Re: How too check for RDP client being up
You can add your own services for whatever you like. I'm not sure what the best way to check on Remote Desktop might be, but perhaps a Port-based service could help — check if the RDP port responds appropriately. Or if there's a terminal command to check on it, a Script-based service would do the trick.
Anyone else already created a service for this?
