Oracle monitoring
I am a new user of Simon.
I have been looking for a way to monitor that oracle servers are up and running, possibly avoiding the installation of the oracle client (thus, without tnsping).
As there does not seem to be anything for monitoring oracle databases in Simon's default tests, I have put together some pieces of code and wrote a short java class called TestDBOracle for the purpose.
Basically, using jdbc, it accepts the following parameters:
ServerName
OracleSid
ListenerPort (default 1521)
UserName
Password
and it connects to the oracle database to execute the test query:
SELECT 1 FROM DUAL;
Finally, it closes the connection.
Here is a sample output:
java TestDBOracle server SID 1521 user password
Fri Jun 17 15:34:14 WEST 2011 Before opening DB connection
Fri Jun 17 15:34:15 WEST 2011 DB connection opened
Fri Jun 17 15:34:15 WEST 2011 select 1 from dual executed
here is the source code:
import java.util.*;
import java.sql.*;
public class TestDBOracle {
  public static void main(String[] args)
      throws ClassNotFoundException, SQLException
        if (args.length < 5)
           System.out.println("Usage: java TestDBOracle ServerName OracleSID ListenerPort Username Password");
           System.exit(1);
        Driver d = new oracle.jdbc.driver.OracleDriver();
        DriverManager.registerDriver(d);
        String url = "jdbc:oracle:thin:" + args[3] + "/" + args[4] + "@" + args[0] + ":" + args[2] + ":" + args[1];
        System.out.println(new java.util.Date() + " Before opening DB connection");
    Connection conn =
         DriverManager.getConnection(url,args[3],args[4]);
        System.out.println(new java.util.Date() + " DB connection opened");
    conn.setAutoCommit(false);
    Statement stmt = conn.createStatement();
    ResultSet rset =
         stmt.executeQuery("select 1 from dual");
    System.out.println(new java.util.Date() + " select 1 from dual executed");
    stmt.close();
    conn.close();
Arguments:
ServerName 0
OracleSid 1
UserName 3
Password 4
In order to compile the class, copy the above code in a file called "TestDBOracle.java" and issue, from the command line:
javac TestDBOracle.java
The compilation will produce the file: "TestDBOracle", which can be invoked as shown above.
I hope this can be useful to other users.
Cheers,
Sergio
Re: Oracle monitoring
Thank you for posting that.
