Re: License issue
I think you may have misread the message; Simon doesn't have such a message. You should be able to add your license on two machines.
If it said something about "partially licensed", that means that you have a version 2 license, and need a version 3 upgrade.
Re: License issue
Ok, I tried again. The version of Simon is 3.0.1 the key is a Silver Upgrade to V3.
This time I entered the values manually and the key was accepted but the app still shows the '13 days left - buy now' alert.
Re: License issue
You need to have both your v2 license and your v3 upgrade entered. Sounds like it's missing the v2 license.
Re: License issue
Found out that I was using a different e-mail address for the basic license. Now it worked.
Thanks a lot.
