Login not working on Web Test?
I am trying to use a web test on a phpmyadmin install (testing mysql and http at same time).
I have the correct username/password entered, but it fails every time.
Any ideas?
P.S. Where is the search option for these forums?
Mike
Re: Login not working on Web Test?
Hi Mike,
The username and password are used for an authentication challenge, as displayed in a normal web browser via a password sheet. Some websites use different authentication, like a login form. For those, you'll need to use cookies instead. Simply do a preview of the site via the test, log in as normal, and the cookies will be recorded.
If that doesn't help, please provide more information about the issue, including any error. (Via email if you prefer.)
There's a search field at the bottom of every page on the website.
