Re: Device Groups or Profiles
For now, the solution is to pause them, as you found. You can use a naming convention and sort by name, or sort by the service kind, to quickly find and select the relevant tests.
In the future, yes, I plan to add group support. It's a popular request, and definitely high on my priority list.
Thanks David!
Regards,
-steve w.
www.sudonetworks.com
