintext authentication only. Is there a way to change this to MD5? Feature request?
Right now, my mail server won't accept plaintext logins and therefore I can't use this test to confirm if our mail server is running. :(
Thank you.
Re: Incoming Mail (IMAP) - "Plaintext authentication ...
See the "Incoming Mail (POP) via SSL" service on the Simon Extras page. That is for POP, but could probably be modified for IMAP.
Gave that a shot and it didn't work either. Used port 143. I also tried typing the command into terminal and seeing the results. Was getting an error. I don't have ssl enabled on our mail server. It's just MD5 encryption.
If you can find a way to check it via Terminal, you could use that in Simon. Maybe a simple
telnetsession would work, though maybe not if there's encryption.
