hi All!
I was directed to this app by the Rebuild Your Vision course as a way to remind myself to rest my eyes during long periods of computer usage and it (Timeout) looks great!
Except! :-) Small problem, I can't seem to get it to work whatsoever! I'm probably missing something really simple but I just can't seem to get it to give me a break reminder. I've left the settings all at default, and tried to initiate both normal and micro breaks but nothing happens. I selected Timeout as a login item and restarted but it still doesn't do anything.
What am I missing? If I'm reading the release notes correctly it IS Lion compatible...? Is there something about 10.7.1 perhaps?
Longtime computer user and the app seems simple enough so I _think_ I'm using it correctly, just can't get it to ummm...do anything. :-) (Yes, I've read the Help pages.)
Thanks for any assistance! Would like to get it working, and look forward to the v.2.
Re: Is Timeout compatible with Lion 10.7.1?
Please download the latest version; version 1.6 had an issue that could prevent it from working on Lion, but 1.6.1 fixed that.
hi David,
Thanks for the prompt reply!
I neglected to mention in my original post, my version IS 1.6.1. Nevertheless I downloaded a fresh copy and overwrote the one I had, but still not working at all.
Mike
Weird. Is Time Out still running after restarting? Is the Begin Normal Break and/or Begin Micro Break menu item(s) enabled?
I suggest enabling the debug logging; that'll provide a clue.
Enter the following command in Terminal (in /Applications/Utilities):
defaults write com.dejal.timeout DebugScheduler YES
Then you can see the logging in Console (also in the Utilities folder). If that doesn't make sense to you, paste in the log entries after manually starting a break for me to analyze.
Ouch! Need help!
Really need this app because of cervical arthritis BUT have carefully done and redone every thing to get it to work—i.e., all settings, etc., etc. but it will not work on my iMac with Lion OS (I have version 1.6.1 Timeout)
In addition, and hugely frustrating, the Timeout continues every minute or so to blink my screen with the color I chose as a background during breaks!
What have I done wrong?
James Fenwick
fenwick@fenwicks.com
The above questions apply to you, too. And trying the schedule logging as indicated above may help, too.
Are you using full-screen apps? When switching between full-screen apps on Lion, during a break, Time Out's break display will vanish and re-appear over the new app. That's just the way full-screen works in Lion (the same applies to other apps that work in all spaces).
If that doesn't clarify it, perhaps a screenshot of how Time Out looks during a break might help.
I too am having problems with Lion. when the program is open the timer never comes on, I can access all the menus and if I choose begin break now it will start a break, BUT if left to function automatically it no longer comes up with a timeout break ever, nothing happens
I have removed timeout and reinstalled it, I have the last version, do you have any idea what is wrong and what I need to do
Many Thanks
I suggest trying the Terminal command, as given in my second reply above. That will log when Time Out thinks breaks are due. Feel free to send me the log if it doesn't make sense to you.
If there is an issue, I'm keen to fix it, but I need more information, such as from that log.
Thank you for your reply
I went into terminal command and pasted the text you requested, nothing happened and I can't see anything called logging in terminal in the utilities folder. Would it be possible to give a very step but step run thorough of what need doing
Many Thanks
That command simply enables the logging. You should quit Time Out before entering it, though it'd probably work if you didn't (but you'll need to quit and re-launch for it to take effect).
The logging appears in the Console, accessed via /Applications/Utilities/Console.
Not sure if this is what you need but I snapped some lines from the console, what should i do with it , sorry to keep asking questions but I don't really understand what thou are asking me to do
Thanks
Hi I copied from the console this hope this is what you needed
Many Thanks
27/10/2011 12:02:52.691 com.apple.launchd: (com.aladdin.hasplmd[7668]) Job appears to have crashed: Bus error: 10
27/10/2011 12:02:52.691 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:02:52.708 ReportCrash: Saved crash report for hasplmd[7668] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120252_localhost.crash
27/10/2011 12:03:02.508 Time Out: Idle 18446519649.3 secs; normal due 27/10/2011 12:54, micro due 27/10/2011 12:16
27/10/2011 12:03:02.510 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:03:02.511 Time Out: ...resetting normal timer
27/10/2011 12:03:02.513 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:55
27/10/2011 12:03:02.514 Time Out: ...resetting micro timer
27/10/2011 12:03:02.516 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:17
27/10/2011 12:03:02.879 com.apple.launchd: (com.aladdin.hasplmd[7669]) Job appears to have crashed: Bus error: 10
27/10/2011 12:03:02.879 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:03:02.897 ReportCrash: Saved crash report for hasplmd[7669] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120302_localhost.crash
27/10/2011 12:03:13.065 com.apple.launchd: (com.aladdin.hasplmd[7670]) Job appears to have crashed: Bus error: 10
27/10/2011 12:03:13.065 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:03:13.084 ReportCrash: Saved crash report for hasplmd[7670] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120313_localhost.crash
27/10/2011 12:03:17.508 Time Out: Idle 18446519664.3 secs; normal due 27/10/2011 12:55, micro due 27/10/2011 12:17
27/10/2011 12:03:17.511 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:03:17.511 Time Out: ...resetting normal timer
27/10/2011 12:03:17.514 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:55
27/10/2011 12:03:17.514 Time Out: ...resetting micro timer
27/10/2011 12:03:17.516 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:17
27/10/2011 12:03:23.098 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:03:23.266 com.apple.launchd: (com.aladdin.hasplmd[7671]) Job appears to have crashed: Bus error: 10
27/10/2011 12:03:23.266 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:03:23.312 ReportCrash: Saved crash report for hasplmd[7671] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120323_localhost.crash
27/10/2011 12:03:32.509 Time Out: Idle 18446519679.3 secs; normal due 27/10/2011 12:55, micro due 27/10/2011 12:17
27/10/2011 12:03:32.511 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:03:32.511 Time Out: ...resetting normal timer
27/10/2011 12:03:32.513 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:55
27/10/2011 12:03:32.514 Time Out: ...resetting micro timer
27/10/2011 12:03:32.516 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:17
27/10/2011 12:03:33.454 com.apple.launchd: (com.aladdin.hasplmd[7673]) Job appears to have crashed: Bus error: 10
27/10/2011 12:03:33.454 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:03:33.467 ReportCrash: Saved crash report for hasplmd[7673] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120333_localhost.crash
27/10/2011 12:03:43.641 com.apple.launchd: (com.aladdin.hasplmd[7674]) Job appears to have crashed: Bus error: 10
27/10/2011 12:03:43.641 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:03:43.654 ReportCrash: Saved crash report for hasplmd[7674] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120343_localhost.crash
27/10/2011 12:03:47.509 Time Out: Idle 18446519694.3 secs; normal due 27/10/2011 12:55, micro due 27/10/2011 12:17
27/10/2011 12:03:47.511 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:03:47.512 Time Out: ...resetting normal timer
27/10/2011 12:03:47.514 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:55
27/10/2011 12:03:47.515 Time Out: ...resetting micro timer
27/10/2011 12:03:47.517 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:17
27/10/2011 12:03:53.827 com.apple.launchd: (com.aladdin.hasplmd[7675]) Job appears to have crashed: Bus error: 10
27/10/2011 12:03:53.827 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:03:53.840 ReportCrash: Saved crash report for hasplmd[7675] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120353_localhost.crash
27/10/2011 12:04:02.509 Time Out: Idle 18446519709.3 secs; normal due 27/10/2011 12:55, micro due 27/10/2011 12:17
27/10/2011 12:04:02.511 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:04:02.512 Time Out: ...resetting normal timer
27/10/2011 12:04:02.514 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:56
27/10/2011 12:04:02.514 Time Out: ...resetting micro timer
27/10/2011 12:04:02.517 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:18
27/10/2011 12:04:04.013 com.apple.launchd: (com.aladdin.hasplmd[7676]) Job appears to have crashed: Bus error: 10
27/10/2011 12:04:04.013 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:04:04.027 ReportCrash: Saved crash report for hasplmd[7676] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120404_localhost.crash
27/10/2011 12:04:14.201 com.apple.launchd: (com.aladdin.hasplmd[7677]) Job appears to have crashed: Bus error: 10
27/10/2011 12:04:14.201 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:04:14.214 ReportCrash: Saved crash report for hasplmd[7677] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120414_localhost.crash
27/10/2011 12:04:17.509 Time Out: Idle 18446519724.3 secs; normal due 27/10/2011 12:56, micro due 27/10/2011 12:18
27/10/2011 12:04:17.510 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:04:17.511 Time Out: ...resetting normal timer
27/10/2011 12:04:17.513 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:56
27/10/2011 12:04:17.514 Time Out: ...resetting micro timer
27/10/2011 12:04:17.516 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:18
27/10/2011 12:04:24.233 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:04:24.401 com.apple.launchd: (com.aladdin.hasplmd[7678]) Job appears to have crashed: Bus error: 10
27/10/2011 12:04:24.401 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:04:24.448 ReportCrash: Saved crash report for hasplmd[7678] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120424_localhost.crash
27/10/2011 12:04:32.509 Time Out: Idle 18446519739.3 secs; normal due 27/10/2011 12:56, micro due 27/10/2011 12:18
27/10/2011 12:04:32.512 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:04:32.512 Time Out: ...resetting normal timer
27/10/2011 12:04:32.514 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:56
27/10/2011 12:04:32.515 Time Out: ...resetting micro timer
27/10/2011 12:04:32.517 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:18
27/10/2011 12:04:34.590 com.apple.launchd: (com.aladdin.hasplmd[7680]) Job appears to have crashed: Bus error: 10
27/10/2011 12:04:34.590 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:04:34.608 ReportCrash: Saved crash report for hasplmd[7680] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120434_localhost.crash
27/10/2011 12:04:44.775 com.apple.launchd: (com.aladdin.hasplmd[7681]) Job appears to have crashed: Bus error: 10
27/10/2011 12:04:44.775 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:04:44.788 ReportCrash: Saved crash report for hasplmd[7681] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120444_localhost.crash
27/10/2011 12:04:47.509 Time Out: Idle 18446519754.3 secs; normal due 27/10/2011 12:56, micro due 27/10/2011 12:18
27/10/2011 12:04:47.512 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:04:47.513 Time Out: ...resetting normal timer
27/10/2011 12:04:47.515 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:56
27/10/2011 12:04:47.515 Time Out: ...resetting micro timer
27/10/2011 12:04:47.517 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:18
27/10/2011 12:04:54.965 com.apple.launchd: (com.aladdin.hasplmd[7682]) Job appears to have crashed: Bus error: 10
27/10/2011 12:04:54.965 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:04:54.978 ReportCrash: Saved crash report for hasplmd[7682] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120454_localhost.crash
27/10/2011 12:05:02.509 Time Out: Idle 18446519769.3 secs; normal due 27/10/2011 12:56, micro due 27/10/2011 12:18
27/10/2011 12:05:02.511 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:05:02.512 Time Out: ...resetting normal timer
27/10/2011 12:05:02.514 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:57
27/10/2011 12:05:02.515 Time Out: ...resetting micro timer
27/10/2011 12:05:02.517 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:19
27/10/2011 12:05:05.154 com.apple.launchd: (com.aladdin.hasplmd[7683]) Job appears to have crashed: Bus error: 10
27/10/2011 12:05:05.154 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:05:05.167 ReportCrash: Saved crash report for hasplmd[7683] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120505_localhost.crash
27/10/2011 12:05:15.344 com.apple.launchd: (com.aladdin.hasplmd[7684]) Job appears to have crashed: Bus error: 10
27/10/2011 12:05:15.344 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:05:15.357 ReportCrash: Saved crash report for hasplmd[7684] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120515_localhost.crash
27/10/2011 12:05:17.510 Time Out: Idle 18446519784.3 secs; normal due 27/10/2011 12:57, micro due 27/10/2011 12:19
27/10/2011 12:05:17.512 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:05:17.513 Time Out: ...resetting normal timer
27/10/2011 12:05:17.515 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:57
27/10/2011 12:05:17.515 Time Out: ...resetting micro timer
27/10/2011 12:05:17.517 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:19
27/10/2011 12:05:25.377 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:05:25.544 com.apple.launchd: (com.aladdin.hasplmd[7685]) Job appears to have crashed: Bus error: 10
27/10/2011 12:05:25.544 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:05:25.592 ReportCrash: Saved crash report for hasplmd[7685] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120525_localhost.crash
27/10/2011 12:05:32.510 Time Out: Idle 18446519799.3 secs; normal due 27/10/2011 12:57, micro due 27/10/2011 12:19
27/10/2011 12:05:32.512 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:05:32.513 Time Out: ...resetting normal timer
27/10/2011 12:05:32.515 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:57
27/10/2011 12:05:32.516 Time Out: ...resetting micro timer
27/10/2011 12:05:32.518 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:19
27/10/2011 12:05:35.731 com.apple.launchd: (com.aladdin.hasplmd[7687]) Job appears to have crashed: Bus error: 10
27/10/2011 12:05:35.731 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:05:35.745 ReportCrash: Saved crash report for hasplmd[7687] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120535_localhost.crash
27/10/2011 12:05:45.920 com.apple.launchd: (com.aladdin.hasplmd[7688]) Job appears to have crashed: Bus error: 10
27/10/2011 12:05:45.920 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:05:45.933 ReportCrash: Saved crash report for hasplmd[7688] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120545_localhost.crash
27/10/2011 12:05:47.510 Time Out: Idle 18446519814.3 secs; normal due 27/10/2011 12:57, micro due 27/10/2011 12:19
27/10/2011 12:05:47.512 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:05:47.513 Time Out: ...resetting normal timer
27/10/2011 12:05:47.515 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:57
27/10/2011 12:05:47.516 Time Out: ...resetting micro timer
27/10/2011 12:05:47.517 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:19
27/10/2011 12:05:56.107 com.apple.launchd: (com.aladdin.hasplmd[7689]) Job appears to have crashed: Bus error: 10
27/10/2011 12:05:56.107 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:05:56.120 ReportCrash: Saved crash report for hasplmd[7689] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120556_localhost.crash
27/10/2011 12:06:02.510 Time Out: Idle 18446519829.3 secs; normal due 27/10/2011 12:57, micro due 27/10/2011 12:19
27/10/2011 12:06:02.512 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:06:02.513 Time Out: ...resetting normal timer
27/10/2011 12:06:02.514 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:58
27/10/2011 12:06:02.515 Time Out: ...resetting micro timer
27/10/2011 12:06:02.517 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:20
27/10/2011 12:06:06.291 com.apple.launchd: (com.aladdin.hasplmd[7690]) Job appears to have crashed: Bus error: 10
27/10/2011 12:06:06.291 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:06:06.304 ReportCrash: Saved crash report for hasplmd[7690] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120606_localhost.crash
27/10/2011 12:06:16.478 com.apple.launchd: (com.aladdin.hasplmd[7691]) Job appears to have crashed: Bus error: 10
27/10/2011 12:06:16.478 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:06:16.490 ReportCrash: Saved crash report for hasplmd[7691] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120616_localhost.crash
27/10/2011 12:06:17.510 Time Out: Idle 18446519844.3 secs; normal due 27/10/2011 12:58, micro due 27/10/2011 12:20
27/10/2011 12:06:17.512 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:06:17.513 Time Out: ...resetting normal timer
27/10/2011 12:06:17.515 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:58
27/10/2011 12:06:17.516 Time Out: ...resetting micro timer
27/10/2011 12:06:17.518 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:20
27/10/2011 12:06:26.511 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:06:26.680 com.apple.launchd: (com.aladdin.hasplmd[7692]) Job appears to have crashed: Bus error: 10
27/10/2011 12:06:26.680 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:06:26.732 ReportCrash: Saved crash report for hasplmd[7692] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120626_localhost.crash
27/10/2011 12:06:32.510 Time Out: Idle 18446519859.3 secs; normal due 27/10/2011 12:58, micro due 27/10/2011 12:20
27/10/2011 12:06:32.512 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:06:32.513 Time Out: ...resetting normal timer
27/10/2011 12:06:32.515 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:58
27/10/2011 12:06:32.516 Time Out: ...resetting micro timer
27/10/2011 12:06:32.518 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:20
27/10/2011 12:06:36.869 com.apple.launchd: (com.aladdin.hasplmd[7694]) Job appears to have crashed: Bus error: 10
27/10/2011 12:06:36.869 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:06:36.887 ReportCrash: Saved crash report for hasplmd[7694] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120636_localhost.crash
27/10/2011 12:06:47.056 com.apple.launchd: (com.aladdin.hasplmd[7695]) Job appears to have crashed: Bus error: 10
27/10/2011 12:06:47.056 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:06:47.069 ReportCrash: Saved crash report for hasplmd[7695] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120647_localhost.crash
27/10/2011 12:06:47.511 Time Out: Idle 18446519874.3 secs; normal due 27/10/2011 12:58, micro due 27/10/2011 12:20
27/10/2011 12:06:47.513 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:06:47.514 Time Out: ...resetting normal timer
27/10/2011 12:06:47.516 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:58
27/10/2011 12:06:47.516 Time Out: ...resetting micro timer
27/10/2011 12:06:47.519 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:20
27/10/2011 12:06:57.246 com.apple.launchd: (com.aladdin.hasplmd[7696]) Job appears to have crashed: Bus error: 10
27/10/2011 12:06:57.246 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:06:57.259 ReportCrash: Saved crash report for hasplmd[7696] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120657_localhost.crash
27/10/2011 12:07:02.511 Time Out: Idle 18446519889.3 secs; normal due 27/10/2011 12:58, micro due 27/10/2011 12:20
27/10/2011 12:07:02.512 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:07:02.513 Time Out: ...resetting normal timer
27/10/2011 12:07:02.515 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:59
27/10/2011 12:07:02.516 Time Out: ...resetting micro timer
27/10/2011 12:07:02.518 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:21
27/10/2011 12:07:07.433 com.apple.launchd: (com.aladdin.hasplmd[7697]) Job appears to have crashed: Bus error: 10
27/10/2011 12:07:07.433 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:07:07.450 ReportCrash: Saved crash report for hasplmd[7697] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120707_localhost.crash
27/10/2011 12:07:17.510 Time Out: Idle 18446519904.3 secs; normal due 27/10/2011 12:59, micro due 27/10/2011 12:21
27/10/2011 12:07:17.511 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:07:17.512 Time Out: ...resetting normal timer
27/10/2011 12:07:17.513 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:59
27/10/2011 12:07:17.513 Time Out: ...resetting micro timer
27/10/2011 12:07:17.515 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:21
27/10/2011 12:07:17.620 com.apple.launchd: (com.aladdin.hasplmd[7698]) Job appears to have crashed: Bus error: 10
27/10/2011 12:07:17.620 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:07:17.633 ReportCrash: Saved crash report for hasplmd[7698] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120717_localhost.crash
27/10/2011 12:07:27.653 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:07:27.823 com.apple.launchd: (com.aladdin.hasplmd[7699]) Job appears to have crashed: Bus error: 10
27/10/2011 12:07:27.823 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:07:27.871 ReportCrash: Saved crash report for hasplmd[7699] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120727_localhost.crash
27/10/2011 12:07:32.511 Time Out: Idle 18446519919.3 secs; normal due 27/10/2011 12:59, micro due 27/10/2011 12:21
27/10/2011 12:07:32.513 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:07:32.514 Time Out: ...resetting normal timer
27/10/2011 12:07:32.516 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:59
27/10/2011 12:07:32.517 Time Out: ...resetting micro timer
27/10/2011 12:07:32.519 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:21
27/10/2011 12:07:38.009 com.apple.launchd: (com.aladdin.hasplmd[7701]) Job appears to have crashed: Bus error: 10
27/10/2011 12:07:38.009 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:07:38.022 ReportCrash: Saved crash report for hasplmd[7701] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120738_localhost.crash
27/10/2011 12:07:47.511 Time Out: Idle 18446519934.3 secs; normal due 27/10/2011 12:59, micro due 27/10/2011 12:21
27/10/2011 12:07:47.513 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:07:47.514 Time Out: ...resetting normal timer
27/10/2011 12:07:47.516 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 12:59
27/10/2011 12:07:47.517 Time Out: ...resetting micro timer
27/10/2011 12:07:47.519 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:21
27/10/2011 12:07:48.197 com.apple.launchd: (com.aladdin.hasplmd[7702]) Job appears to have crashed: Bus error: 10
27/10/2011 12:07:48.197 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:07:48.210 ReportCrash: Saved crash report for hasplmd[7702] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120748_localhost.crash
27/10/2011 12:07:58.385 com.apple.launchd: (com.aladdin.hasplmd[7704]) Job appears to have crashed: Bus error: 10
27/10/2011 12:07:58.385 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:07:58.398 ReportCrash: Saved crash report for hasplmd[7704] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120758_localhost.crash
27/10/2011 12:08:02.511 Time Out: Idle 18446519949.3 secs; normal due 27/10/2011 12:59, micro due 27/10/2011 12:21
27/10/2011 12:08:02.514 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:08:02.514 Time Out: ...resetting normal timer
27/10/2011 12:08:02.517 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:00
27/10/2011 12:08:02.517 Time Out: ...resetting micro timer
27/10/2011 12:08:02.519 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:22
27/10/2011 12:08:08.571 com.apple.launchd: (com.aladdin.hasplmd[7705]) Job appears to have crashed: Bus error: 10
27/10/2011 12:08:08.571 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:08:08.584 ReportCrash: Saved crash report for hasplmd[7705] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120808_localhost.crash
27/10/2011 12:08:17.512 Time Out: Idle 18446519964.3 secs; normal due 27/10/2011 13:00, micro due 27/10/2011 12:22
27/10/2011 12:08:17.514 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:08:17.515 Time Out: ...resetting normal timer
27/10/2011 12:08:17.517 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:00
27/10/2011 12:08:17.517 Time Out: ...resetting micro timer
27/10/2011 12:08:17.519 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:22
27/10/2011 12:08:18.758 com.apple.launchd: (com.aladdin.hasplmd[7706]) Job appears to have crashed: Bus error: 10
27/10/2011 12:08:18.758 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:08:18.770 ReportCrash: Saved crash report for hasplmd[7706] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120818_localhost.crash
27/10/2011 12:08:28.791 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:08:28.965 com.apple.launchd: (com.aladdin.hasplmd[7707]) Job appears to have crashed: Bus error: 10
27/10/2011 12:08:28.965 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:08:29.013 ReportCrash: Saved crash report for hasplmd[7707] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120829_localhost.crash
27/10/2011 12:08:32.512 Time Out: Idle 18446519979.3 secs; normal due 27/10/2011 13:00, micro due 27/10/2011 12:22
27/10/2011 12:08:32.514 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:08:32.515 Time Out: ...resetting normal timer
27/10/2011 12:08:32.517 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:00
27/10/2011 12:08:32.517 Time Out: ...resetting micro timer
27/10/2011 12:08:32.519 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:22
27/10/2011 12:08:39.151 com.apple.launchd: (com.aladdin.hasplmd[7709]) Job appears to have crashed: Bus error: 10
27/10/2011 12:08:39.151 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:08:39.164 ReportCrash: Saved crash report for hasplmd[7709] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120839_localhost.crash
27/10/2011 12:08:47.512 Time Out: Idle 18446519994.3 secs; normal due 27/10/2011 13:00, micro due 27/10/2011 12:22
27/10/2011 12:08:47.514 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:08:47.515 Time Out: ...resetting normal timer
27/10/2011 12:08:47.517 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:00
27/10/2011 12:08:47.518 Time Out: ...resetting micro timer
27/10/2011 12:08:47.520 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:22
27/10/2011 12:08:49.335 com.apple.launchd: (com.aladdin.hasplmd[7710]) Job appears to have crashed: Bus error: 10
27/10/2011 12:08:49.335 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:08:49.348 ReportCrash: Saved crash report for hasplmd[7710] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120849_localhost.crash
27/10/2011 12:08:59.524 com.apple.launchd: (com.aladdin.hasplmd[7711]) Job appears to have crashed: Bus error: 10
27/10/2011 12:08:59.524 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:08:59.537 ReportCrash: Saved crash report for hasplmd[7711] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120859_localhost.crash
27/10/2011 12:09:02.512 Time Out: Idle 18446520009.3 secs; normal due 27/10/2011 13:00, micro due 27/10/2011 12:22
27/10/2011 12:09:02.514 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:09:02.515 Time Out: ...resetting normal timer
27/10/2011 12:09:02.517 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:01
27/10/2011 12:09:02.518 Time Out: ...resetting micro timer
27/10/2011 12:09:02.520 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:23
27/10/2011 12:09:09.710 com.apple.launchd: (com.aladdin.hasplmd[7712]) Job appears to have crashed: Bus error: 10
27/10/2011 12:09:09.710 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:09:09.723 ReportCrash: Saved crash report for hasplmd[7712] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120909_localhost.crash
27/10/2011 12:09:17.512 Time Out: Idle 18446520024.3 secs; normal due 27/10/2011 13:01, micro due 27/10/2011 12:23
27/10/2011 12:09:17.514 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:09:17.515 Time Out: ...resetting normal timer
27/10/2011 12:09:17.517 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:01
27/10/2011 12:09:17.518 Time Out: ...resetting micro timer
27/10/2011 12:09:17.519 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:23
27/10/2011 12:09:19.896 com.apple.launchd: (com.aladdin.hasplmd[7713]) Job appears to have crashed: Bus error: 10
27/10/2011 12:09:19.896 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:09:19.913 ReportCrash: Saved crash report for hasplmd[7713] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120919_localhost.crash
27/10/2011 12:09:29.928 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:09:30.099 com.apple.launchd: (com.aladdin.hasplmd[7714]) Job appears to have crashed: Bus error: 10
27/10/2011 12:09:30.099 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:09:30.151 ReportCrash: Saved crash report for hasplmd[7714] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120930_localhost.crash
27/10/2011 12:09:32.512 Time Out: Idle 18446520039.3 secs; normal due 27/10/2011 13:01, micro due 27/10/2011 12:23
27/10/2011 12:09:32.515 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:09:32.516 Time Out: ...resetting normal timer
27/10/2011 12:09:32.518 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:01
27/10/2011 12:09:32.519 Time Out: ...resetting micro timer
27/10/2011 12:09:32.521 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:23
27/10/2011 12:09:40.284 com.apple.launchd: (com.aladdin.hasplmd[7716]) Job appears to have crashed: Bus error: 10
27/10/2011 12:09:40.284 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:09:40.297 ReportCrash: Saved crash report for hasplmd[7716] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120940_localhost.crash
27/10/2011 12:09:47.513 Time Out: Idle 18446520054.3 secs; normal due 27/10/2011 13:01, micro due 27/10/2011 12:23
27/10/2011 12:09:47.515 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:09:47.516 Time Out: ...resetting normal timer
27/10/2011 12:09:47.518 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:01
27/10/2011 12:09:47.518 Time Out: ...resetting micro timer
27/10/2011 12:09:47.520 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:23
27/10/2011 12:09:50.474 com.apple.launchd: (com.aladdin.hasplmd[7717]) Job appears to have crashed: Bus error: 10
27/10/2011 12:09:50.474 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:09:50.486 ReportCrash: Saved crash report for hasplmd[7717] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-120950_localhost.crash
27/10/2011 12:10:00.657 com.apple.launchd: (com.aladdin.hasplmd[7718]) Job appears to have crashed: Bus error: 10
27/10/2011 12:10:00.657 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:10:00.671 ReportCrash: Saved crash report for hasplmd[7718] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121000_localhost.crash
27/10/2011 12:10:02.513 Time Out: Idle 18446520069.3 secs; normal due 27/10/2011 13:01, micro due 27/10/2011 12:23
27/10/2011 12:10:02.515 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:10:02.516 Time Out: ...resetting normal timer
27/10/2011 12:10:02.518 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:02
27/10/2011 12:10:02.519 Time Out: ...resetting micro timer
27/10/2011 12:10:02.520 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:24
27/10/2011 12:10:10.844 com.apple.launchd: (com.aladdin.hasplmd[7719]) Job appears to have crashed: Bus error: 10
27/10/2011 12:10:10.844 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:10:10.857 ReportCrash: Saved crash report for hasplmd[7719] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121010_localhost.crash
27/10/2011 12:10:17.513 Time Out: Idle 18446520084.3 secs; normal due 27/10/2011 13:02, micro due 27/10/2011 12:24
27/10/2011 12:10:17.515 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:10:17.516 Time Out: ...resetting normal timer
27/10/2011 12:10:17.518 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:02
27/10/2011 12:10:17.519 Time Out: ...resetting micro timer
27/10/2011 12:10:17.521 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:24
27/10/2011 12:10:21.033 com.apple.launchd: (com.aladdin.hasplmd[7720]) Job appears to have crashed: Bus error: 10
27/10/2011 12:10:21.033 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:10:21.051 ReportCrash: Saved crash report for hasplmd[7720] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121021_localhost.crash
27/10/2011 12:10:31.066 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:10:31.235 com.apple.launchd: (com.aladdin.hasplmd[7721]) Job appears to have crashed: Bus error: 10
27/10/2011 12:10:31.235 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:10:31.282 ReportCrash: Saved crash report for hasplmd[7721] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121031_localhost.crash
27/10/2011 12:10:32.513 Time Out: Idle 18446520099.3 secs; normal due 27/10/2011 13:02, micro due 27/10/2011 12:24
27/10/2011 12:10:32.515 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:10:32.516 Time Out: ...resetting normal timer
27/10/2011 12:10:32.518 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:02
27/10/2011 12:10:32.519 Time Out: ...resetting micro timer
27/10/2011 12:10:32.521 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:24
27/10/2011 12:10:41.424 com.apple.launchd: (com.aladdin.hasplmd[7723]) Job appears to have crashed: Bus error: 10
27/10/2011 12:10:41.424 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:10:41.437 ReportCrash: Saved crash report for hasplmd[7723] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121041_localhost.crash
27/10/2011 12:10:47.513 Time Out: Idle 18446520114.3 secs; normal due 27/10/2011 13:02, micro due 27/10/2011 12:24
27/10/2011 12:10:47.515 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:10:47.516 Time Out: ...resetting normal timer
27/10/2011 12:10:47.518 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:02
27/10/2011 12:10:47.519 Time Out: ...resetting micro timer
27/10/2011 12:10:47.520 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:24
27/10/2011 12:10:51.613 com.apple.launchd: (com.aladdin.hasplmd[7725]) Job appears to have crashed: Bus error: 10
27/10/2011 12:10:51.613 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:10:51.631 ReportCrash: Saved crash report for hasplmd[7725] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121051_localhost.crash
27/10/2011 12:11:01.798 com.apple.launchd: (com.aladdin.hasplmd[7726]) Job appears to have crashed: Bus error: 10
27/10/2011 12:11:01.798 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:11:01.811 ReportCrash: Saved crash report for hasplmd[7726] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121101_localhost.crash
27/10/2011 12:11:02.513 Time Out: Idle 18446520129.3 secs; normal due 27/10/2011 13:02, micro due 27/10/2011 12:24
27/10/2011 12:11:02.515 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:11:02.516 Time Out: ...resetting normal timer
27/10/2011 12:11:02.518 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:03
27/10/2011 12:11:02.519 Time Out: ...resetting micro timer
27/10/2011 12:11:02.521 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:25
27/10/2011 12:11:11.983 com.apple.launchd: (com.aladdin.hasplmd[7727]) Job appears to have crashed: Bus error: 10
27/10/2011 12:11:11.983 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:11:11.996 ReportCrash: Saved crash report for hasplmd[7727] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121111_localhost.crash
27/10/2011 12:11:17.514 Time Out: Idle 18446520144.3 secs; normal due 27/10/2011 13:03, micro due 27/10/2011 12:25
27/10/2011 12:11:17.516 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:11:17.516 Time Out: ...resetting normal timer
27/10/2011 12:11:17.518 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:03
27/10/2011 12:11:17.519 Time Out: ...resetting micro timer
27/10/2011 12:11:17.521 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:25
27/10/2011 12:11:22.173 com.apple.launchd: (com.aladdin.hasplmd[7728]) Job appears to have crashed: Bus error: 10
27/10/2011 12:11:22.173 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:11:22.186 ReportCrash: Saved crash report for hasplmd[7728] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121122_localhost.crash
27/10/2011 12:11:32.207 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:11:32.373 com.apple.launchd: (com.aladdin.hasplmd[7729]) Job appears to have crashed: Bus error: 10
27/10/2011 12:11:32.373 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:11:32.422 ReportCrash: Saved crash report for hasplmd[7729] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121132_localhost.crash
27/10/2011 12:11:32.514 Time Out: Idle 18446520159.3 secs; normal due 27/10/2011 13:03, micro due 27/10/2011 12:25
27/10/2011 12:11:32.516 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:11:32.517 Time Out: ...resetting normal timer
27/10/2011 12:11:32.519 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:03
27/10/2011 12:11:32.519 Time Out: ...resetting micro timer
27/10/2011 12:11:32.522 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:25
27/10/2011 12:11:42.561 com.apple.launchd: (com.aladdin.hasplmd[7731]) Job appears to have crashed: Bus error: 10
27/10/2011 12:11:42.561 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:11:42.574 ReportCrash: Saved crash report for hasplmd[7731] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121142_localhost.crash
27/10/2011 12:11:47.514 Time Out: Idle 18446520174.3 secs; normal due 27/10/2011 13:03, micro due 27/10/2011 12:25
27/10/2011 12:11:47.516 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:11:47.517 Time Out: ...resetting normal timer
27/10/2011 12:11:47.519 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:03
27/10/2011 12:11:47.519 Time Out: ...resetting micro timer
27/10/2011 12:11:47.521 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:25
27/10/2011 12:11:52.751 com.apple.launchd: (com.aladdin.hasplmd[7732]) Job appears to have crashed: Bus error: 10
27/10/2011 12:11:52.751 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:11:52.769 ReportCrash: Saved crash report for hasplmd[7732] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121152_localhost.crash
27/10/2011 12:12:02.514 Time Out: Idle 18446520189.3 secs; normal due 27/10/2011 13:03, micro due 27/10/2011 12:25
27/10/2011 12:12:02.516 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:12:02.517 Time Out: ...resetting normal timer
27/10/2011 12:12:02.519 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:04
27/10/2011 12:12:02.520 Time Out: ...resetting micro timer
27/10/2011 12:12:02.522 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:26
27/10/2011 12:12:02.939 com.apple.launchd: (com.aladdin.hasplmd[7733]) Job appears to have crashed: Bus error: 10
27/10/2011 12:12:02.939 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:12:02.952 ReportCrash: Saved crash report for hasplmd[7733] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121202_localhost.crash
27/10/2011 12:12:13.127 com.apple.launchd: (com.aladdin.hasplmd[7734]) Job appears to have crashed: Bus error: 10
27/10/2011 12:12:13.127 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:12:13.140 ReportCrash: Saved crash report for hasplmd[7734] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121213_localhost.crash
27/10/2011 12:12:17.514 Time Out: Idle 18446520204.3 secs; normal due 27/10/2011 13:04, micro due 27/10/2011 12:26
27/10/2011 12:12:17.516 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:12:17.517 Time Out: ...resetting normal timer
27/10/2011 12:12:17.519 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:04
27/10/2011 12:12:17.520 Time Out: ...resetting micro timer
27/10/2011 12:12:17.522 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:26
27/10/2011 12:12:23.313 com.apple.launchd: (com.aladdin.hasplmd[7735]) Job appears to have crashed: Bus error: 10
27/10/2011 12:12:23.313 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:12:23.330 ReportCrash: Saved crash report for hasplmd[7735] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121223_localhost.crash
27/10/2011 12:12:32.514 Time Out: Idle 18446520219.3 secs; normal due 27/10/2011 13:04, micro due 27/10/2011 12:26
27/10/2011 12:12:32.516 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:12:32.517 Time Out: ...resetting normal timer
27/10/2011 12:12:32.519 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:04
27/10/2011 12:12:32.520 Time Out: ...resetting micro timer
27/10/2011 12:12:32.522 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:26
27/10/2011 12:12:33.346 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:12:33.515 com.apple.launchd: (com.aladdin.hasplmd[7736]) Job appears to have crashed: Bus error: 10
27/10/2011 12:12:33.515 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:12:33.566 ReportCrash: Saved crash report for hasplmd[7736] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121233_localhost.crash
27/10/2011 12:12:43.703 com.apple.launchd: (com.aladdin.hasplmd[7738]) Job appears to have crashed: Bus error: 10
27/10/2011 12:12:43.703 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:12:43.716 ReportCrash: Saved crash report for hasplmd[7738] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121243_localhost.crash
27/10/2011 12:12:47.515 Time Out: Idle 18446520234.3 secs; normal due 27/10/2011 13:04, micro due 27/10/2011 12:26
27/10/2011 12:12:47.517 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:12:47.518 Time Out: ...resetting normal timer
27/10/2011 12:12:47.520 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:04
27/10/2011 12:12:47.520 Time Out: ...resetting micro timer
27/10/2011 12:12:47.523 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:26
27/10/2011 12:12:53.892 com.apple.launchd: (com.aladdin.hasplmd[7739]) Job appears to have crashed: Bus error: 10
27/10/2011 12:12:53.892 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:12:53.904 ReportCrash: Saved crash report for hasplmd[7739] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121253_localhost.crash
27/10/2011 12:13:02.515 Time Out: Idle 18446520249.3 secs; normal due 27/10/2011 13:04, micro due 27/10/2011 12:26
27/10/2011 12:13:02.517 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:13:02.518 Time Out: ...resetting normal timer
27/10/2011 12:13:02.520 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:05
27/10/2011 12:13:02.520 Time Out: ...resetting micro timer
27/10/2011 12:13:02.522 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:27
27/10/2011 12:13:04.080 com.apple.launchd: (com.aladdin.hasplmd[7740]) Job appears to have crashed: Bus error: 10
27/10/2011 12:13:04.080 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:13:04.093 ReportCrash: Saved crash report for hasplmd[7740] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121304_localhost.crash
27/10/2011 12:13:14.263 com.apple.launchd: (com.aladdin.hasplmd[7741]) Job appears to have crashed: Bus error: 10
27/10/2011 12:13:14.263 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:13:14.276 ReportCrash: Saved crash report for hasplmd[7741] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121314_localhost.crash
27/10/2011 12:13:17.515 Time Out: Idle 18446520264.3 secs; normal due 27/10/2011 13:05, micro due 27/10/2011 12:27
27/10/2011 12:13:17.517 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:13:17.518 Time Out: ...resetting normal timer
27/10/2011 12:13:17.520 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:05
27/10/2011 12:13:17.521 Time Out: ...resetting micro timer
27/10/2011 12:13:17.523 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:27
27/10/2011 12:13:24.449 com.apple.launchd: (com.aladdin.hasplmd[7742]) Job appears to have crashed: Bus error: 10
27/10/2011 12:13:24.449 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:13:24.462 ReportCrash: Saved crash report for hasplmd[7742] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121324_localhost.crash
27/10/2011 12:13:32.515 Time Out: Idle 18446520279.3 secs; normal due 27/10/2011 13:05, micro due 27/10/2011 12:27
27/10/2011 12:13:32.517 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:13:32.518 Time Out: ...resetting normal timer
27/10/2011 12:13:32.520 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:05
27/10/2011 12:13:32.521 Time Out: ...resetting micro timer
27/10/2011 12:13:32.522 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:27
27/10/2011 12:13:34.484 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:13:34.653 com.apple.launchd: (com.aladdin.hasplmd[7743]) Job appears to have crashed: Bus error: 10
27/10/2011 12:13:34.653 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:13:34.703 ReportCrash: Saved crash report for hasplmd[7743] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121334_localhost.crash
27/10/2011 12:13:44.841 com.apple.launchd: (com.aladdin.hasplmd[7745]) Job appears to have crashed: Bus error: 10
27/10/2011 12:13:44.841 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:13:44.854 ReportCrash: Saved crash report for hasplmd[7745] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121344_localhost.crash
27/10/2011 12:13:47.515 Time Out: Idle 18446520294.3 secs; normal due 27/10/2011 13:05, micro due 27/10/2011 12:27
27/10/2011 12:13:47.517 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:13:47.518 Time Out: ...resetting normal timer
27/10/2011 12:13:47.520 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:05
27/10/2011 12:13:47.521 Time Out: ...resetting micro timer
27/10/2011 12:13:47.523 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:27
27/10/2011 12:13:55.030 com.apple.launchd: (com.aladdin.hasplmd[7746]) Job appears to have crashed: Bus error: 10
27/10/2011 12:13:55.030 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:13:55.043 ReportCrash: Saved crash report for hasplmd[7746] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121355_localhost.crash
27/10/2011 12:14:02.515 Time Out: Idle 18446520309.3 secs; normal due 27/10/2011 13:05, micro due 27/10/2011 12:27
27/10/2011 12:14:02.517 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:14:02.518 Time Out: ...resetting normal timer
27/10/2011 12:14:02.520 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:06
27/10/2011 12:14:02.521 Time Out: ...resetting micro timer
27/10/2011 12:14:02.522 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:28
27/10/2011 12:14:05.216 com.apple.launchd: (com.aladdin.hasplmd[7747]) Job appears to have crashed: Bus error: 10
27/10/2011 12:14:05.216 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:14:05.235 ReportCrash: Saved crash report for hasplmd[7747] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121405_localhost.crash
27/10/2011 12:14:15.405 com.apple.launchd: (com.aladdin.hasplmd[7748]) Job appears to have crashed: Bus error: 10
27/10/2011 12:14:15.405 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:14:15.418 ReportCrash: Saved crash report for hasplmd[7748] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121415_localhost.crash
27/10/2011 12:14:17.515 Time Out: Idle 18446520324.3 secs; normal due 27/10/2011 13:06, micro due 27/10/2011 12:28
27/10/2011 12:14:17.518 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:14:17.518 Time Out: ...resetting normal timer
27/10/2011 12:14:17.521 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:06
27/10/2011 12:14:17.521 Time Out: ...resetting micro timer
27/10/2011 12:14:17.524 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:28
27/10/2011 12:14:25.593 com.apple.launchd: (com.aladdin.hasplmd[7749]) Job appears to have crashed: Bus error: 10
27/10/2011 12:14:25.593 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:14:25.605 ReportCrash: Saved crash report for hasplmd[7749] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121425_localhost.crash
27/10/2011 12:14:32.516 Time Out: Idle 18446520339.3 secs; normal due 27/10/2011 13:06, micro due 27/10/2011 12:28
27/10/2011 12:14:32.518 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:14:32.518 Time Out: ...resetting normal timer
27/10/2011 12:14:32.520 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:06
27/10/2011 12:14:32.521 Time Out: ...resetting micro timer
27/10/2011 12:14:32.523 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:28
27/10/2011 12:14:35.626 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:14:35.796 com.apple.launchd: (com.aladdin.hasplmd[7750]) Job appears to have crashed: Bus error: 10
27/10/2011 12:14:35.796 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:14:35.846 ReportCrash: Saved crash report for hasplmd[7750] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121435_localhost.crash
27/10/2011 12:14:45.982 com.apple.launchd: (com.aladdin.hasplmd[7752]) Job appears to have crashed: Bus error: 10
27/10/2011 12:14:45.982 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:14:45.995 ReportCrash: Saved crash report for hasplmd[7752] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121445_localhost.crash
27/10/2011 12:14:47.516 Time Out: Idle 18446520354.3 secs; normal due 27/10/2011 13:06, micro due 27/10/2011 12:28
27/10/2011 12:14:47.518 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:14:47.519 Time Out: ...resetting normal timer
27/10/2011 12:14:47.521 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:06
27/10/2011 12:14:47.522 Time Out: ...resetting micro timer
27/10/2011 12:14:47.524 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:28
27/10/2011 12:14:56.173 com.apple.launchd: (com.aladdin.hasplmd[7753]) Job appears to have crashed: Bus error: 10
27/10/2011 12:14:56.173 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:14:56.186 ReportCrash: Saved crash report for hasplmd[7753] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121456_localhost.crash
27/10/2011 12:15:02.516 Time Out: Idle 18446520369.3 secs; normal due 27/10/2011 13:06, micro due 27/10/2011 12:28
27/10/2011 12:15:02.518 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:15:02.518 Time Out: ...resetting normal timer
27/10/2011 12:15:02.520 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:07
27/10/2011 12:15:02.521 Time Out: ...resetting micro timer
27/10/2011 12:15:02.522 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:29
27/10/2011 12:15:06.360 com.apple.launchd: (com.aladdin.hasplmd[7754]) Job appears to have crashed: Bus error: 10
27/10/2011 12:15:06.360 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:15:06.373 ReportCrash: Saved crash report for hasplmd[7754] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121506_localhost.crash
27/10/2011 12:15:16.548 com.apple.launchd: (com.aladdin.hasplmd[7755]) Job appears to have crashed: Bus error: 10
27/10/2011 12:15:16.548 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:15:16.561 ReportCrash: Saved crash report for hasplmd[7755] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121516_localhost.crash
27/10/2011 12:15:17.516 Time Out: Idle 18446520384.3 secs; normal due 27/10/2011 13:07, micro due 27/10/2011 12:29
27/10/2011 12:15:17.519 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:15:17.519 Time Out: ...resetting normal timer
27/10/2011 12:15:17.522 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:07
27/10/2011 12:15:17.522 Time Out: ...resetting micro timer
27/10/2011 12:15:17.524 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:29
27/10/2011 12:15:26.738 com.apple.launchd: (com.aladdin.hasplmd[7756]) Job appears to have crashed: Bus error: 10
27/10/2011 12:15:26.738 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:15:26.751 ReportCrash: Saved crash report for hasplmd[7756] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121526_localhost.crash
27/10/2011 12:15:32.516 Time Out: Idle 18446520399.3 secs; normal due 27/10/2011 13:07, micro due 27/10/2011 12:29
27/10/2011 12:15:32.518 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:15:32.519 Time Out: ...resetting normal timer
27/10/2011 12:15:32.521 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:07
27/10/2011 12:15:32.522 Time Out: ...resetting micro timer
27/10/2011 12:15:32.523 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:29
27/10/2011 12:15:36.771 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:15:36.940 com.apple.launchd: (com.aladdin.hasplmd[7757]) Job appears to have crashed: Bus error: 10
27/10/2011 12:15:36.940 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:15:36.992 ReportCrash: Saved crash report for hasplmd[7757] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121536_localhost.crash
27/10/2011 12:15:47.128 com.apple.launchd: (com.aladdin.hasplmd[7759]) Job appears to have crashed: Bus error: 10
27/10/2011 12:15:47.128 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:15:47.141 ReportCrash: Saved crash report for hasplmd[7759] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121547_localhost.crash
27/10/2011 12:15:47.517 Time Out: Idle 18446520414.3 secs; normal due 27/10/2011 13:07, micro due 27/10/2011 12:29
27/10/2011 12:15:47.519 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:15:47.520 Time Out: ...resetting normal timer
27/10/2011 12:15:47.522 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:07
27/10/2011 12:15:47.522 Time Out: ...resetting micro timer
27/10/2011 12:15:47.524 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:29
27/10/2011 12:15:57.314 com.apple.launchd: (com.aladdin.hasplmd[7760]) Job appears to have crashed: Bus error: 10
27/10/2011 12:15:57.314 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:15:57.328 ReportCrash: Saved crash report for hasplmd[7760] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121557_localhost.crash
27/10/2011 12:16:02.517 Time Out: Idle 18446520429.3 secs; normal due 27/10/2011 13:07, micro due 27/10/2011 12:29
27/10/2011 12:16:02.519 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:16:02.520 Time Out: ...resetting normal timer
27/10/2011 12:16:02.522 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:08
27/10/2011 12:16:02.522 Time Out: ...resetting micro timer
27/10/2011 12:16:02.524 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:30
27/10/2011 12:16:07.500 com.apple.launchd: (com.aladdin.hasplmd[7761]) Job appears to have crashed: Bus error: 10
27/10/2011 12:16:07.500 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:16:07.513 ReportCrash: Saved crash report for hasplmd[7761] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121607_localhost.crash
27/10/2011 12:16:17.516 Time Out: Idle 18446520444.3 secs; normal due 27/10/2011 13:08, micro due 27/10/2011 12:30
27/10/2011 12:16:17.518 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:16:17.518 Time Out: ...resetting normal timer
27/10/2011 12:16:17.520 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:08
27/10/2011 12:16:17.520 Time Out: ...resetting micro timer
27/10/2011 12:16:17.521 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:30
27/10/2011 12:16:17.688 com.apple.launchd: (com.aladdin.hasplmd[7762]) Job appears to have crashed: Bus error: 10
27/10/2011 12:16:17.688 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:16:17.705 ReportCrash: Saved crash report for hasplmd[7762] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121617_localhost.crash
27/10/2011 12:16:27.873 com.apple.launchd: (com.aladdin.hasplmd[7763]) Job appears to have crashed: Bus error: 10
27/10/2011 12:16:27.873 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:16:27.886 ReportCrash: Saved crash report for hasplmd[7763] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121627_localhost.crash
27/10/2011 12:16:32.517 Time Out: Idle 18446520459.3 secs; normal due 27/10/2011 13:08, micro due 27/10/2011 12:30
27/10/2011 12:16:32.519 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:16:32.520 Time Out: ...resetting normal timer
27/10/2011 12:16:32.522 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:08
27/10/2011 12:16:32.523 Time Out: ...resetting micro timer
27/10/2011 12:16:32.525 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:30
27/10/2011 12:16:37.906 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:16:38.075 com.apple.launchd: (com.aladdin.hasplmd[7764]) Job appears to have crashed: Bus error: 10
27/10/2011 12:16:38.075 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:16:38.125 ReportCrash: Saved crash report for hasplmd[7764] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121638_localhost.crash
27/10/2011 12:16:47.516 Time Out: Idle 18446520474.3 secs; normal due 27/10/2011 13:08, micro due 27/10/2011 12:30
27/10/2011 12:16:47.518 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:16:47.518 Time Out: ...resetting normal timer
27/10/2011 12:16:47.520 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:08
27/10/2011 12:16:47.520 Time Out: ...resetting micro timer
27/10/2011 12:16:47.521 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:30
27/10/2011 12:16:48.265 com.apple.launchd: (com.aladdin.hasplmd[7766]) Job appears to have crashed: Bus error: 10
27/10/2011 12:16:48.265 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:16:48.278 ReportCrash: Saved crash report for hasplmd[7766] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121648_localhost.crash
27/10/2011 12:16:58.455 com.apple.launchd: (com.aladdin.hasplmd[7767]) Job appears to have crashed: Bus error: 10
27/10/2011 12:16:58.455 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:16:58.468 ReportCrash: Saved crash report for hasplmd[7767] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121658_localhost.crash
27/10/2011 12:17:02.517 Time Out: Idle 18446520489.3 secs; normal due 27/10/2011 13:08, micro due 27/10/2011 12:30
27/10/2011 12:17:02.519 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:17:02.520 Time Out: ...resetting normal timer
27/10/2011 12:17:02.522 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:09
27/10/2011 12:17:02.523 Time Out: ...resetting micro timer
27/10/2011 12:17:02.525 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:31
27/10/2011 12:17:08.643 com.apple.launchd: (com.aladdin.hasplmd[7768]) Job appears to have crashed: Bus error: 10
27/10/2011 12:17:08.643 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:17:08.656 ReportCrash: Saved crash report for hasplmd[7768] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121708_localhost.crash
27/10/2011 12:17:17.517 Time Out: Idle 18446520504.3 secs; normal due 27/10/2011 13:09, micro due 27/10/2011 12:31
27/10/2011 12:17:17.519 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:17:17.520 Time Out: ...resetting normal timer
27/10/2011 12:17:17.522 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:09
27/10/2011 12:17:17.523 Time Out: ...resetting micro timer
27/10/2011 12:17:17.525 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:31
27/10/2011 12:17:18.831 com.apple.launchd: (com.aladdin.hasplmd[7769]) Job appears to have crashed: Bus error: 10
27/10/2011 12:17:18.832 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:17:18.844 ReportCrash: Saved crash report for hasplmd[7769] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121718_localhost.crash
27/10/2011 12:17:29.021 com.apple.launchd: (com.aladdin.hasplmd[7770]) Job appears to have crashed: Bus error: 10
27/10/2011 12:17:29.021 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:17:29.034 ReportCrash: Saved crash report for hasplmd[7770] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121729_localhost.crash
27/10/2011 12:17:32.518 Time Out: Idle 18446520519.3 secs; normal due 27/10/2011 13:09, micro due 27/10/2011 12:31
27/10/2011 12:17:32.520 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:17:32.521 Time Out: ...resetting normal timer
27/10/2011 12:17:32.523 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:09
27/10/2011 12:17:32.524 Time Out: ...resetting micro timer
27/10/2011 12:17:32.526 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:31
27/10/2011 12:17:39.054 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:17:39.225 com.apple.launchd: (com.aladdin.hasplmd[7771]) Job appears to have crashed: Bus error: 10
27/10/2011 12:17:39.225 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:17:39.275 ReportCrash: Saved crash report for hasplmd[7771] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121739_localhost.crash
27/10/2011 12:17:47.518 Time Out: Idle 18446520534.3 secs; normal due 27/10/2011 13:09, micro due 27/10/2011 12:31
27/10/2011 12:17:47.520 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:17:47.520 Time Out: ...resetting normal timer
27/10/2011 12:17:47.522 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:09
27/10/2011 12:17:47.523 Time Out: ...resetting micro timer
27/10/2011 12:17:47.525 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:31
27/10/2011 12:17:49.415 com.apple.launchd: (com.aladdin.hasplmd[7773]) Job appears to have crashed: Bus error: 10
27/10/2011 12:17:49.415 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:17:49.428 ReportCrash: Saved crash report for hasplmd[7773] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121749_localhost.crash
27/10/2011 12:17:59.601 com.apple.launchd: (com.aladdin.hasplmd[7774]) Job appears to have crashed: Bus error: 10
27/10/2011 12:17:59.601 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:17:59.615 ReportCrash: Saved crash report for hasplmd[7774] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121759_localhost.crash
27/10/2011 12:18:02.518 Time Out: Idle 18446520549.3 secs; normal due 27/10/2011 13:09, micro due 27/10/2011 12:31
27/10/2011 12:18:02.520 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:18:02.521 Time Out: ...resetting normal timer
27/10/2011 12:18:02.523 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:10
27/10/2011 12:18:02.524 Time Out: ...resetting micro timer
27/10/2011 12:18:02.526 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:32
27/10/2011 12:18:09.791 com.apple.launchd: (com.aladdin.hasplmd[7775]) Job appears to have crashed: Bus error: 10
27/10/2011 12:18:09.791 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:18:09.804 ReportCrash: Saved crash report for hasplmd[7775] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121809_localhost.crash
27/10/2011 12:18:17.518 Time Out: Idle 18446520564.3 secs; normal due 27/10/2011 13:10, micro due 27/10/2011 12:32
27/10/2011 12:18:17.520 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:18:17.521 Time Out: ...resetting normal timer
27/10/2011 12:18:17.523 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:10
27/10/2011 12:18:17.524 Time Out: ...resetting micro timer
27/10/2011 12:18:17.526 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:32
27/10/2011 12:18:19.981 com.apple.launchd: (com.aladdin.hasplmd[7776]) Job appears to have crashed: Bus error: 10
27/10/2011 12:18:19.981 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:18:19.994 ReportCrash: Saved crash report for hasplmd[7776] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121819_localhost.crash
27/10/2011 12:18:30.230 com.apple.launchd: (com.aladdin.hasplmd[7777]) Job appears to have crashed: Bus error: 10
27/10/2011 12:18:30.230 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:18:30.259 ReportCrash: Saved crash report for hasplmd[7777] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121830_localhost.crash
27/10/2011 12:18:32.518 Time Out: Idle 18446520579.3 secs; normal due 27/10/2011 13:10, micro due 27/10/2011 12:32
27/10/2011 12:18:32.520 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:18:32.521 Time Out: ...resetting normal timer
27/10/2011 12:18:32.523 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:10
27/10/2011 12:18:32.524 Time Out: ...resetting micro timer
27/10/2011 12:18:32.525 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:32
27/10/2011 12:18:40.263 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:18:40.430 com.apple.launchd: (com.aladdin.hasplmd[7779]) Job appears to have crashed: Bus error: 10
27/10/2011 12:18:40.430 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:18:40.480 ReportCrash: Saved crash report for hasplmd[7779] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121840_localhost.crash
27/10/2011 12:18:47.518 Time Out: Idle 18446520594.3 secs; normal due 27/10/2011 13:10, micro due 27/10/2011 12:32
27/10/2011 12:18:47.521 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:18:47.521 Time Out: ...resetting normal timer
27/10/2011 12:18:47.524 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:10
27/10/2011 12:18:47.524 Time Out: ...resetting micro timer
27/10/2011 12:18:47.526 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:32
27/10/2011 12:18:50.620 com.apple.launchd: (com.aladdin.hasplmd[7781]) Job appears to have crashed: Bus error: 10
27/10/2011 12:18:50.620 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:18:50.639 ReportCrash: Saved crash report for hasplmd[7781] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121850_localhost.crash
27/10/2011 12:19:00.808 com.apple.launchd: (com.aladdin.hasplmd[7782]) Job appears to have crashed: Bus error: 10
27/10/2011 12:19:00.808 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:19:00.821 ReportCrash: Saved crash report for hasplmd[7782] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121900_localhost.crash
27/10/2011 12:19:02.518 Time Out: Idle 18446520609.3 secs; normal due 27/10/2011 13:10, micro due 27/10/2011 12:32
27/10/2011 12:19:02.521 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:19:02.521 Time Out: ...resetting normal timer
27/10/2011 12:19:02.524 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:11
27/10/2011 12:19:02.524 Time Out: ...resetting micro timer
27/10/2011 12:19:02.526 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:33
27/10/2011 12:19:10.998 com.apple.launchd: (com.aladdin.hasplmd[7783]) Job appears to have crashed: Bus error: 10
27/10/2011 12:19:10.998 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:19:11.012 ReportCrash: Saved crash report for hasplmd[7783] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121911_localhost.crash
27/10/2011 12:19:17.519 Time Out: Idle 18446520624.3 secs; normal due 27/10/2011 13:11, micro due 27/10/2011 12:33
27/10/2011 12:19:17.521 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:19:17.522 Time Out: ...resetting normal timer
27/10/2011 12:19:17.524 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:11
27/10/2011 12:19:17.525 Time Out: ...resetting micro timer
27/10/2011 12:19:17.527 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:33
27/10/2011 12:19:21.187 com.apple.launchd: (com.aladdin.hasplmd[7784]) Job appears to have crashed: Bus error: 10
27/10/2011 12:19:21.187 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:19:21.200 ReportCrash: Saved crash report for hasplmd[7784] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121921_localhost.crash
27/10/2011 12:19:31.375 com.apple.launchd: (com.aladdin.hasplmd[7785]) Job appears to have crashed: Bus error: 10
27/10/2011 12:19:31.375 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:19:31.391 ReportCrash: Saved crash report for hasplmd[7785] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121931_localhost.crash
27/10/2011 12:19:32.518 Time Out: Idle 18446520639.3 secs; normal due 27/10/2011 13:11, micro due 27/10/2011 12:33
27/10/2011 12:19:32.520 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:19:32.521 Time Out: ...resetting normal timer
27/10/2011 12:19:32.523 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:11
27/10/2011 12:19:32.524 Time Out: ...resetting micro timer
27/10/2011 12:19:32.526 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:33
27/10/2011 12:19:41.408 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:19:41.579 com.apple.launchd: (com.aladdin.hasplmd[7786]) Job appears to have crashed: Bus error: 10
27/10/2011 12:19:41.579 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:19:41.627 ReportCrash: Saved crash report for hasplmd[7786] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121941_localhost.crash
27/10/2011 12:19:47.519 Time Out: Idle 18446520654.3 secs; normal due 27/10/2011 13:11, micro due 27/10/2011 12:33
27/10/2011 12:19:47.521 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:19:47.522 Time Out: ...resetting normal timer
27/10/2011 12:19:47.524 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:11
27/10/2011 12:19:47.525 Time Out: ...resetting micro timer
27/10/2011 12:19:47.527 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:33
27/10/2011 12:19:51.766 com.apple.launchd: (com.aladdin.hasplmd[7788]) Job appears to have crashed: Bus error: 10
27/10/2011 12:19:51.766 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:19:51.783 ReportCrash: Saved crash report for hasplmd[7788] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-121951_localhost.crash
27/10/2011 12:20:01.960 com.apple.launchd: (com.aladdin.hasplmd[7789]) Job appears to have crashed: Bus error: 10
27/10/2011 12:20:01.960 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:20:01.978 ReportCrash: Saved crash report for hasplmd[7789] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122001_localhost.crash
27/10/2011 12:20:02.519 Time Out: Idle 18446520669.3 secs; normal due 27/10/2011 13:11, micro due 27/10/2011 12:33
27/10/2011 12:20:02.522 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:20:02.522 Time Out: ...resetting normal timer
27/10/2011 12:20:02.524 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:12
27/10/2011 12:20:02.526 Time Out: ...resetting micro timer
27/10/2011 12:20:02.527 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:34
27/10/2011 12:20:12.149 com.apple.launchd: (com.aladdin.hasplmd[7790]) Job appears to have crashed: Bus error: 10
27/10/2011 12:20:12.149 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:20:12.162 ReportCrash: Saved crash report for hasplmd[7790] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122012_localhost.crash
27/10/2011 12:20:17.519 Time Out: Idle 18446520684.3 secs; normal due 27/10/2011 13:12, micro due 27/10/2011 12:34
27/10/2011 12:20:17.522 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:20:17.522 Time Out: ...resetting normal timer
27/10/2011 12:20:17.524 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:12
27/10/2011 12:20:17.525 Time Out: ...resetting micro timer
27/10/2011 12:20:17.527 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:34
27/10/2011 12:20:22.338 com.apple.launchd: (com.aladdin.hasplmd[7791]) Job appears to have crashed: Bus error: 10
27/10/2011 12:20:22.338 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:20:22.356 ReportCrash: Saved crash report for hasplmd[7791] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122022_localhost.crash
27/10/2011 12:20:32.518 Time Out: Idle 18446520699.3 secs; normal due 27/10/2011 13:12, micro due 27/10/2011 12:34
27/10/2011 12:20:32.519 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:20:32.520 Time Out: ...resetting normal timer
27/10/2011 12:20:32.521 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:12
27/10/2011 12:20:32.522 Time Out: ...resetting micro timer
27/10/2011 12:20:32.523 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:34
27/10/2011 12:20:32.532 com.apple.launchd: (com.aladdin.hasplmd[7792]) Job appears to have crashed: Bus error: 10
27/10/2011 12:20:32.532 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:20:32.545 ReportCrash: Saved crash report for hasplmd[7792] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122032_localhost.crash
27/10/2011 12:20:42.564 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:20:42.749 com.apple.launchd: (com.aladdin.hasplmd[7793]) Job appears to have crashed: Bus error: 10
27/10/2011 12:20:42.749 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:20:42.799 ReportCrash: Saved crash report for hasplmd[7793] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122042_localhost.crash
27/10/2011 12:20:47.520 Time Out: Idle 18446520714.3 secs; normal due 27/10/2011 13:12, micro due 27/10/2011 12:34
27/10/2011 12:20:47.522 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:20:47.523 Time Out: ...resetting normal timer
27/10/2011 12:20:47.525 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:12
27/10/2011 12:20:47.525 Time Out: ...resetting micro timer
27/10/2011 12:20:47.527 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:34
27/10/2011 12:20:52.943 com.apple.launchd: (com.aladdin.hasplmd[7795]) Job appears to have crashed: Bus error: 10
27/10/2011 12:20:52.943 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:20:52.956 ReportCrash: Saved crash report for hasplmd[7795] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122052_localhost.crash
27/10/2011 12:21:02.520 Time Out: Idle 18446520729.3 secs; normal due 27/10/2011 13:12, micro due 27/10/2011 12:34
27/10/2011 12:21:02.522 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:21:02.523 Time Out: ...resetting normal timer
27/10/2011 12:21:02.525 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:13
27/10/2011 12:21:02.526 Time Out: ...resetting micro timer
27/10/2011 12:21:02.527 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:35
27/10/2011 12:21:03.129 com.apple.launchd: (com.aladdin.hasplmd[7796]) Job appears to have crashed: Bus error: 10
27/10/2011 12:21:03.129 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:21:03.142 ReportCrash: Saved crash report for hasplmd[7796] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122103_localhost.crash
27/10/2011 12:21:13.318 com.apple.launchd: (com.aladdin.hasplmd[7797]) Job appears to have crashed: Bus error: 10
27/10/2011 12:21:13.318 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:21:13.331 ReportCrash: Saved crash report for hasplmd[7797] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122113_localhost.crash
27/10/2011 12:21:17.520 Time Out: Idle 18446520744.3 secs; normal due 27/10/2011 13:13, micro due 27/10/2011 12:35
27/10/2011 12:21:17.522 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:21:17.523 Time Out: ...resetting normal timer
27/10/2011 12:21:17.525 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:13
27/10/2011 12:21:17.526 Time Out: ...resetting micro timer
27/10/2011 12:21:17.528 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:35
27/10/2011 12:21:23.507 com.apple.launchd: (com.aladdin.hasplmd[7798]) Job appears to have crashed: Bus error: 10
27/10/2011 12:21:23.507 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:21:23.524 ReportCrash: Saved crash report for hasplmd[7798] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122123_localhost.crash
27/10/2011 12:21:32.520 Time Out: Idle 18446520759.3 secs; normal due 27/10/2011 13:13, micro due 27/10/2011 12:35
27/10/2011 12:21:32.523 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:21:32.523 Time Out: ...resetting normal timer
27/10/2011 12:21:32.526 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:13
27/10/2011 12:21:32.526 Time Out: ...resetting micro timer
27/10/2011 12:21:32.528 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:35
27/10/2011 12:21:33.694 com.apple.launchd: (com.aladdin.hasplmd[7799]) Job appears to have crashed: Bus error: 10
27/10/2011 12:21:33.694 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:21:33.708 ReportCrash: Saved crash report for hasplmd[7799] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122133_localhost.crash
27/10/2011 12:21:43.726 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:21:43.898 com.apple.launchd: (com.aladdin.hasplmd[7800]) Job appears to have crashed: Bus error: 10
27/10/2011 12:21:43.898 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:21:43.947 ReportCrash: Saved crash report for hasplmd[7800] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122143_localhost.crash
27/10/2011 12:21:47.520 Time Out: Idle 18446520774.3 secs; normal due 27/10/2011 13:13, micro due 27/10/2011 12:35
27/10/2011 12:21:47.522 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:21:47.523 Time Out: ...resetting normal timer
27/10/2011 12:21:47.525 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:13
27/10/2011 12:21:47.526 Time Out: ...resetting micro timer
27/10/2011 12:21:47.528 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:35
27/10/2011 12:21:54.088 com.apple.launchd: (com.aladdin.hasplmd[7802]) Job appears to have crashed: Bus error: 10
27/10/2011 12:21:54.088 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:21:54.101 ReportCrash: Saved crash report for hasplmd[7802] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122154_localhost.crash
27/10/2011 12:22:02.519 Time Out: Idle 18446520789.3 secs; normal due 27/10/2011 13:13, micro due 27/10/2011 12:35
27/10/2011 12:22:02.520 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:22:02.521 Time Out: ...resetting normal timer
27/10/2011 12:22:02.523 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:14
27/10/2011 12:22:02.523 Time Out: ...resetting micro timer
27/10/2011 12:22:02.525 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:36
27/10/2011 12:22:04.291 com.apple.launchd: (com.aladdin.hasplmd[7803]) Job appears to have crashed: Bus error: 10
27/10/2011 12:22:04.291 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:22:04.307 ReportCrash: Saved crash report for hasplmd[7803] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122204_localhost.crash
27/10/2011 12:22:14.479 com.apple.launchd: (com.aladdin.hasplmd[7804]) Job appears to have crashed: Bus error: 10
27/10/2011 12:22:14.479 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:22:14.492 ReportCrash: Saved crash report for hasplmd[7804] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122214_localhost.crash
27/10/2011 12:22:17.521 Time Out: Idle 18446520804.3 secs; normal due 27/10/2011 13:14, micro due 27/10/2011 12:36
27/10/2011 12:22:17.523 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:22:17.523 Time Out: ...resetting normal timer
27/10/2011 12:22:17.526 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:14
27/10/2011 12:22:17.526 Time Out: ...resetting micro timer
27/10/2011 12:22:17.528 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:36
27/10/2011 12:22:24.677 com.apple.launchd: (com.aladdin.hasplmd[7805]) Job appears to have crashed: Bus error: 10
27/10/2011 12:22:24.677 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:22:24.692 ReportCrash: Saved crash report for hasplmd[7805] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122224_localhost.crash
27/10/2011 12:22:32.521 Time Out: Idle 18446520819.3 secs; normal due 27/10/2011 13:14, micro due 27/10/2011 12:36
27/10/2011 12:22:32.523 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:22:32.524 Time Out: ...resetting normal timer
27/10/2011 12:22:32.526 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:14
27/10/2011 12:22:32.527 Time Out: ...resetting micro timer
27/10/2011 12:22:32.528 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:36
27/10/2011 12:22:34.862 com.apple.launchd: (com.aladdin.hasplmd[7806]) Job appears to have crashed: Bus error: 10
27/10/2011 12:22:34.862 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:22:34.880 ReportCrash: Saved crash report for hasplmd[7806] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122234_localhost.crash
27/10/2011 12:22:44.895 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:22:45.066 com.apple.launchd: (com.aladdin.hasplmd[7807]) Job appears to have crashed: Bus error: 10
27/10/2011 12:22:45.066 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:22:45.117 ReportCrash: Saved crash report for hasplmd[7807] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122245_localhost.crash
27/10/2011 12:22:47.521 Time Out: Idle 18446520834.3 secs; normal due 27/10/2011 13:14, micro due 27/10/2011 12:36
27/10/2011 12:22:47.523 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:22:47.524 Time Out: ...resetting normal timer
27/10/2011 12:22:47.526 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:14
27/10/2011 12:22:47.527 Time Out: ...resetting micro timer
27/10/2011 12:22:47.529 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:36
27/10/2011 12:22:55.255 com.apple.launchd: (com.aladdin.hasplmd[7809]) Job appears to have crashed: Bus error: 10
27/10/2011 12:22:55.255 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:22:55.268 ReportCrash: Saved crash report for hasplmd[7809] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122255_localhost.crash
27/10/2011 12:23:02.519 Time Out: Idle 18446520849.3 secs; normal due 27/10/2011 13:14, micro due 27/10/2011 12:36
27/10/2011 12:23:02.521 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:23:02.521 Time Out: ...resetting normal timer
27/10/2011 12:23:02.523 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:15
27/10/2011 12:23:02.523 Time Out: ...resetting micro timer
27/10/2011 12:23:02.525 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:37
27/10/2011 12:23:05.445 com.apple.launchd: (com.aladdin.hasplmd[7810]) Job appears to have crashed: Bus error: 10
27/10/2011 12:23:05.445 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:23:05.458 ReportCrash: Saved crash report for hasplmd[7810] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122305_localhost.crash
27/10/2011 12:23:15.635 com.apple.launchd: (com.aladdin.hasplmd[7811]) Job appears to have crashed: Bus error: 10
27/10/2011 12:23:15.635 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:23:15.648 ReportCrash: Saved crash report for hasplmd[7811] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122315_localhost.crash
27/10/2011 12:23:17.521 Time Out: Idle 18446520864.3 secs; normal due 27/10/2011 13:15, micro due 27/10/2011 12:37
27/10/2011 12:23:17.523 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:23:17.524 Time Out: ...resetting normal timer
27/10/2011 12:23:17.526 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:15
27/10/2011 12:23:17.527 Time Out: ...resetting micro timer
27/10/2011 12:23:17.529 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:37
27/10/2011 12:23:25.825 com.apple.launchd: (com.aladdin.hasplmd[7812]) Job appears to have crashed: Bus error: 10
27/10/2011 12:23:25.825 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:23:25.838 ReportCrash: Saved crash report for hasplmd[7812] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122325_localhost.crash
27/10/2011 12:23:32.522 Time Out: Idle 18446520879.3 secs; normal due 27/10/2011 13:15, micro due 27/10/2011 12:37
27/10/2011 12:23:32.523 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:23:32.524 Time Out: ...resetting normal timer
27/10/2011 12:23:32.526 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:15
27/10/2011 12:23:32.527 Time Out: ...resetting micro timer
27/10/2011 12:23:32.529 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:37
27/10/2011 12:23:36.014 com.apple.launchd: (com.aladdin.hasplmd[7813]) Job appears to have crashed: Bus error: 10
27/10/2011 12:23:36.014 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:23:36.027 ReportCrash: Saved crash report for hasplmd[7813] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122336_localhost.crash
27/10/2011 12:23:46.046 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:23:46.216 com.apple.launchd: (com.aladdin.hasplmd[7814]) Job appears to have crashed: Bus error: 10
27/10/2011 12:23:46.216 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:23:46.265 ReportCrash: Saved crash report for hasplmd[7814] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122346_localhost.crash
27/10/2011 12:23:47.522 Time Out: Idle 18446520894.3 secs; normal due 27/10/2011 13:15, micro due 27/10/2011 12:37
27/10/2011 12:23:47.524 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:23:47.525 Time Out: ...resetting normal timer
27/10/2011 12:23:47.527 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:15
27/10/2011 12:23:47.528 Time Out: ...resetting micro timer
27/10/2011 12:23:47.530 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:37
27/10/2011 12:23:56.406 com.apple.launchd: (com.aladdin.hasplmd[7816]) Job appears to have crashed: Bus error: 10
27/10/2011 12:23:56.406 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:23:56.419 ReportCrash: Saved crash report for hasplmd[7816] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122356_localhost.crash
27/10/2011 12:24:02.522 Time Out: Idle 18446520909.3 secs; normal due 27/10/2011 13:15, micro due 27/10/2011 12:37
27/10/2011 12:24:02.524 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:24:02.525 Time Out: ...resetting normal timer
27/10/2011 12:24:02.527 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:16
27/10/2011 12:24:02.528 Time Out: ...resetting micro timer
27/10/2011 12:24:02.530 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:38
27/10/2011 12:24:06.601 com.apple.launchd: (com.aladdin.hasplmd[7825]) Job appears to have crashed: Bus error: 10
27/10/2011 12:24:06.601 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:24:06.614 ReportCrash: Saved crash report for hasplmd[7825] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122406_localhost.crash
27/10/2011 12:24:16.788 com.apple.launchd: (com.aladdin.hasplmd[7826]) Job appears to have crashed: Bus error: 10
27/10/2011 12:24:16.788 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:24:16.801 ReportCrash: Saved crash report for hasplmd[7826] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122416_localhost.crash
27/10/2011 12:24:17.522 Time Out: Idle 18446520924.3 secs; normal due 27/10/2011 13:16, micro due 27/10/2011 12:38
27/10/2011 12:24:17.524 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:24:17.525 Time Out: ...resetting normal timer
27/10/2011 12:24:17.527 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:16
27/10/2011 12:24:17.528 Time Out: ...resetting micro timer
27/10/2011 12:24:17.530 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:38
27/10/2011 12:24:26.977 com.apple.launchd: (com.aladdin.hasplmd[7827]) Job appears to have crashed: Bus error: 10
27/10/2011 12:24:26.977 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:24:26.990 ReportCrash: Saved crash report for hasplmd[7827] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122426_localhost.crash
27/10/2011 12:24:32.522 Time Out: Idle 18446520939.3 secs; normal due 27/10/2011 13:16, micro due 27/10/2011 12:38
27/10/2011 12:24:32.524 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:24:32.525 Time Out: ...resetting normal timer
27/10/2011 12:24:32.527 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:16
27/10/2011 12:24:32.528 Time Out: ...resetting micro timer
27/10/2011 12:24:32.529 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:38
27/10/2011 12:24:37.164 com.apple.launchd: (com.aladdin.hasplmd[7828]) Job appears to have crashed: Bus error: 10
27/10/2011 12:24:37.164 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:24:37.177 ReportCrash: Saved crash report for hasplmd[7828] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122437_localhost.crash
27/10/2011 12:24:47.197 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:24:47.368 com.apple.launchd: (com.aladdin.hasplmd[7829]) Job appears to have crashed: Bus error: 10
27/10/2011 12:24:47.368 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:24:47.416 ReportCrash: Saved crash report for hasplmd[7829] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122447_localhost.crash
27/10/2011 12:24:47.522 Time Out: Idle 18446520954.3 secs; normal due 27/10/2011 13:16, micro due 27/10/2011 12:38
27/10/2011 12:24:47.525 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:24:47.525 Time Out: ...resetting normal timer
27/10/2011 12:24:47.527 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:16
27/10/2011 12:24:47.528 Time Out: ...resetting micro timer
27/10/2011 12:24:47.530 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:38
27/10/2011 12:24:57.559 com.apple.launchd: (com.aladdin.hasplmd[7831]) Job appears to have crashed: Bus error: 10
27/10/2011 12:24:57.559 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:24:57.572 ReportCrash: Saved crash report for hasplmd[7831] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122457_localhost.crash
27/10/2011 12:25:02.523 Time Out: Idle 18446520969.3 secs; normal due 27/10/2011 13:16, micro due 27/10/2011 12:38
27/10/2011 12:25:02.524 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:25:02.525 Time Out: ...resetting normal timer
27/10/2011 12:25:02.527 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:17
27/10/2011 12:25:02.528 Time Out: ...resetting micro timer
27/10/2011 12:25:02.530 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:39
27/10/2011 12:25:07.746 com.apple.launchd: (com.aladdin.hasplmd[7832]) Job appears to have crashed: Bus error: 10
27/10/2011 12:25:07.746 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:25:07.760 ReportCrash: Saved crash report for hasplmd[7832] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122507_localhost.crash
27/10/2011 12:25:17.523 Time Out: Idle 18446520984.3 secs; normal due 27/10/2011 13:17, micro due 27/10/2011 12:39
27/10/2011 12:25:17.525 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:25:17.526 Time Out: ...resetting normal timer
27/10/2011 12:25:17.528 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:17
27/10/2011 12:25:17.529 Time Out: ...resetting micro timer
27/10/2011 12:25:17.530 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:39
27/10/2011 12:25:17.935 com.apple.launchd: (com.aladdin.hasplmd[7833]) Job appears to have crashed: Bus error: 10
27/10/2011 12:25:17.935 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:25:17.948 ReportCrash: Saved crash report for hasplmd[7833] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122517_localhost.crash
27/10/2011 12:25:28.123 com.apple.launchd: (com.aladdin.hasplmd[7834]) Job appears to have crashed: Bus error: 10
27/10/2011 12:25:28.123 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:25:28.136 ReportCrash: Saved crash report for hasplmd[7834] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122528_localhost.crash
27/10/2011 12:25:32.523 Time Out: Idle 18446520999.3 secs; normal due 27/10/2011 13:17, micro due 27/10/2011 12:39
27/10/2011 12:25:32.525 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:25:32.526 Time Out: ...resetting normal timer
27/10/2011 12:25:32.528 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:17
27/10/2011 12:25:32.529 Time Out: ...resetting micro timer
27/10/2011 12:25:32.530 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:39
27/10/2011 12:25:38.312 com.apple.launchd: (com.aladdin.hasplmd[7835]) Job appears to have crashed: Bus error: 10
27/10/2011 12:25:38.312 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:25:38.325 ReportCrash: Saved crash report for hasplmd[7835] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122538_localhost.crash
27/10/2011 12:25:47.523 Time Out: Idle 18446521014.3 secs; normal due 27/10/2011 13:17, micro due 27/10/2011 12:39
27/10/2011 12:25:47.525 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:25:47.526 Time Out: ...resetting normal timer
27/10/2011 12:25:47.528 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:17
27/10/2011 12:25:47.528 Time Out: ...resetting micro timer
27/10/2011 12:25:47.530 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:39
27/10/2011 12:25:48.344 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:25:48.515 com.apple.launchd: (com.aladdin.hasplmd[7836]) Job appears to have crashed: Bus error: 10
27/10/2011 12:25:48.515 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:25:48.562 ReportCrash: Saved crash report for hasplmd[7836] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122548_localhost.crash
27/10/2011 12:25:58.704 com.apple.launchd: (com.aladdin.hasplmd[7838]) Job appears to have crashed: Bus error: 10
27/10/2011 12:25:58.704 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:25:58.722 ReportCrash: Saved crash report for hasplmd[7838] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122558_localhost.crash
27/10/2011 12:26:02.523 Time Out: Idle 18446521029.3 secs; normal due 27/10/2011 13:17, micro due 27/10/2011 12:39
27/10/2011 12:26:02.525 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:26:02.526 Time Out: ...resetting normal timer
27/10/2011 12:26:02.528 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:18
27/10/2011 12:26:02.529 Time Out: ...resetting micro timer
27/10/2011 12:26:02.530 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:40
27/10/2011 12:26:08.888 com.apple.launchd: (com.aladdin.hasplmd[7839]) Job appears to have crashed: Bus error: 10
27/10/2011 12:26:08.888 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:26:08.901 ReportCrash: Saved crash report for hasplmd[7839] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122608_localhost.crash
27/10/2011 12:26:17.523 Time Out: Idle 18446521044.3 secs; normal due 27/10/2011 13:18, micro due 27/10/2011 12:40
27/10/2011 12:26:17.526 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:26:17.526 Time Out: ...resetting normal timer
27/10/2011 12:26:17.528 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:18
27/10/2011 12:26:17.529 Time Out: ...resetting micro timer
27/10/2011 12:26:17.531 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:40
27/10/2011 12:26:19.077 com.apple.launchd: (com.aladdin.hasplmd[7840]) Job appears to have crashed: Bus error: 10
27/10/2011 12:26:19.077 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:26:19.094 ReportCrash: Saved crash report for hasplmd[7840] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122619_localhost.crash
27/10/2011 12:26:29.265 com.apple.launchd: (com.aladdin.hasplmd[7841]) Job appears to have crashed: Bus error: 10
27/10/2011 12:26:29.265 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:26:29.278 ReportCrash: Saved crash report for hasplmd[7841] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122629_localhost.crash
27/10/2011 12:26:32.523 Time Out: Idle 18446521059.3 secs; normal due 27/10/2011 13:18, micro due 27/10/2011 12:40
27/10/2011 12:26:32.526 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:26:32.526 Time Out: ...resetting normal timer
27/10/2011 12:26:32.529 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:18
27/10/2011 12:26:32.529 Time Out: ...resetting micro timer
27/10/2011 12:26:32.532 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:40
27/10/2011 12:26:39.455 com.apple.launchd: (com.aladdin.hasplmd[7842]) Job appears to have crashed: Bus error: 10
27/10/2011 12:26:39.455 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:26:39.468 ReportCrash: Saved crash report for hasplmd[7842] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122639_localhost.crash
27/10/2011 12:26:47.523 Time Out: Idle 18446521074.3 secs; normal due 27/10/2011 13:18, micro due 27/10/2011 12:40
27/10/2011 12:26:47.525 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:26:47.526 Time Out: ...resetting normal timer
27/10/2011 12:26:47.528 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:18
27/10/2011 12:26:47.529 Time Out: ...resetting micro timer
27/10/2011 12:26:47.531 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:40
27/10/2011 12:26:49.488 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:26:49.658 com.apple.launchd: (com.aladdin.hasplmd[7843]) Job appears to have crashed: Bus error: 10
27/10/2011 12:26:49.658 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:26:49.706 ReportCrash: Saved crash report for hasplmd[7843] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122649_localhost.crash
27/10/2011 12:26:56.848 _softwareupdate: audit warning: allsoft
27/10/2011 12:26:56.849 _softwareupdate: audit warning: closefile /var/audit/20111027102214.20111027112656
27/10/2011 12:26:56.849 _softwareupdate: audit warning: soft /var/audit
27/10/2011 12:26:59.848 com.apple.launchd: (com.aladdin.hasplmd[7855]) Job appears to have crashed: Bus error: 10
27/10/2011 12:26:59.848 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:26:59.861 ReportCrash: Saved crash report for hasplmd[7855] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122659_localhost.crash
27/10/2011 12:27:02.524 Time Out: Idle 18446521089.3 secs; normal due 27/10/2011 13:18, micro due 27/10/2011 12:40
27/10/2011 12:27:02.526 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:27:02.527 Time Out: ...resetting normal timer
27/10/2011 12:27:02.529 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:19
27/10/2011 12:27:02.529 Time Out: ...resetting micro timer
27/10/2011 12:27:02.531 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:41
27/10/2011 12:27:10.065 com.apple.launchd: (com.aladdin.hasplmd[7856]) Job appears to have crashed: Bus error: 10
27/10/2011 12:27:10.065 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:27:10.082 ReportCrash: Saved crash report for hasplmd[7856] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122710_localhost.crash
27/10/2011 12:27:17.524 Time Out: Idle 18446521104.3 secs; normal due 27/10/2011 13:19, micro due 27/10/2011 12:41
27/10/2011 12:27:17.526 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:27:17.527 Time Out: ...resetting normal timer
27/10/2011 12:27:17.529 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:19
27/10/2011 12:27:17.530 Time Out: ...resetting micro timer
27/10/2011 12:27:17.531 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:41
27/10/2011 12:27:20.251 com.apple.launchd: (com.aladdin.hasplmd[7857]) Job appears to have crashed: Bus error: 10
27/10/2011 12:27:20.251 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:27:20.264 ReportCrash: Saved crash report for hasplmd[7857] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122720_localhost.crash
27/10/2011 12:27:30.443 com.apple.launchd: (com.aladdin.hasplmd[7858]) Job appears to have crashed: Bus error: 10
27/10/2011 12:27:30.443 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:27:30.458 ReportCrash: Saved crash report for hasplmd[7858] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122730_localhost.crash
27/10/2011 12:27:32.523 Time Out: Idle 18446521119.3 secs; normal due 27/10/2011 13:19, micro due 27/10/2011 12:41
27/10/2011 12:27:32.524 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:27:32.524 Time Out: ...resetting normal timer
27/10/2011 12:27:32.525 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:19
27/10/2011 12:27:32.526 Time Out: ...resetting micro timer
27/10/2011 12:27:32.527 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:41
27/10/2011 12:27:40.635 com.apple.launchd: (com.aladdin.hasplmd[7859]) Job appears to have crashed: Bus error: 10
27/10/2011 12:27:40.635 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:27:40.647 ReportCrash: Saved crash report for hasplmd[7859] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122740_localhost.crash
27/10/2011 12:27:47.524 Time Out: Idle 18446521134.3 secs; normal due 27/10/2011 13:19, micro due 27/10/2011 12:41
27/10/2011 12:27:47.527 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:27:47.527 Time Out: ...resetting normal timer
27/10/2011 12:27:47.529 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:19
27/10/2011 12:27:47.530 Time Out: ...resetting micro timer
27/10/2011 12:27:47.532 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:41
27/10/2011 12:27:50.667 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:27:50.838 com.apple.launchd: (com.aladdin.hasplmd[7860]) Job appears to have crashed: Bus error: 10
27/10/2011 12:27:50.838 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:27:50.885 ReportCrash: Saved crash report for hasplmd[7860] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122750_localhost.crash
27/10/2011 12:28:01.055 com.apple.launchd: (com.aladdin.hasplmd[7862]) Job appears to have crashed: Bus error: 10
27/10/2011 12:28:01.055 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:28:01.072 ReportCrash: Saved crash report for hasplmd[7862] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122801_localhost.crash
27/10/2011 12:28:02.524 Time Out: Idle 18446521149.3 secs; normal due 27/10/2011 13:19, micro due 27/10/2011 12:41
27/10/2011 12:28:02.526 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:28:02.527 Time Out: ...resetting normal timer
27/10/2011 12:28:02.529 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:20
27/10/2011 12:28:02.529 Time Out: ...resetting micro timer
27/10/2011 12:28:02.530 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:42
27/10/2011 12:28:11.245 com.apple.launchd: (com.aladdin.hasplmd[7863]) Job appears to have crashed: Bus error: 10
27/10/2011 12:28:11.245 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:28:11.258 ReportCrash: Saved crash report for hasplmd[7863] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122811_localhost.crash
27/10/2011 12:28:17.525 Time Out: Idle 18446521164.3 secs; normal due 27/10/2011 13:20, micro due 27/10/2011 12:42
27/10/2011 12:28:17.527 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:28:17.528 Time Out: ...resetting normal timer
27/10/2011 12:28:17.530 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:20
27/10/2011 12:28:17.531 Time Out: ...resetting micro timer
27/10/2011 12:28:17.533 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:42
27/10/2011 12:28:21.434 com.apple.launchd: (com.aladdin.hasplmd[7864]) Job appears to have crashed: Bus error: 10
27/10/2011 12:28:21.434 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:28:21.452 ReportCrash: Saved crash report for hasplmd[7864] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122821_localhost.crash
27/10/2011 12:28:31.659 com.apple.launchd: (com.aladdin.hasplmd[7865]) Job appears to have crashed: Bus error: 10
27/10/2011 12:28:31.659 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:28:31.677 ReportCrash: Saved crash report for hasplmd[7865] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122831_localhost.crash
27/10/2011 12:28:32.525 Time Out: Idle 18446521179.3 secs; normal due 27/10/2011 13:20, micro due 27/10/2011 12:42
27/10/2011 12:28:32.527 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:28:32.528 Time Out: ...resetting normal timer
27/10/2011 12:28:32.530 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:20
27/10/2011 12:28:32.530 Time Out: ...resetting micro timer
27/10/2011 12:28:32.532 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:42
27/10/2011 12:28:41.848 com.apple.launchd: (com.aladdin.hasplmd[7866]) Job appears to have crashed: Bus error: 10
27/10/2011 12:28:41.848 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:28:41.861 ReportCrash: Saved crash report for hasplmd[7866] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122841_localhost.crash
27/10/2011 12:28:47.525 Time Out: Idle 18446521194.3 secs; normal due 27/10/2011 13:20, micro due 27/10/2011 12:42
27/10/2011 12:28:47.527 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:28:47.528 Time Out: ...resetting normal timer
27/10/2011 12:28:47.530 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:20
27/10/2011 12:28:47.531 Time Out: ...resetting micro timer
27/10/2011 12:28:47.532 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:42
27/10/2011 12:28:51.881 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:28:52.050 com.apple.launchd: (com.aladdin.hasplmd[7867]) Job appears to have crashed: Bus error: 10
27/10/2011 12:28:52.050 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:28:52.100 ReportCrash: Saved crash report for hasplmd[7867] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122852_localhost.crash
27/10/2011 12:29:02.239 com.apple.launchd: (com.aladdin.hasplmd[7869]) Job appears to have crashed: Bus error: 10
27/10/2011 12:29:02.239 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:29:02.252 ReportCrash: Saved crash report for hasplmd[7869] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122902_localhost.crash
27/10/2011 12:29:02.525 Time Out: Idle 18446521209.3 secs; normal due 27/10/2011 13:20, micro due 27/10/2011 12:42
27/10/2011 12:29:02.527 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:29:02.528 Time Out: ...resetting normal timer
27/10/2011 12:29:02.530 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:21
27/10/2011 12:29:02.531 Time Out: ...resetting micro timer
27/10/2011 12:29:02.533 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:43
27/10/2011 12:29:12.427 com.apple.launchd: (com.aladdin.hasplmd[7870]) Job appears to have crashed: Bus error: 10
27/10/2011 12:29:12.427 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:29:12.440 ReportCrash: Saved crash report for hasplmd[7870] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122912_localhost.crash
27/10/2011 12:29:17.525 Time Out: Idle 18446521224.3 secs; normal due 27/10/2011 13:21, micro due 27/10/2011 12:43
27/10/2011 12:29:17.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:29:17.528 Time Out: ...resetting normal timer
27/10/2011 12:29:17.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:21
27/10/2011 12:29:17.531 Time Out: ...resetting micro timer
27/10/2011 12:29:17.533 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:43
27/10/2011 12:29:22.615 com.apple.launchd: (com.aladdin.hasplmd[7871]) Job appears to have crashed: Bus error: 10
27/10/2011 12:29:22.615 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:29:22.633 ReportCrash: Saved crash report for hasplmd[7871] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122922_localhost.crash
27/10/2011 12:29:32.525 Time Out: Idle 18446521239.3 secs; normal due 27/10/2011 13:21, micro due 27/10/2011 12:43
27/10/2011 12:29:32.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:29:32.528 Time Out: ...resetting normal timer
27/10/2011 12:29:32.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:21
27/10/2011 12:29:32.531 Time Out: ...resetting micro timer
27/10/2011 12:29:32.533 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:43
27/10/2011 12:29:32.802 com.apple.launchd: (com.aladdin.hasplmd[7872]) Job appears to have crashed: Bus error: 10
27/10/2011 12:29:32.802 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:29:32.815 ReportCrash: Saved crash report for hasplmd[7872] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122932_localhost.crash
27/10/2011 12:29:42.991 com.apple.launchd: (com.aladdin.hasplmd[7873]) Job appears to have crashed: Bus error: 10
27/10/2011 12:29:42.991 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:29:43.004 ReportCrash: Saved crash report for hasplmd[7873] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122943_localhost.crash
27/10/2011 12:29:47.526 Time Out: Idle 18446521254.3 secs; normal due 27/10/2011 13:21, micro due 27/10/2011 12:43
27/10/2011 12:29:47.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:29:47.529 Time Out: ...resetting normal timer
27/10/2011 12:29:47.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:21
27/10/2011 12:29:47.532 Time Out: ...resetting micro timer
27/10/2011 12:29:47.533 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:43
27/10/2011 12:29:53.024 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:29:53.194 com.apple.launchd: (com.aladdin.hasplmd[7874]) Job appears to have crashed: Bus error: 10
27/10/2011 12:29:53.194 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:29:53.244 ReportCrash: Saved crash report for hasplmd[7874] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-122953_localhost.crash
27/10/2011 12:30:02.526 Time Out: Idle 18446521269.3 secs; normal due 27/10/2011 13:21, micro due 27/10/2011 12:43
27/10/2011 12:30:02.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:30:02.529 Time Out: ...resetting normal timer
27/10/2011 12:30:02.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:22
27/10/2011 12:30:02.532 Time Out: ...resetting micro timer
27/10/2011 12:30:02.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:44
27/10/2011 12:30:03.385 com.apple.launchd: (com.aladdin.hasplmd[7877]) Job appears to have crashed: Bus error: 10
27/10/2011 12:30:03.385 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:30:03.397 ReportCrash: Saved crash report for hasplmd[7877] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123003_localhost.crash
27/10/2011 12:30:13.568 com.apple.launchd: (com.aladdin.hasplmd[7878]) Job appears to have crashed: Bus error: 10
27/10/2011 12:30:13.568 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:30:13.581 ReportCrash: Saved crash report for hasplmd[7878] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123013_localhost.crash
27/10/2011 12:30:17.526 Time Out: Idle 18446521284.3 secs; normal due 27/10/2011 13:22, micro due 27/10/2011 12:44
27/10/2011 12:30:17.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:30:17.529 Time Out: ...resetting normal timer
27/10/2011 12:30:17.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:22
27/10/2011 12:30:17.531 Time Out: ...resetting micro timer
27/10/2011 12:30:17.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:44
27/10/2011 12:30:23.758 com.apple.launchd: (com.aladdin.hasplmd[7879]) Job appears to have crashed: Bus error: 10
27/10/2011 12:30:23.758 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:30:23.771 ReportCrash: Saved crash report for hasplmd[7879] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123023_localhost.crash
27/10/2011 12:30:32.526 Time Out: Idle 18446521299.3 secs; normal due 27/10/2011 13:22, micro due 27/10/2011 12:44
27/10/2011 12:30:32.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:30:32.529 Time Out: ...resetting normal timer
27/10/2011 12:30:32.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:22
27/10/2011 12:30:32.532 Time Out: ...resetting micro timer
27/10/2011 12:30:32.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:44
27/10/2011 12:30:33.943 com.apple.launchd: (com.aladdin.hasplmd[7880]) Job appears to have crashed: Bus error: 10
27/10/2011 12:30:33.943 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:30:33.956 ReportCrash: Saved crash report for hasplmd[7880] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123033_localhost.crash
27/10/2011 12:30:44.130 com.apple.launchd: (com.aladdin.hasplmd[7881]) Job appears to have crashed: Bus error: 10
27/10/2011 12:30:44.130 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:30:44.144 ReportCrash: Saved crash report for hasplmd[7881] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123044_localhost.crash
27/10/2011 12:30:47.526 Time Out: Idle 18446521314.3 secs; normal due 27/10/2011 13:22, micro due 27/10/2011 12:44
27/10/2011 12:30:47.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:30:47.529 Time Out: ...resetting normal timer
27/10/2011 12:30:47.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:22
27/10/2011 12:30:47.532 Time Out: ...resetting micro timer
27/10/2011 12:30:47.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:44
27/10/2011 12:30:54.163 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:30:54.330 com.apple.launchd: (com.aladdin.hasplmd[7882]) Job appears to have crashed: Bus error: 10
27/10/2011 12:30:54.330 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:30:54.383 ReportCrash: Saved crash report for hasplmd[7882] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123054_localhost.crash
27/10/2011 12:31:02.527 Time Out: Idle 18446521329.3 secs; normal due 27/10/2011 13:22, micro due 27/10/2011 12:44
27/10/2011 12:31:02.529 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:31:02.530 Time Out: ...resetting normal timer
27/10/2011 12:31:02.532 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:23
27/10/2011 12:31:02.532 Time Out: ...resetting micro timer
27/10/2011 12:31:02.535 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:45
27/10/2011 12:31:04.517 com.apple.launchd: (com.aladdin.hasplmd[7884]) Job appears to have crashed: Bus error: 10
27/10/2011 12:31:04.517 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:31:04.530 ReportCrash: Saved crash report for hasplmd[7884] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123104_localhost.crash
27/10/2011 12:31:14.706 com.apple.launchd: (com.aladdin.hasplmd[7885]) Job appears to have crashed: Bus error: 10
27/10/2011 12:31:14.706 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:31:14.719 ReportCrash: Saved crash report for hasplmd[7885] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123114_localhost.crash
27/10/2011 12:31:17.527 Time Out: Idle 18446521344.3 secs; normal due 27/10/2011 13:23, micro due 27/10/2011 12:45
27/10/2011 12:31:17.529 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:31:17.529 Time Out: ...resetting normal timer
27/10/2011 12:31:17.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:23
27/10/2011 12:31:17.532 Time Out: ...resetting micro timer
27/10/2011 12:31:17.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:45
27/10/2011 12:31:24.892 com.apple.launchd: (com.aladdin.hasplmd[7886]) Job appears to have crashed: Bus error: 10
27/10/2011 12:31:24.892 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:31:24.905 ReportCrash: Saved crash report for hasplmd[7886] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123124_localhost.crash
27/10/2011 12:31:32.527 Time Out: Idle 18446521359.3 secs; normal due 27/10/2011 13:23, micro due 27/10/2011 12:45
27/10/2011 12:31:32.529 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:31:32.529 Time Out: ...resetting normal timer
27/10/2011 12:31:32.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:23
27/10/2011 12:31:32.532 Time Out: ...resetting micro timer
27/10/2011 12:31:32.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:45
27/10/2011 12:31:35.121 com.apple.launchd: (com.aladdin.hasplmd[7887]) Job appears to have crashed: Bus error: 10
27/10/2011 12:31:35.121 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:31:35.138 ReportCrash: Saved crash report for hasplmd[7887] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123135_localhost.crash
27/10/2011 12:31:45.338 com.apple.launchd: (com.aladdin.hasplmd[7888]) Job appears to have crashed: Bus error: 10
27/10/2011 12:31:45.338 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:31:45.356 ReportCrash: Saved crash report for hasplmd[7888] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123145_localhost.crash
27/10/2011 12:31:47.527 Time Out: Idle 18446521374.3 secs; normal due 27/10/2011 13:23, micro due 27/10/2011 12:45
27/10/2011 12:31:47.529 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:31:47.530 Time Out: ...resetting normal timer
27/10/2011 12:31:47.532 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:23
27/10/2011 12:31:47.533 Time Out: ...resetting micro timer
27/10/2011 12:31:47.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:45
27/10/2011 12:31:55.370 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:31:55.541 com.apple.launchd: (com.aladdin.hasplmd[7889]) Job appears to have crashed: Bus error: 10
27/10/2011 12:31:55.541 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:31:55.589 ReportCrash: Saved crash report for hasplmd[7889] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123155_localhost.crash
27/10/2011 12:32:02.526 Time Out: Idle 18446521389.3 secs; normal due 27/10/2011 13:23, micro due 27/10/2011 12:45
27/10/2011 12:32:02.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:32:02.529 Time Out: ...resetting normal timer
27/10/2011 12:32:02.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:24
27/10/2011 12:32:02.532 Time Out: ...resetting micro timer
27/10/2011 12:32:02.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:46
27/10/2011 12:32:05.757 com.apple.launchd: (com.aladdin.hasplmd[7891]) Job appears to have crashed: Bus error: 10
27/10/2011 12:32:05.757 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:32:05.773 ReportCrash: Saved crash report for hasplmd[7891] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123205_localhost.crash
27/10/2011 12:32:15.943 com.apple.launchd: (com.aladdin.hasplmd[7892]) Job appears to have crashed: Bus error: 10
27/10/2011 12:32:15.943 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:32:15.956 ReportCrash: Saved crash report for hasplmd[7892] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123215_localhost.crash
27/10/2011 12:32:17.527 Time Out: Idle 18446521404.3 secs; normal due 27/10/2011 13:24, micro due 27/10/2011 12:46
27/10/2011 12:32:17.530 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:32:17.530 Time Out: ...resetting normal timer
27/10/2011 12:32:17.533 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:24
27/10/2011 12:32:17.533 Time Out: ...resetting micro timer
27/10/2011 12:32:17.535 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:46
27/10/2011 12:32:26.147 com.apple.launchd: (com.aladdin.hasplmd[7893]) Job appears to have crashed: Bus error: 10
27/10/2011 12:32:26.147 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:32:26.160 ReportCrash: Saved crash report for hasplmd[7893] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123226_localhost.crash
27/10/2011 12:32:32.527 Time Out: Idle 18446521419.3 secs; normal due 27/10/2011 13:24, micro due 27/10/2011 12:46
27/10/2011 12:32:32.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:32:32.529 Time Out: ...resetting normal timer
27/10/2011 12:32:32.530 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:24
27/10/2011 12:32:32.531 Time Out: ...resetting micro timer
27/10/2011 12:32:32.533 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:46
27/10/2011 12:32:36.364 com.apple.launchd: (com.aladdin.hasplmd[7894]) Job appears to have crashed: Bus error: 10
27/10/2011 12:32:36.364 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:32:36.378 ReportCrash: Saved crash report for hasplmd[7894] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123236_localhost.crash
27/10/2011 12:32:46.574 com.apple.launchd: (com.aladdin.hasplmd[7896]) Job appears to have crashed: Bus error: 10
27/10/2011 12:32:46.574 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:32:46.588 ReportCrash: Saved crash report for hasplmd[7896] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123246_localhost.crash
27/10/2011 12:32:47.528 Time Out: Idle 18446521434.3 secs; normal due 27/10/2011 13:24, micro due 27/10/2011 12:46
27/10/2011 12:32:47.530 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:32:47.531 Time Out: ...resetting normal timer
27/10/2011 12:32:47.533 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:24
27/10/2011 12:32:47.534 Time Out: ...resetting micro timer
27/10/2011 12:32:47.536 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:46
27/10/2011 12:32:56.604 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:32:56.785 com.apple.launchd: (com.aladdin.hasplmd[7897]) Job appears to have crashed: Bus error: 10
27/10/2011 12:32:56.785 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:32:56.832 ReportCrash: Saved crash report for hasplmd[7897] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123256_localhost.crash
27/10/2011 12:33:02.528 Time Out: Idle 18446521449.3 secs; normal due 27/10/2011 13:24, micro due 27/10/2011 12:46
27/10/2011 12:33:02.529 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:33:02.530 Time Out: ...resetting normal timer
27/10/2011 12:33:02.532 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:25
27/10/2011 12:33:02.533 Time Out: ...resetting micro timer
27/10/2011 12:33:02.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:47
27/10/2011 12:33:06.980 com.apple.launchd: (com.aladdin.hasplmd[7899]) Job appears to have crashed: Bus error: 10
27/10/2011 12:33:06.980 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:33:06.995 ReportCrash: Saved crash report for hasplmd[7899] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123306_localhost.crash
27/10/2011 12:33:17.173 com.apple.launchd: (com.aladdin.hasplmd[7900]) Job appears to have crashed: Bus error: 10
27/10/2011 12:33:17.173 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:33:17.186 ReportCrash: Saved crash report for hasplmd[7900] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123317_localhost.crash
27/10/2011 12:33:17.527 Time Out: Idle 18446521464.3 secs; normal due 27/10/2011 13:25, micro due 27/10/2011 12:47
27/10/2011 12:33:17.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:33:17.528 Time Out: ...resetting normal timer
27/10/2011 12:33:17.530 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:25
27/10/2011 12:33:17.530 Time Out: ...resetting micro timer
27/10/2011 12:33:17.531 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:47
27/10/2011 12:33:21.353 [0x0-0x87087].com.apple.iTunes: The plugin 'Quartz Composer Visualizer' failed to load because it has the wrong CPU architecture for this version of iTunes. (3585)
27/10/2011 12:33:27.372 com.apple.launchd: (com.aladdin.hasplmd[7904]) Job appears to have crashed: Bus error: 10
27/10/2011 12:33:27.372 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:33:27.385 ReportCrash: Saved crash report for hasplmd[7904] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123327_localhost.crash
27/10/2011 12:33:32.527 Time Out: Idle 18446521479.3 secs; normal due 27/10/2011 13:25, micro due 27/10/2011 12:47
27/10/2011 12:33:32.529 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:33:32.529 Time Out: ...resetting normal timer
27/10/2011 12:33:32.530 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:25
27/10/2011 12:33:32.531 Time Out: ...resetting micro timer
27/10/2011 12:33:32.532 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:47
27/10/2011 12:33:37.561 com.apple.launchd: (com.aladdin.hasplmd[7906]) Job appears to have crashed: Bus error: 10
27/10/2011 12:33:37.561 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:33:37.580 ReportCrash: Saved crash report for hasplmd[7906] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123337_localhost.crash
27/10/2011 12:33:47.529 Time Out: Idle 18446521494.3 secs; normal due 27/10/2011 13:25, micro due 27/10/2011 12:47
27/10/2011 12:33:47.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:33:47.531 Time Out: ...resetting normal timer
27/10/2011 12:33:47.533 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:25
27/10/2011 12:33:47.534 Time Out: ...resetting micro timer
27/10/2011 12:33:47.535 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:47
27/10/2011 12:33:47.756 com.apple.launchd: (com.aladdin.hasplmd[7907]) Job appears to have crashed: Bus error: 10
27/10/2011 12:33:47.756 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:33:47.771 ReportCrash: Saved crash report for hasplmd[7907] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123347_localhost.crash
27/10/2011 12:33:57.785 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:33:57.963 com.apple.launchd: (com.aladdin.hasplmd[7910]) Job appears to have crashed: Bus error: 10
27/10/2011 12:33:57.963 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:33:58.011 ReportCrash: Saved crash report for hasplmd[7910] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123358_localhost.crash
27/10/2011 12:33:59.000 kernel: IOSurface: buffer allocation size is zero
27/10/2011 12:34:00.000 kernel: IOSurface: buffer allocation size is zero
27/10/2011 12:34:02.528 Time Out: Idle 18446521509.3 secs; normal due 27/10/2011 13:25, micro due 27/10/2011 12:47
27/10/2011 12:34:02.529 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:34:02.530 Time Out: ...resetting normal timer
27/10/2011 12:34:02.532 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:26
27/10/2011 12:34:02.532 Time Out: ...resetting micro timer
27/10/2011 12:34:02.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:48
27/10/2011 12:34:08.155 com.apple.launchd: (com.aladdin.hasplmd[7912]) Job appears to have crashed: Bus error: 10
27/10/2011 12:34:08.155 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:34:08.479 ReportCrash: Saved crash report for hasplmd[7912] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123408_localhost.crash
27/10/2011 12:34:16.394 [0x0-0x42042].com.apple.Safari: DVFreeThread - CFMachPortCreateWithPort hack = 0x25f5a0, fPowerNotifyPort= 0x262ce0
27/10/2011 12:34:16.394 [0x0-0x42042].com.apple.Safari: DVFreeThread - CFMachPortCreateWithPort hack = 0x6d019d50, fPowerNotifyPort= 0x6d019d30
27/10/2011 12:34:17.528 Time Out: Idle 18446521524.3 secs; normal due 27/10/2011 13:26, micro due 27/10/2011 12:48
27/10/2011 12:34:17.530 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:34:17.531 Time Out: ...resetting normal timer
27/10/2011 12:34:17.533 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:26
27/10/2011 12:34:17.534 Time Out: ...resetting micro timer
27/10/2011 12:34:17.536 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:48
27/10/2011 12:34:18.342 com.apple.launchd: (com.aladdin.hasplmd[7913]) Job appears to have crashed: Bus error: 10
27/10/2011 12:34:18.342 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:34:18.355 ReportCrash: Saved crash report for hasplmd[7913] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123418_localhost.crash
27/10/2011 12:34:28.528 com.apple.launchd: (com.aladdin.hasplmd[7914]) Job appears to have crashed: Bus error: 10
27/10/2011 12:34:28.528 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:34:28.541 ReportCrash: Saved crash report for hasplmd[7914] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123428_localhost.crash
27/10/2011 12:34:32.529 Time Out: Idle 18446521539.3 secs; normal due 27/10/2011 13:26, micro due 27/10/2011 12:48
27/10/2011 12:34:32.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:34:32.532 Time Out: ...resetting normal timer
27/10/2011 12:34:32.534 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:26
27/10/2011 12:34:32.534 Time Out: ...resetting micro timer
27/10/2011 12:34:32.536 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:48
27/10/2011 12:34:38.744 com.apple.launchd: (com.aladdin.hasplmd[7916]) Job appears to have crashed: Bus error: 10
27/10/2011 12:34:38.744 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:34:38.760 ReportCrash: Saved crash report for hasplmd[7916] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123438_localhost.crash
27/10/2011 12:34:47.527 Time Out: Idle 18446521554.3 secs; normal due 27/10/2011 13:26, micro due 27/10/2011 12:48
27/10/2011 12:34:47.528 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:34:47.529 Time Out: ...resetting normal timer
27/10/2011 12:34:47.530 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:26
27/10/2011 12:34:47.531 Time Out: ...resetting micro timer
27/10/2011 12:34:47.532 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:48
27/10/2011 12:34:48.958 com.apple.launchd: (com.aladdin.hasplmd[7919]) Job appears to have crashed: Bus error: 10
27/10/2011 12:34:48.958 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:34:48.975 ReportCrash: Saved crash report for hasplmd[7919] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123448_localhost.crash
27/10/2011 12:34:58.990 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:34:59.166 com.apple.launchd: (com.aladdin.hasplmd[7920]) Job appears to have crashed: Bus error: 10
27/10/2011 12:34:59.166 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:34:59.217 ReportCrash: Saved crash report for hasplmd[7920] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123459_localhost.crash
27/10/2011 12:35:02.529 Time Out: Idle 18446521569.3 secs; normal due 27/10/2011 13:26, micro due 27/10/2011 12:48
27/10/2011 12:35:02.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:35:02.531 Time Out: ...resetting normal timer
27/10/2011 12:35:02.533 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:27
27/10/2011 12:35:02.534 Time Out: ...resetting micro timer
27/10/2011 12:35:02.535 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:49
27/10/2011 12:35:09.357 com.apple.launchd: (com.aladdin.hasplmd[7922]) Job appears to have crashed: Bus error: 10
27/10/2011 12:35:09.357 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:35:09.370 ReportCrash: Saved crash report for hasplmd[7922] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123509_localhost.crash
27/10/2011 12:35:17.529 Time Out: Idle 18446521584.3 secs; normal due 27/10/2011 13:27, micro due 27/10/2011 12:49
27/10/2011 12:35:17.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:35:17.532 Time Out: ...resetting normal timer
27/10/2011 12:35:17.534 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:27
27/10/2011 12:35:17.535 Time Out: ...resetting micro timer
27/10/2011 12:35:17.537 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:49
27/10/2011 12:35:19.547 com.apple.launchd: (com.aladdin.hasplmd[7923]) Job appears to have crashed: Bus error: 10
27/10/2011 12:35:19.547 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:35:19.560 ReportCrash: Saved crash report for hasplmd[7923] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123519_localhost.crash
27/10/2011 12:35:29.740 com.apple.launchd: (com.aladdin.hasplmd[7924]) Job appears to have crashed: Bus error: 10
27/10/2011 12:35:29.740 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:35:29.753 ReportCrash: Saved crash report for hasplmd[7924] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123529_localhost.crash
27/10/2011 12:35:32.529 Time Out: Idle 18446521599.3 secs; normal due 27/10/2011 13:27, micro due 27/10/2011 12:49
27/10/2011 12:35:32.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:35:32.532 Time Out: ...resetting normal timer
27/10/2011 12:35:32.534 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:27
27/10/2011 12:35:32.534 Time Out: ...resetting micro timer
27/10/2011 12:35:32.536 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:49
27/10/2011 12:35:39.933 com.apple.launchd: (com.aladdin.hasplmd[7925]) Job appears to have crashed: Bus error: 10
27/10/2011 12:35:39.933 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:35:39.946 ReportCrash: Saved crash report for hasplmd[7925] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123539_localhost.crash
27/10/2011 12:35:47.529 Time Out: Idle 18446521614.3 secs; normal due 27/10/2011 13:27, micro due 27/10/2011 12:49
27/10/2011 12:35:47.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:35:47.532 Time Out: ...resetting normal timer
27/10/2011 12:35:47.533 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:27
27/10/2011 12:35:47.534 Time Out: ...resetting micro timer
27/10/2011 12:35:47.536 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:49
27/10/2011 12:35:50.129 com.apple.launchd: (com.aladdin.hasplmd[7926]) Job appears to have crashed: Bus error: 10
27/10/2011 12:35:50.129 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:35:50.145 ReportCrash: Saved crash report for hasplmd[7926] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123550_localhost.crash
27/10/2011 12:36:00.158 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:36:00.344 com.apple.launchd: (com.aladdin.hasplmd[7927]) Job appears to have crashed: Bus error: 10
27/10/2011 12:36:00.344 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:36:00.389 ReportCrash: Saved crash report for hasplmd[7927] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123600_localhost.crash
27/10/2011 12:36:02.528 Time Out: Idle 18446521629.3 secs; normal due 27/10/2011 13:27, micro due 27/10/2011 12:49
27/10/2011 12:36:02.529 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:36:02.530 Time Out: ...resetting normal timer
27/10/2011 12:36:02.531 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:28
27/10/2011 12:36:02.532 Time Out: ...resetting micro timer
27/10/2011 12:36:02.533 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:50
27/10/2011 12:36:10.538 com.apple.launchd: (com.aladdin.hasplmd[7929]) Job appears to have crashed: Bus error: 10
27/10/2011 12:36:10.538 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:36:10.553 ReportCrash: Saved crash report for hasplmd[7929] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123610_localhost.crash
27/10/2011 12:36:17.528 Time Out: Idle 18446521644.3 secs; normal due 27/10/2011 13:28, micro due 27/10/2011 12:50
27/10/2011 12:36:17.530 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:36:17.531 Time Out: ...resetting normal timer
27/10/2011 12:36:17.532 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:28
27/10/2011 12:36:17.532 Time Out: ...resetting micro timer
27/10/2011 12:36:17.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:50
27/10/2011 12:36:20.734 com.apple.launchd: (com.aladdin.hasplmd[7930]) Job appears to have crashed: Bus error: 10
27/10/2011 12:36:20.734 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:36:20.748 ReportCrash: Saved crash report for hasplmd[7930] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123620_localhost.crash
27/10/2011 12:36:24.830 _softwareupdate: audit warning: soft /var/audit
27/10/2011 12:36:24.830 _softwareupdate: audit warning: allsoft
27/10/2011 12:36:24.833 _softwareupdate: audit warning: closefile /var/audit/20111027112656.20111027113624
27/10/2011 12:36:30.925 com.apple.launchd: (com.aladdin.hasplmd[7943]) Job appears to have crashed: Bus error: 10
27/10/2011 12:36:30.925 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:36:30.939 ReportCrash: Saved crash report for hasplmd[7943] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123630_localhost.crash
27/10/2011 12:36:32.530 Time Out: Idle 18446521659.3 secs; normal due 27/10/2011 13:28, micro due 27/10/2011 12:50
27/10/2011 12:36:32.532 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:36:32.533 Time Out: ...resetting normal timer
27/10/2011 12:36:32.535 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:28
27/10/2011 12:36:32.536 Time Out: ...resetting micro timer
27/10/2011 12:36:32.537 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:50
27/10/2011 12:36:41.118 com.apple.launchd: (com.aladdin.hasplmd[7944]) Job appears to have crashed: Bus error: 10
27/10/2011 12:36:41.118 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:36:41.131 ReportCrash: Saved crash report for hasplmd[7944] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123641_localhost.crash
27/10/2011 12:36:47.529 Time Out: Idle 18446521674.3 secs; normal due 27/10/2011 13:28, micro due 27/10/2011 12:50
27/10/2011 12:36:47.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:36:47.532 Time Out: ...resetting normal timer
27/10/2011 12:36:47.533 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:28
27/10/2011 12:36:47.533 Time Out: ...resetting micro timer
27/10/2011 12:36:47.535 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:50
27/10/2011 12:36:51.311 com.apple.launchd: (com.aladdin.hasplmd[7945]) Job appears to have crashed: Bus error: 10
27/10/2011 12:36:51.311 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:36:51.324 ReportCrash: Saved crash report for hasplmd[7945] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123651_localhost.crash
27/10/2011 12:37:01.344 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:37:01.520 com.apple.launchd: (com.aladdin.hasplmd[7946]) Job appears to have crashed: Bus error: 10
27/10/2011 12:37:01.520 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:37:01.571 ReportCrash: Saved crash report for hasplmd[7946] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123701_localhost.crash
27/10/2011 12:37:02.529 Time Out: Idle 18446521689.3 secs; normal due 27/10/2011 13:28, micro due 27/10/2011 12:50
27/10/2011 12:37:02.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:37:02.531 Time Out: ...resetting normal timer
27/10/2011 12:37:02.532 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:29
27/10/2011 12:37:02.533 Time Out: ...resetting micro timer
27/10/2011 12:37:02.534 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:51
27/10/2011 12:37:11.710 com.apple.launchd: (com.aladdin.hasplmd[7948]) Job appears to have crashed: Bus error: 10
27/10/2011 12:37:11.710 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:37:11.724 ReportCrash: Saved crash report for hasplmd[7948] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123711_localhost.crash
27/10/2011 12:37:17.531 Time Out: Idle 18446521704.3 secs; normal due 27/10/2011 13:29, micro due 27/10/2011 12:51
27/10/2011 12:37:17.532 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:37:17.533 Time Out: ...resetting normal timer
27/10/2011 12:37:17.535 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:29
27/10/2011 12:37:17.536 Time Out: ...resetting micro timer
27/10/2011 12:37:17.538 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:51
27/10/2011 12:37:21.902 com.apple.launchd: (com.aladdin.hasplmd[7949]) Job appears to have crashed: Bus error: 10
27/10/2011 12:37:21.902 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:37:21.921 ReportCrash: Saved crash report for hasplmd[7949] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123721_localhost.crash
27/10/2011 12:37:32.093 com.apple.launchd: (com.aladdin.hasplmd[7950]) Job appears to have crashed: Bus error: 10
27/10/2011 12:37:32.093 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:37:32.106 ReportCrash: Saved crash report for hasplmd[7950] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123732_localhost.crash
27/10/2011 12:37:32.531 Time Out: Idle 18446521719.3 secs; normal due 27/10/2011 13:29, micro due 27/10/2011 12:51
27/10/2011 12:37:32.533 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:37:32.534 Time Out: ...resetting normal timer
27/10/2011 12:37:32.536 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:29
27/10/2011 12:37:32.537 Time Out: ...resetting micro timer
27/10/2011 12:37:32.538 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:51
27/10/2011 12:37:42.290 com.apple.launchd: (com.aladdin.hasplmd[7951]) Job appears to have crashed: Bus error: 10
27/10/2011 12:37:42.290 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:37:42.304 ReportCrash: Saved crash report for hasplmd[7951] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123742_localhost.crash
27/10/2011 12:37:47.531 Time Out: Idle 18446521734.3 secs; normal due 27/10/2011 13:29, micro due 27/10/2011 12:51
27/10/2011 12:37:47.533 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:37:47.533 Time Out: ...resetting normal timer
27/10/2011 12:37:47.535 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:29
27/10/2011 12:37:47.536 Time Out: ...resetting micro timer
27/10/2011 12:37:47.538 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:51
27/10/2011 12:37:52.483 com.apple.launchd: (com.aladdin.hasplmd[7952]) Job appears to have crashed: Bus error: 10
27/10/2011 12:37:52.483 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:37:52.501 ReportCrash: Saved crash report for hasplmd[7952] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123752_localhost.crash
27/10/2011 12:38:02.515 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:38:02.530 Time Out: Idle 18446521749.3 secs; normal due 27/10/2011 13:29, micro due 27/10/2011 12:51
27/10/2011 12:38:02.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:38:02.532 Time Out: ...resetting normal timer
27/10/2011 12:38:02.533 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:30
27/10/2011 12:38:02.533 Time Out: ...resetting micro timer
27/10/2011 12:38:02.535 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:52
27/10/2011 12:38:02.689 com.apple.launchd: (com.aladdin.hasplmd[7954]) Job appears to have crashed: Bus error: 10
27/10/2011 12:38:02.689 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:38:02.735 ReportCrash: Saved crash report for hasplmd[7954] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123802_localhost.crash
27/10/2011 12:38:12.881 com.apple.launchd: (com.aladdin.hasplmd[7956]) Job appears to have crashed: Bus error: 10
27/10/2011 12:38:12.881 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:38:12.894 ReportCrash: Saved crash report for hasplmd[7956] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123812_localhost.crash
27/10/2011 12:38:17.531 Time Out: Idle 18446521764.3 secs; normal due 27/10/2011 13:30, micro due 27/10/2011 12:52
27/10/2011 12:38:17.533 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:38:17.534 Time Out: ...resetting normal timer
27/10/2011 12:38:17.536 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:30
27/10/2011 12:38:17.537 Time Out: ...resetting micro timer
27/10/2011 12:38:17.539 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:52
27/10/2011 12:38:23.071 com.apple.launchd: (com.aladdin.hasplmd[7957]) Job appears to have crashed: Bus error: 10
27/10/2011 12:38:23.071 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:38:23.084 ReportCrash: Saved crash report for hasplmd[7957] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123823_localhost.crash
27/10/2011 12:38:27.737 _softwareupdate: audit warning: soft /var/audit
27/10/2011 12:38:27.738 _softwareupdate: audit warning: allsoft
27/10/2011 12:38:27.738 _softwareupdate: audit warning: closefile /var/audit/20111027113624.20111027113827
27/10/2011 12:38:32.530 Time Out: Idle 18446521779.3 secs; normal due 27/10/2011 13:30, micro due 27/10/2011 12:52
27/10/2011 12:38:32.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:38:32.532 Time Out: ...resetting normal timer
27/10/2011 12:38:32.533 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:30
27/10/2011 12:38:32.534 Time Out: ...resetting micro timer
27/10/2011 12:38:32.535 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:52
27/10/2011 12:38:33.276 com.apple.launchd: (com.aladdin.hasplmd[7968]) Job appears to have crashed: Bus error: 10
27/10/2011 12:38:33.276 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:38:33.290 ReportCrash: Saved crash report for hasplmd[7968] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123833_localhost.crash
27/10/2011 12:38:43.468 com.apple.launchd: (com.aladdin.hasplmd[7969]) Job appears to have crashed: Bus error: 10
27/10/2011 12:38:43.468 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:38:43.481 ReportCrash: Saved crash report for hasplmd[7969] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123843_localhost.crash
27/10/2011 12:38:47.531 Time Out: Idle 18446521794.3 secs; normal due 27/10/2011 13:30, micro due 27/10/2011 12:52
27/10/2011 12:38:47.533 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:38:47.534 Time Out: ...resetting normal timer
27/10/2011 12:38:47.536 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:30
27/10/2011 12:38:47.537 Time Out: ...resetting micro timer
27/10/2011 12:38:47.539 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:52
27/10/2011 12:38:53.700 com.apple.launchd: (com.aladdin.hasplmd[7970]) Job appears to have crashed: Bus error: 10
27/10/2011 12:38:53.700 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:38:53.719 ReportCrash: Saved crash report for hasplmd[7970] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123853_localhost.crash
27/10/2011 12:39:02.530 Time Out: Idle 18446521809.3 secs; normal due 27/10/2011 13:30, micro due 27/10/2011 12:52
27/10/2011 12:39:02.531 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:39:02.532 Time Out: ...resetting normal timer
27/10/2011 12:39:02.533 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:31
27/10/2011 12:39:02.534 Time Out: ...resetting micro timer
27/10/2011 12:39:02.535 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:53
27/10/2011 12:39:03.733 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:39:03.908 com.apple.launchd: (com.aladdin.hasplmd[7971]) Job appears to have crashed: Bus error: 10
27/10/2011 12:39:03.908 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:39:03.957 ReportCrash: Saved crash report for hasplmd[7971] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123903_localhost.crash
27/10/2011 12:39:14.100 com.apple.launchd: (com.aladdin.hasplmd[7973]) Job appears to have crashed: Bus error: 10
27/10/2011 12:39:14.100 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:39:14.113 ReportCrash: Saved crash report for hasplmd[7973] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123914_localhost.crash
27/10/2011 12:39:17.532 Time Out: Idle 18446521824.3 secs; normal due 27/10/2011 13:31, micro due 27/10/2011 12:53
27/10/2011 12:39:17.534 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:39:17.535 Time Out: ...resetting normal timer
27/10/2011 12:39:17.537 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:31
27/10/2011 12:39:17.538 Time Out: ...resetting micro timer
27/10/2011 12:39:17.540 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:53
27/10/2011 12:39:24.298 com.apple.launchd: (com.aladdin.hasplmd[7974]) Job appears to have crashed: Bus error: 10
27/10/2011 12:39:24.298 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:39:24.311 ReportCrash: Saved crash report for hasplmd[7974] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123924_localhost.crash
27/10/2011 12:39:32.532 Time Out: Idle 18446521839.3 secs; normal due 27/10/2011 13:31, micro due 27/10/2011 12:53
27/10/2011 12:39:32.534 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:39:32.534 Time Out: ...resetting normal timer
27/10/2011 12:39:32.536 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:31
27/10/2011 12:39:32.537 Time Out: ...resetting micro timer
27/10/2011 12:39:32.538 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:53
27/10/2011 12:39:34.490 com.apple.launchd: (com.aladdin.hasplmd[7975]) Job appears to have crashed: Bus error: 10
27/10/2011 12:39:34.490 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:39:34.503 ReportCrash: Saved crash report for hasplmd[7975] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123934_localhost.crash
27/10/2011 12:39:44.677 com.apple.launchd: (com.aladdin.hasplmd[7976]) Job appears to have crashed: Bus error: 10
27/10/2011 12:39:44.677 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:39:44.689 ReportCrash: Saved crash report for hasplmd[7976] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123944_localhost.crash
27/10/2011 12:39:47.532 Time Out: Idle 18446521854.3 secs; normal due 27/10/2011 13:31, micro due 27/10/2011 12:53
27/10/2011 12:39:47.534 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:39:47.535 Time Out: ...resetting normal timer
27/10/2011 12:39:47.537 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:31
27/10/2011 12:39:47.538 Time Out: ...resetting micro timer
27/10/2011 12:39:47.540 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:53
27/10/2011 12:39:54.886 com.apple.launchd: (com.aladdin.hasplmd[7977]) Job appears to have crashed: Bus error: 10
27/10/2011 12:39:54.886 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:39:54.903 ReportCrash: Saved crash report for hasplmd[7977] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-123954_localhost.crash
27/10/2011 12:40:02.532 Time Out: Idle 18446521869.3 secs; normal due 27/10/2011 13:31, micro due 27/10/2011 12:53
27/10/2011 12:40:02.533 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:40:02.534 Time Out: ...resetting normal timer
27/10/2011 12:40:02.535 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:32
27/10/2011 12:40:02.536 Time Out: ...resetting micro timer
27/10/2011 12:40:02.537 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:54
27/10/2011 12:40:04.920 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:40:05.122 com.apple.launchd: (com.aladdin.hasplmd[7978]) Job appears to have crashed: Bus error: 10
27/10/2011 12:40:05.122 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:40:05.178 ReportCrash: Saved crash report for hasplmd[7978] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124005_localhost.crash
27/10/2011 12:40:15.315 com.apple.launchd: (com.aladdin.hasplmd[7980]) Job appears to have crashed: Bus error: 10
27/10/2011 12:40:15.315 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:40:15.328 ReportCrash: Saved crash report for hasplmd[7980] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124015_localhost.crash
27/10/2011 12:40:17.532 Time Out: Idle 18446521884.3 secs; normal due 27/10/2011 13:32, micro due 27/10/2011 12:54
27/10/2011 12:40:17.535 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:40:17.535 Time Out: ...resetting normal timer
27/10/2011 12:40:17.537 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:32
27/10/2011 12:40:17.538 Time Out: ...resetting micro timer
27/10/2011 12:40:17.540 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:54
27/10/2011 12:40:25.508 com.apple.launchd: (com.aladdin.hasplmd[7981]) Job appears to have crashed: Bus error: 10
27/10/2011 12:40:25.508 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:40:25.521 ReportCrash: Saved crash report for hasplmd[7981] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124025_localhost.crash
27/10/2011 12:40:32.533 Time Out: Idle 18446521899.3 secs; normal due 27/10/2011 13:32, micro due 27/10/2011 12:54
27/10/2011 12:40:32.535 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:40:32.535 Time Out: ...resetting normal timer
27/10/2011 12:40:32.538 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:32
27/10/2011 12:40:32.538 Time Out: ...resetting micro timer
27/10/2011 12:40:32.541 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:54
27/10/2011 12:40:35.701 com.apple.launchd: (com.aladdin.hasplmd[7982]) Job appears to have crashed: Bus error: 10
27/10/2011 12:40:35.701 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:40:35.718 ReportCrash: Saved crash report for hasplmd[7982] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124035_localhost.crash
27/10/2011 12:40:45.910 com.apple.launchd: (com.aladdin.hasplmd[7983]) Job appears to have crashed: Bus error: 10
27/10/2011 12:40:45.911 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:40:45.924 ReportCrash: Saved crash report for hasplmd[7983] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124045_localhost.crash
27/10/2011 12:40:47.532 Time Out: Idle 18446521914.3 secs; normal due 27/10/2011 13:32, micro due 27/10/2011 12:54
27/10/2011 12:40:47.533 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:40:47.533 Time Out: ...resetting normal timer
27/10/2011 12:40:47.534 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:32
27/10/2011 12:40:47.535 Time Out: ...resetting micro timer
27/10/2011 12:40:47.536 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:54
27/10/2011 12:40:56.123 com.apple.launchd: (com.aladdin.hasplmd[7984]) Job appears to have crashed: Bus error: 10
27/10/2011 12:40:56.124 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:40:56.140 ReportCrash: Saved crash report for hasplmd[7984] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124056_localhost.crash
27/10/2011 12:41:02.533 Time Out: Idle 18446521929.3 secs; normal due 27/10/2011 13:32, micro due 27/10/2011 12:54
27/10/2011 12:41:02.535 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:41:02.536 Time Out: ...resetting normal timer
27/10/2011 12:41:02.538 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:33
27/10/2011 12:41:02.538 Time Out: ...resetting micro timer
27/10/2011 12:41:02.540 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:55
27/10/2011 12:41:06.156 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:41:06.329 com.apple.launchd: (com.aladdin.hasplmd[7985]) Job appears to have crashed: Bus error: 10
27/10/2011 12:41:06.329 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:41:06.372 ReportCrash: Saved crash report for hasplmd[7985] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124106_localhost.crash
27/10/2011 12:41:16.528 com.apple.launchd: (com.aladdin.hasplmd[7987]) Job appears to have crashed: Bus error: 10
27/10/2011 12:41:16.528 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:41:16.540 ReportCrash: Saved crash report for hasplmd[7987] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124116_localhost.crash
27/10/2011 12:41:17.533 Time Out: Idle 18446521944.3 secs; normal due 27/10/2011 13:33, micro due 27/10/2011 12:55
27/10/2011 12:41:17.535 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:41:17.536 Time Out: ...resetting normal timer
27/10/2011 12:41:17.538 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:33
27/10/2011 12:41:17.539 Time Out: ...resetting micro timer
27/10/2011 12:41:17.540 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:55
27/10/2011 12:41:26.730 com.apple.launchd: (com.aladdin.hasplmd[7988]) Job appears to have crashed: Bus error: 10
27/10/2011 12:41:26.730 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:41:26.743 ReportCrash: Saved crash report for hasplmd[7988] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124126_localhost.crash
27/10/2011 12:41:32.533 Time Out: Idle 18446521959.3 secs; normal due 27/10/2011 13:33, micro due 27/10/2011 12:55
27/10/2011 12:41:32.536 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:41:32.536 Time Out: ...resetting normal timer
27/10/2011 12:41:32.538 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:33
27/10/2011 12:41:32.539 Time Out: ...resetting micro timer
27/10/2011 12:41:32.541 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:55
27/10/2011 12:41:36.921 com.apple.launchd: (com.aladdin.hasplmd[7989]) Job appears to have crashed: Bus error: 10
27/10/2011 12:41:36.921 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:41:36.934 ReportCrash: Saved crash report for hasplmd[7989] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124136_localhost.crash
27/10/2011 12:41:47.126 com.apple.launchd: (com.aladdin.hasplmd[7990]) Job appears to have crashed: Bus error: 10
27/10/2011 12:41:47.126 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:41:47.141 ReportCrash: Saved crash report for hasplmd[7990] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124147_localhost.crash
27/10/2011 12:41:47.534 Time Out: Idle 18446521974.3 secs; normal due 27/10/2011 13:33, micro due 27/10/2011 12:55
27/10/2011 12:41:47.536 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:41:47.537 Time Out: ...resetting normal timer
27/10/2011 12:41:47.539 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:33
27/10/2011 12:41:47.539 Time Out: ...resetting micro timer
27/10/2011 12:41:47.541 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:55
27/10/2011 12:41:57.322 com.apple.launchd: (com.aladdin.hasplmd[7991]) Job appears to have crashed: Bus error: 10
27/10/2011 12:41:57.322 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:41:57.337 ReportCrash: Saved crash report for hasplmd[7991] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124157_localhost.crash
27/10/2011 12:42:02.534 Time Out: Idle 18446521989.3 secs; normal due 27/10/2011 13:33, micro due 27/10/2011 12:55
27/10/2011 12:42:02.536 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:42:02.537 Time Out: ...resetting normal timer
27/10/2011 12:42:02.539 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:34
27/10/2011 12:42:02.540 Time Out: ...resetting micro timer
27/10/2011 12:42:02.541 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:56
27/10/2011 12:42:07.356 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:42:07.530 com.apple.launchd: (com.aladdin.hasplmd[7992]) Job appears to have crashed: Bus error: 10
27/10/2011 12:42:07.530 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:42:07.579 ReportCrash: Saved crash report for hasplmd[7992] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124207_localhost.crash
27/10/2011 12:42:17.533 Time Out: Idle 18446522004.3 secs; normal due 27/10/2011 13:34, micro due 27/10/2011 12:56
27/10/2011 12:42:17.535 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:42:17.536 Time Out: ...resetting normal timer
27/10/2011 12:42:17.538 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:34
27/10/2011 12:42:17.538 Time Out: ...resetting micro timer
27/10/2011 12:42:17.540 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:56
27/10/2011 12:42:17.738 com.apple.launchd: (com.aladdin.hasplmd[7994]) Job appears to have crashed: Bus error: 10
27/10/2011 12:42:17.738 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:42:17.752 ReportCrash: Saved crash report for hasplmd[7994] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124217_localhost.crash
27/10/2011 12:42:27.944 com.apple.launchd: (com.aladdin.hasplmd[7996]) Job appears to have crashed: Bus error: 10
27/10/2011 12:42:27.944 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:42:27.957 ReportCrash: Saved crash report for hasplmd[7996] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124227_localhost.crash
27/10/2011 12:42:32.533 Time Out: Idle 18446522019.3 secs; normal due 27/10/2011 13:34, micro due 27/10/2011 12:56
27/10/2011 12:42:32.534 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:42:32.534 Time Out: ...resetting normal timer
27/10/2011 12:42:32.535 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:34
27/10/2011 12:42:32.536 Time Out: ...resetting micro timer
27/10/2011 12:42:32.537 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:56
27/10/2011 12:42:38.143 com.apple.launchd: (com.aladdin.hasplmd[7997]) Job appears to have crashed: Bus error: 10
27/10/2011 12:42:38.143 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:42:38.159 ReportCrash: Saved crash report for hasplmd[7997] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124238_localhost.crash
27/10/2011 12:42:47.534 Time Out: Idle 18446522034.3 secs; normal due 27/10/2011 13:34, micro due 27/10/2011 12:56
27/10/2011 12:42:47.536 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:42:47.537 Time Out: ...resetting normal timer
27/10/2011 12:42:47.538 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:34
27/10/2011 12:42:47.539 Time Out: ...resetting micro timer
27/10/2011 12:42:47.540 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:56
27/10/2011 12:42:48.340 com.apple.launchd: (com.aladdin.hasplmd[7998]) Job appears to have crashed: Bus error: 10
27/10/2011 12:42:48.340 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:42:48.354 ReportCrash: Saved crash report for hasplmd[7998] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124248_localhost.crash
27/10/2011 12:42:58.542 com.apple.launchd: (com.aladdin.hasplmd[7999]) Job appears to have crashed: Bus error: 10
27/10/2011 12:42:58.542 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:42:58.555 ReportCrash: Saved crash report for hasplmd[7999] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124258_localhost.crash
27/10/2011 12:43:02.534 Time Out: Idle 18446522049.3 secs; normal due 27/10/2011 13:34, micro due 27/10/2011 12:56
27/10/2011 12:43:02.536 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:43:02.537 Time Out: ...resetting normal timer
27/10/2011 12:43:02.539 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:35
27/10/2011 12:43:02.540 Time Out: ...resetting micro timer
27/10/2011 12:43:02.541 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:57
27/10/2011 12:43:08.575 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:43:08.754 com.apple.launchd: (com.aladdin.hasplmd[8000]) Job appears to have crashed: Bus error: 10
27/10/2011 12:43:08.754 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:43:08.800 ReportCrash: Saved crash report for hasplmd[8000] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124308_localhost.crash
27/10/2011 12:43:17.534 Time Out: Idle 18446522064.3 secs; normal due 27/10/2011 13:35, micro due 27/10/2011 12:57
27/10/2011 12:43:17.535 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:43:17.536 Time Out: ...resetting normal timer
27/10/2011 12:43:17.537 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:35
27/10/2011 12:43:17.538 Time Out: ...resetting micro timer
27/10/2011 12:43:17.539 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:57
27/10/2011 12:43:18.949 com.apple.launchd: (com.aladdin.hasplmd[8002]) Job appears to have crashed: Bus error: 10
27/10/2011 12:43:18.949 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:43:18.962 ReportCrash: Saved crash report for hasplmd[8002] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124318_localhost.crash
27/10/2011 12:43:29.144 com.apple.launchd: (com.aladdin.hasplmd[8003]) Job appears to have crashed: Bus error: 10
27/10/2011 12:43:29.144 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:43:29.157 ReportCrash: Saved crash report for hasplmd[8003] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124329_localhost.crash
27/10/2011 12:43:32.535 Time Out: Idle 18446522079.3 secs; normal due 27/10/2011 13:35, micro due 27/10/2011 12:57
27/10/2011 12:43:32.537 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:43:32.537 Time Out: ...resetting normal timer
27/10/2011 12:43:32.539 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:35
27/10/2011 12:43:32.540 Time Out: ...resetting micro timer
27/10/2011 12:43:32.541 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:57
27/10/2011 12:43:39.352 com.apple.launchd: (com.aladdin.hasplmd[8004]) Job appears to have crashed: Bus error: 10
27/10/2011 12:43:39.352 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:43:39.365 ReportCrash: Saved crash report for hasplmd[8004] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124339_localhost.crash
27/10/2011 12:43:47.534 Time Out: Idle 18446522094.3 secs; normal due 27/10/2011 13:35, micro due 27/10/2011 12:57
27/10/2011 12:43:47.537 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:43:47.537 Time Out: ...resetting normal timer
27/10/2011 12:43:47.539 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:35
27/10/2011 12:43:47.539 Time Out: ...resetting micro timer
27/10/2011 12:43:47.541 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:57
27/10/2011 12:43:49.557 com.apple.launchd: (com.aladdin.hasplmd[8005]) Job appears to have crashed: Bus error: 10
27/10/2011 12:43:49.557 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:43:49.570 ReportCrash: Saved crash report for hasplmd[8005] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124349_localhost.crash
27/10/2011 12:43:59.757 com.apple.launchd: (com.aladdin.hasplmd[8006]) Job appears to have crashed: Bus error: 10
27/10/2011 12:43:59.757 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:43:59.770 ReportCrash: Saved crash report for hasplmd[8006] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124359_localhost.crash
27/10/2011 12:44:02.534 Time Out: Idle 18446522109.3 secs; normal due 27/10/2011 13:35, micro due 27/10/2011 12:57
27/10/2011 12:44:02.537 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:44:02.537 Time Out: ...resetting normal timer
27/10/2011 12:44:02.539 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:36
27/10/2011 12:44:02.540 Time Out: ...resetting micro timer
27/10/2011 12:44:02.541 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:58
27/10/2011 12:44:09.789 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:44:09.969 com.apple.launchd: (com.aladdin.hasplmd[8007]) Job appears to have crashed: Bus error: 10
27/10/2011 12:44:09.969 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:44:10.019 ReportCrash: Saved crash report for hasplmd[8007] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124410_localhost.crash
27/10/2011 12:44:17.535 Time Out: Idle 18446522124.3 secs; normal due 27/10/2011 13:36, micro due 27/10/2011 12:58
27/10/2011 12:44:17.537 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:44:17.537 Time Out: ...resetting normal timer
27/10/2011 12:44:17.539 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:36
27/10/2011 12:44:17.539 Time Out: ...resetting micro timer
27/10/2011 12:44:17.541 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:58
27/10/2011 12:44:20.173 com.apple.launchd: (com.aladdin.hasplmd[8009]) Job appears to have crashed: Bus error: 10
27/10/2011 12:44:20.173 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:44:20.186 ReportCrash: Saved crash report for hasplmd[8009] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124420_localhost.crash
27/10/2011 12:44:30.377 com.apple.launchd: (com.aladdin.hasplmd[8010]) Job appears to have crashed: Bus error: 10
27/10/2011 12:44:30.377 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:44:30.390 ReportCrash: Saved crash report for hasplmd[8010] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124430_localhost.crash
27/10/2011 12:44:32.535 Time Out: Idle 18446522139.3 secs; normal due 27/10/2011 13:36, micro due 27/10/2011 12:58
27/10/2011 12:44:32.537 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:44:32.538 Time Out: ...resetting normal timer
27/10/2011 12:44:32.540 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:36
27/10/2011 12:44:32.540 Time Out: ...resetting micro timer
27/10/2011 12:44:32.542 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:58
27/10/2011 12:44:40.572 com.apple.launchd: (com.aladdin.hasplmd[8011]) Job appears to have crashed: Bus error: 10
27/10/2011 12:44:40.572 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:44:40.586 ReportCrash: Saved crash report for hasplmd[8011] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124440_localhost.crash
27/10/2011 12:44:47.535 Time Out: Idle 18446522154.3 secs; normal due 27/10/2011 13:36, micro due 27/10/2011 12:58
27/10/2011 12:44:47.537 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:44:47.537 Time Out: ...resetting normal timer
27/10/2011 12:44:47.539 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:36
27/10/2011 12:44:47.540 Time Out: ...resetting micro timer
27/10/2011 12:44:47.541 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:58
27/10/2011 12:44:50.774 com.apple.launchd: (com.aladdin.hasplmd[8012]) Job appears to have crashed: Bus error: 10
27/10/2011 12:44:50.774 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:44:50.788 ReportCrash: Saved crash report for hasplmd[8012] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124450_localhost.crash
27/10/2011 12:45:00.968 com.apple.launchd: (com.aladdin.hasplmd[8013]) Job appears to have crashed: Bus error: 10
27/10/2011 12:45:00.968 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:45:00.981 ReportCrash: Saved crash report for hasplmd[8013] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124500_localhost.crash
27/10/2011 12:45:02.536 Time Out: Idle 18446522169.3 secs; normal due 27/10/2011 13:36, micro due 27/10/2011 12:58
27/10/2011 12:45:02.538 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:45:02.539 Time Out: ...resetting normal timer
27/10/2011 12:45:02.540 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:37
27/10/2011 12:45:02.541 Time Out: ...resetting micro timer
27/10/2011 12:45:02.543 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:59
27/10/2011 12:45:11.000 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:45:11.181 com.apple.launchd: (com.aladdin.hasplmd[8014]) Job appears to have crashed: Bus error: 10
27/10/2011 12:45:11.181 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:45:11.227 ReportCrash: Saved crash report for hasplmd[8014] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124511_localhost.crash
27/10/2011 12:45:17.535 Time Out: Idle 18446522184.3 secs; normal due 27/10/2011 13:37, micro due 27/10/2011 12:59
27/10/2011 12:45:17.538 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:45:17.538 Time Out: ...resetting normal timer
27/10/2011 12:45:17.540 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:37
27/10/2011 12:45:17.541 Time Out: ...resetting micro timer
27/10/2011 12:45:17.542 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:59
27/10/2011 12:45:21.379 com.apple.launchd: (com.aladdin.hasplmd[8016]) Job appears to have crashed: Bus error: 10
27/10/2011 12:45:21.379 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:45:21.395 ReportCrash: Saved crash report for hasplmd[8016] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124521_localhost.crash
27/10/2011 12:45:31.572 com.apple.launchd: (com.aladdin.hasplmd[8017]) Job appears to have crashed: Bus error: 10
27/10/2011 12:45:31.572 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:45:31.585 ReportCrash: Saved crash report for hasplmd[8017] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124531_localhost.crash
27/10/2011 12:45:32.536 Time Out: Idle 18446522199.3 secs; normal due 27/10/2011 13:37, micro due 27/10/2011 12:59
27/10/2011 12:45:32.538 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:45:32.538 Time Out: ...resetting normal timer
27/10/2011 12:45:32.540 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:37
27/10/2011 12:45:32.541 Time Out: ...resetting micro timer
27/10/2011 12:45:32.543 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:59
27/10/2011 12:45:41.768 com.apple.launchd: (com.aladdin.hasplmd[8018]) Job appears to have crashed: Bus error: 10
27/10/2011 12:45:41.768 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:45:41.786 ReportCrash: Saved crash report for hasplmd[8018] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124541_localhost.crash
27/10/2011 12:45:47.536 Time Out: Idle 18446522214.3 secs; normal due 27/10/2011 13:37, micro due 27/10/2011 12:59
27/10/2011 12:45:47.538 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:45:47.539 Time Out: ...resetting normal timer
27/10/2011 12:45:47.541 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:37
27/10/2011 12:45:47.541 Time Out: ...resetting micro timer
27/10/2011 12:45:47.543 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 12:59
27/10/2011 12:45:51.966 com.apple.launchd: (com.aladdin.hasplmd[8019]) Job appears to have crashed: Bus error: 10
27/10/2011 12:45:51.966 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:45:51.982 ReportCrash: Saved crash report for hasplmd[8019] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124551_localhost.crash
27/10/2011 12:46:02.161 com.apple.launchd: (com.aladdin.hasplmd[8020]) Job appears to have crashed: Bus error: 10
27/10/2011 12:46:02.161 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:46:02.177 ReportCrash: Saved crash report for hasplmd[8020] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124602_localhost.crash
27/10/2011 12:46:02.536 Time Out: Idle 18446522229.3 secs; normal due 27/10/2011 13:37, micro due 27/10/2011 12:59
27/10/2011 12:46:02.538 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:46:02.539 Time Out: ...resetting normal timer
27/10/2011 12:46:02.541 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:38
27/10/2011 12:46:02.542 Time Out: ...resetting micro timer
27/10/2011 12:46:02.544 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:00
27/10/2011 12:46:12.193 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:46:12.376 com.apple.launchd: (com.aladdin.hasplmd[8021]) Job appears to have crashed: Bus error: 10
27/10/2011 12:46:12.376 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:46:12.428 ReportCrash: Saved crash report for hasplmd[8021] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124612_localhost.crash
27/10/2011 12:46:17.536 Time Out: Idle 18446522244.3 secs; normal due 27/10/2011 13:38, micro due 27/10/2011 13:00
27/10/2011 12:46:17.538 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:46:17.538 Time Out: ...resetting normal timer
27/10/2011 12:46:17.540 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:38
27/10/2011 12:46:17.541 Time Out: ...resetting micro timer
27/10/2011 12:46:17.542 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:00
27/10/2011 12:46:22.576 com.apple.launchd: (com.aladdin.hasplmd[8023]) Job appears to have crashed: Bus error: 10
27/10/2011 12:46:22.576 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:46:22.591 ReportCrash: Saved crash report for hasplmd[8023] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124622_localhost.crash
27/10/2011 12:46:32.536 Time Out: Idle 18446522259.3 secs; normal due 27/10/2011 13:38, micro due 27/10/2011 13:00
27/10/2011 12:46:32.538 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:46:32.538 Time Out: ...resetting normal timer
27/10/2011 12:46:32.540 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:38
27/10/2011 12:46:32.541 Time Out: ...resetting micro timer
27/10/2011 12:46:32.542 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:00
27/10/2011 12:46:32.764 com.apple.launchd: (com.aladdin.hasplmd[8024]) Job appears to have crashed: Bus error: 10
27/10/2011 12:46:32.764 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:46:32.777 ReportCrash: Saved crash report for hasplmd[8024] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124632_localhost.crash
27/10/2011 12:46:42.960 com.apple.launchd: (com.aladdin.hasplmd[8025]) Job appears to have crashed: Bus error: 10
27/10/2011 12:46:42.960 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:46:42.973 ReportCrash: Saved crash report for hasplmd[8025] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124642_localhost.crash
27/10/2011 12:46:47.536 Time Out: Idle 18446522274.3 secs; normal due 27/10/2011 13:38, micro due 27/10/2011 13:00
27/10/2011 12:46:47.537 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:46:47.538 Time Out: ...resetting normal timer
27/10/2011 12:46:47.540 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:38
27/10/2011 12:46:47.540 Time Out: ...resetting micro timer
27/10/2011 12:46:47.542 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:00
27/10/2011 12:46:53.152 com.apple.launchd: (com.aladdin.hasplmd[8026]) Job appears to have crashed: Bus error: 10
27/10/2011 12:46:53.152 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:46:53.165 ReportCrash: Saved crash report for hasplmd[8026] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124653_localhost.crash
27/10/2011 12:47:02.536 Time Out: Idle 18446522289.3 secs; normal due 27/10/2011 13:38, micro due 27/10/2011 13:00
27/10/2011 12:47:02.539 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:47:02.539 Time Out: ...resetting normal timer
27/10/2011 12:47:02.541 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:39
27/10/2011 12:47:02.542 Time Out: ...resetting micro timer
27/10/2011 12:47:02.544 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:01
27/10/2011 12:47:03.351 com.apple.launchd: (com.aladdin.hasplmd[8027]) Job appears to have crashed: Bus error: 10
27/10/2011 12:47:03.351 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:47:03.370 ReportCrash: Saved crash report for hasplmd[8027] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124703_localhost.crash
27/10/2011 12:47:13.386 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:47:13.564 com.apple.launchd: (com.aladdin.hasplmd[8028]) Job appears to have crashed: Bus error: 10
27/10/2011 12:47:13.564 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:47:13.610 ReportCrash: Saved crash report for hasplmd[8028] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124713_localhost.crash
27/10/2011 12:47:17.537 Time Out: Idle 18446522304.3 secs; normal due 27/10/2011 13:39, micro due 27/10/2011 13:01
27/10/2011 12:47:17.539 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:47:17.540 Time Out: ...resetting normal timer
27/10/2011 12:47:17.542 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:39
27/10/2011 12:47:17.543 Time Out: ...resetting micro timer
27/10/2011 12:47:17.545 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:01
27/10/2011 12:47:23.759 com.apple.launchd: (com.aladdin.hasplmd[8030]) Job appears to have crashed: Bus error: 10
27/10/2011 12:47:23.759 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:47:23.773 ReportCrash: Saved crash report for hasplmd[8030] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124723_localhost.crash
27/10/2011 12:47:32.537 Time Out: Idle 18446522319.3 secs; normal due 27/10/2011 13:39, micro due 27/10/2011 13:01
27/10/2011 12:47:32.539 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:47:32.540 Time Out: ...resetting normal timer
27/10/2011 12:47:32.541 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:39
27/10/2011 12:47:32.542 Time Out: ...resetting micro timer
27/10/2011 12:47:32.543 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:01
27/10/2011 12:47:33.957 com.apple.launchd: (com.aladdin.hasplmd[8031]) Job appears to have crashed: Bus error: 10
27/10/2011 12:47:33.957 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:47:33.970 ReportCrash: Saved crash report for hasplmd[8031] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124733_localhost.crash
27/10/2011 12:47:44.157 com.apple.launchd: (com.aladdin.hasplmd[8032]) Job appears to have crashed: Bus error: 10
27/10/2011 12:47:44.157 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:47:44.170 ReportCrash: Saved crash report for hasplmd[8032] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124744_localhost.crash
27/10/2011 12:47:47.537 Time Out: Idle 18446522334.3 secs; normal due 27/10/2011 13:39, micro due 27/10/2011 13:01
27/10/2011 12:47:47.539 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:47:47.540 Time Out: ...resetting normal timer
27/10/2011 12:47:47.542 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:39
27/10/2011 12:47:47.543 Time Out: ...resetting micro timer
27/10/2011 12:47:47.544 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:01
27/10/2011 12:47:54.349 com.apple.launchd: (com.aladdin.hasplmd[8033]) Job appears to have crashed: Bus error: 10
27/10/2011 12:47:54.350 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:47:54.363 ReportCrash: Saved crash report for hasplmd[8033] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124754_localhost.crash
27/10/2011 12:48:02.537 Time Out: Idle 18446522349.3 secs; normal due 27/10/2011 13:39, micro due 27/10/2011 13:01
27/10/2011 12:48:02.538 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:48:02.539 Time Out: ...resetting normal timer
27/10/2011 12:48:02.541 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:40
27/10/2011 12:48:02.541 Time Out: ...resetting micro timer
27/10/2011 12:48:02.543 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:02
27/10/2011 12:48:04.550 com.apple.launchd: (com.aladdin.hasplmd[8034]) Job appears to have crashed: Bus error: 10
27/10/2011 12:48:04.550 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:48:04.565 ReportCrash: Saved crash report for hasplmd[8034] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124804_localhost.crash
27/10/2011 12:48:14.583 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:48:14.761 com.apple.launchd: (com.aladdin.hasplmd[8035]) Job appears to have crashed: Bus error: 10
27/10/2011 12:48:14.761 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:48:14.809 ReportCrash: Saved crash report for hasplmd[8035] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124814_localhost.crash
27/10/2011 12:48:17.537 Time Out: Idle 18446522364.3 secs; normal due 27/10/2011 13:40, micro due 27/10/2011 13:02
27/10/2011 12:48:17.539 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:48:17.540 Time Out: ...resetting normal timer
27/10/2011 12:48:17.542 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:40
27/10/2011 12:48:17.543 Time Out: ...resetting micro timer
27/10/2011 12:48:17.544 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:02
27/10/2011 12:48:24.965 com.apple.launchd: (com.aladdin.hasplmd[8037]) Job appears to have crashed: Bus error: 10
27/10/2011 12:48:24.965 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:48:24.978 ReportCrash: Saved crash report for hasplmd[8037] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124824_localhost.crash
27/10/2011 12:48:32.537 Time Out: Idle 18446522379.3 secs; normal due 27/10/2011 13:40, micro due 27/10/2011 13:02
27/10/2011 12:48:32.539 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:48:32.539 Time Out: ...resetting normal timer
27/10/2011 12:48:32.541 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:40
27/10/2011 12:48:32.541 Time Out: ...resetting micro timer
27/10/2011 12:48:32.543 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:02
27/10/2011 12:48:35.170 com.apple.launchd: (com.aladdin.hasplmd[8038]) Job appears to have crashed: Bus error: 10
27/10/2011 12:48:35.170 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:48:35.186 ReportCrash: Saved crash report for hasplmd[8038] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124835_localhost.crash
27/10/2011 12:48:45.365 com.apple.launchd: (com.aladdin.hasplmd[8039]) Job appears to have crashed: Bus error: 10
27/10/2011 12:48:45.365 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:48:45.379 ReportCrash: Saved crash report for hasplmd[8039] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124845_localhost.crash
27/10/2011 12:48:47.538 Time Out: Idle 18446522394.3 secs; normal due 27/10/2011 13:40, micro due 27/10/2011 13:02
27/10/2011 12:48:47.539 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:48:47.540 Time Out: ...resetting normal timer
27/10/2011 12:48:47.542 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:40
27/10/2011 12:48:47.542 Time Out: ...resetting micro timer
27/10/2011 12:48:47.544 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:02
27/10/2011 12:48:55.563 com.apple.launchd: (com.aladdin.hasplmd[8040]) Job appears to have crashed: Bus error: 10
27/10/2011 12:48:55.563 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:48:55.576 ReportCrash: Saved crash report for hasplmd[8040] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124855_localhost.crash
27/10/2011 12:49:02.538 Time Out: Idle 18446522409.3 secs; normal due 27/10/2011 13:40, micro due 27/10/2011 13:02
27/10/2011 12:49:02.540 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:49:02.540 Time Out: ...resetting normal timer
27/10/2011 12:49:02.542 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:41
27/10/2011 12:49:02.543 Time Out: ...resetting micro timer
27/10/2011 12:49:02.544 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:03
27/10/2011 12:49:05.759 com.apple.launchd: (com.aladdin.hasplmd[8041]) Job appears to have crashed: Bus error: 10
27/10/2011 12:49:05.759 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:49:05.772 ReportCrash: Saved crash report for hasplmd[8041] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124905_localhost.crash
27/10/2011 12:49:15.791 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:49:15.972 com.apple.launchd: (com.aladdin.hasplmd[8042]) Job appears to have crashed: Bus error: 10
27/10/2011 12:49:15.972 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:49:16.021 ReportCrash: Saved crash report for hasplmd[8042] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124916_localhost.crash
27/10/2011 12:49:17.538 Time Out: Idle 18446522424.3 secs; normal due 27/10/2011 13:41, micro due 27/10/2011 13:03
27/10/2011 12:49:17.540 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:49:17.541 Time Out: ...resetting normal timer
27/10/2011 12:49:17.543 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:41
27/10/2011 12:49:17.544 Time Out: ...resetting micro timer
27/10/2011 12:49:17.545 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:03
27/10/2011 12:49:26.190 com.apple.launchd: (com.aladdin.hasplmd[8044]) Job appears to have crashed: Bus error: 10
27/10/2011 12:49:26.190 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:49:26.203 ReportCrash: Saved crash report for hasplmd[8044] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124926_localhost.crash
27/10/2011 12:49:32.538 Time Out: Idle 18446522439.3 secs; normal due 27/10/2011 13:41, micro due 27/10/2011 13:03
27/10/2011 12:49:32.541 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:49:32.541 Time Out: ...resetting normal timer
27/10/2011 12:49:32.543 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:41
27/10/2011 12:49:32.544 Time Out: ...resetting micro timer
27/10/2011 12:49:32.545 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:03
27/10/2011 12:49:36.382 com.apple.launchd: (com.aladdin.hasplmd[8045]) Job appears to have crashed: Bus error: 10
27/10/2011 12:49:36.382 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:49:36.396 ReportCrash: Saved crash report for hasplmd[8045] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124936_localhost.crash
27/10/2011 12:49:46.576 com.apple.launchd: (com.aladdin.hasplmd[8046]) Job appears to have crashed: Bus error: 10
27/10/2011 12:49:46.576 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:49:46.594 ReportCrash: Saved crash report for hasplmd[8046] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124946_localhost.crash
27/10/2011 12:49:47.539 Time Out: Idle 18446522454.3 secs; normal due 27/10/2011 13:41, micro due 27/10/2011 13:03
27/10/2011 12:49:47.541 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:49:47.542 Time Out: ...resetting normal timer
27/10/2011 12:49:47.543 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:41
27/10/2011 12:49:47.544 Time Out: ...resetting micro timer
27/10/2011 12:49:47.545 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:03
27/10/2011 12:49:56.773 com.apple.launchd: (com.aladdin.hasplmd[8047]) Job appears to have crashed: Bus error: 10
27/10/2011 12:49:56.773 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:49:56.789 ReportCrash: Saved crash report for hasplmd[8047] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-124956_localhost.crash
27/10/2011 12:50:02.539 Time Out: Idle 18446522469.3 secs; normal due 27/10/2011 13:41, micro due 27/10/2011 13:03
27/10/2011 12:50:02.541 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:50:02.541 Time Out: ...resetting normal timer
27/10/2011 12:50:02.543 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:42
27/10/2011 12:50:02.544 Time Out: ...resetting micro timer
27/10/2011 12:50:02.546 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:04
27/10/2011 12:50:06.965 com.apple.launchd: (com.aladdin.hasplmd[8048]) Job appears to have crashed: Bus error: 10
27/10/2011 12:50:06.965 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:50:06.978 ReportCrash: Saved crash report for hasplmd[8048] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125006_localhost.crash
27/10/2011 12:50:17.002 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:50:17.185 com.apple.launchd: (com.aladdin.hasplmd[8049]) Job appears to have crashed: Bus error: 10
27/10/2011 12:50:17.185 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:50:17.232 ReportCrash: Saved crash report for hasplmd[8049] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125017_localhost.crash
27/10/2011 12:50:17.539 Time Out: Idle 18446522484.3 secs; normal due 27/10/2011 13:42, micro due 27/10/2011 13:04
27/10/2011 12:50:17.541 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:50:17.542 Time Out: ...resetting normal timer
27/10/2011 12:50:17.544 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:42
27/10/2011 12:50:17.544 Time Out: ...resetting micro timer
27/10/2011 12:50:17.546 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:04
27/10/2011 12:50:27.390 com.apple.launchd: (com.aladdin.hasplmd[8052]) Job appears to have crashed: Bus error: 10
27/10/2011 12:50:27.390 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:50:27.404 ReportCrash: Saved crash report for hasplmd[8052] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125027_localhost.crash
27/10/2011 12:50:32.539 Time Out: Idle 18446522499.3 secs; normal due 27/10/2011 13:42, micro due 27/10/2011 13:04
27/10/2011 12:50:32.541 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:50:32.542 Time Out: ...resetting normal timer
27/10/2011 12:50:32.544 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:42
27/10/2011 12:50:32.545 Time Out: ...resetting micro timer
27/10/2011 12:50:32.547 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:04
27/10/2011 12:50:37.583 com.apple.launchd: (com.aladdin.hasplmd[8053]) Job appears to have crashed: Bus error: 10
27/10/2011 12:50:37.583 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:50:37.597 ReportCrash: Saved crash report for hasplmd[8053] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125037_localhost.crash
27/10/2011 12:50:47.539 Time Out: Idle 18446522514.3 secs; normal due 27/10/2011 13:42, micro due 27/10/2011 13:04
27/10/2011 12:50:47.541 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:50:47.542 Time Out: ...resetting normal timer
27/10/2011 12:50:47.544 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:42
27/10/2011 12:50:47.544 Time Out: ...resetting micro timer
27/10/2011 12:50:47.546 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:04
27/10/2011 12:50:47.803 com.apple.launchd: (com.aladdin.hasplmd[8054]) Job appears to have crashed: Bus error: 10
27/10/2011 12:50:47.803 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:50:47.821 ReportCrash: Saved crash report for hasplmd[8054] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125047_localhost.crash
27/10/2011 12:50:58.001 com.apple.launchd: (com.aladdin.hasplmd[8055]) Job appears to have crashed: Bus error: 10
27/10/2011 12:50:58.001 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:50:58.014 ReportCrash: Saved crash report for hasplmd[8055] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125058_localhost.crash
27/10/2011 12:51:02.540 Time Out: Idle 18446522529.3 secs; normal due 27/10/2011 13:42, micro due 27/10/2011 13:04
27/10/2011 12:51:02.542 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:51:02.542 Time Out: ...resetting normal timer
27/10/2011 12:51:02.544 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:43
27/10/2011 12:51:02.545 Time Out: ...resetting micro timer
27/10/2011 12:51:02.547 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:05
27/10/2011 12:51:08.220 com.apple.launchd: (com.aladdin.hasplmd[8056]) Job appears to have crashed: Bus error: 10
27/10/2011 12:51:08.220 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:51:08.233 ReportCrash: Saved crash report for hasplmd[8056] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125108_localhost.crash
27/10/2011 12:51:17.539 Time Out: Idle 18446522544.3 secs; normal due 27/10/2011 13:43, micro due 27/10/2011 13:05
27/10/2011 12:51:17.540 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:51:17.540 Time Out: ...resetting normal timer
27/10/2011 12:51:17.542 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:43
27/10/2011 12:51:17.542 Time Out: ...resetting micro timer
27/10/2011 12:51:17.543 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:05
27/10/2011 12:51:18.251 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:51:18.433 com.apple.launchd: (com.aladdin.hasplmd[8057]) Job appears to have crashed: Bus error: 10
27/10/2011 12:51:18.433 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:51:18.477 ReportCrash: Saved crash report for hasplmd[8057] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125118_localhost.crash
27/10/2011 12:51:28.631 com.apple.launchd: (com.aladdin.hasplmd[8059]) Job appears to have crashed: Bus error: 10
27/10/2011 12:51:28.631 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:51:28.648 ReportCrash: Saved crash report for hasplmd[8059] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125128_localhost.crash
27/10/2011 12:51:32.539 Time Out: Idle 18446522559.3 secs; normal due 27/10/2011 13:43, micro due 27/10/2011 13:05
27/10/2011 12:51:32.541 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:51:32.542 Time Out: ...resetting normal timer
27/10/2011 12:51:32.543 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:43
27/10/2011 12:51:32.544 Time Out: ...resetting micro timer
27/10/2011 12:51:32.546 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:05
27/10/2011 12:51:38.826 com.apple.launchd: (com.aladdin.hasplmd[8060]) Job appears to have crashed: Bus error: 10
27/10/2011 12:51:38.826 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:51:38.840 ReportCrash: Saved crash report for hasplmd[8060] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125138_localhost.crash
27/10/2011 12:51:47.540 Time Out: Idle 18446522574.3 secs; normal due 27/10/2011 13:43, micro due 27/10/2011 13:05
27/10/2011 12:51:47.542 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:51:47.543 Time Out: ...resetting normal timer
27/10/2011 12:51:47.545 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:43
27/10/2011 12:51:47.545 Time Out: ...resetting micro timer
27/10/2011 12:51:47.547 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:05
27/10/2011 12:51:49.022 com.apple.launchd: (com.aladdin.hasplmd[8061]) Job appears to have crashed: Bus error: 10
27/10/2011 12:51:49.022 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:51:49.038 ReportCrash: Saved crash report for hasplmd[8061] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125149_localhost.crash
27/10/2011 12:51:59.223 com.apple.launchd: (com.aladdin.hasplmd[8062]) Job appears to have crashed: Bus error: 10
27/10/2011 12:51:59.223 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:51:59.237 ReportCrash: Saved crash report for hasplmd[8062] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125159_localhost.crash
27/10/2011 12:52:02.540 Time Out: Idle 18446522589.3 secs; normal due 27/10/2011 13:43, micro due 27/10/2011 13:05
27/10/2011 12:52:02.542 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:52:02.543 Time Out: ...resetting normal timer
27/10/2011 12:52:02.545 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:44
27/10/2011 12:52:02.546 Time Out: ...resetting micro timer
27/10/2011 12:52:02.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:06
27/10/2011 12:52:09.414 com.apple.launchd: (com.aladdin.hasplmd[8063]) Job appears to have crashed: Bus error: 10
27/10/2011 12:52:09.414 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:52:09.431 ReportCrash: Saved crash report for hasplmd[8063] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125209_localhost.crash
27/10/2011 12:52:15.052 loginwindow: CheckBootstrap(): bootstrap_look_up(): 0x44e: Bootstrap Unknown Service
27/10/2011 12:52:17.539 Time Out: Idle 18446522604.3 secs; normal due 27/10/2011 13:44, micro due 27/10/2011 13:06
27/10/2011 12:52:17.540 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:52:17.541 Time Out: ...resetting normal timer
27/10/2011 12:52:17.542 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:44
27/10/2011 12:52:17.542 Time Out: ...resetting micro timer
27/10/2011 12:52:17.544 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:06
27/10/2011 12:52:19.443 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:52:19.626 com.apple.launchd: (com.aladdin.hasplmd[8064]) Job appears to have crashed: Bus error: 10
27/10/2011 12:52:19.626 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:52:19.672 ReportCrash: Saved crash report for hasplmd[8064] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125219_localhost.crash
27/10/2011 12:52:29.826 com.apple.launchd: (com.aladdin.hasplmd[8066]) Job appears to have crashed: Bus error: 10
27/10/2011 12:52:29.826 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:52:29.840 ReportCrash: Saved crash report for hasplmd[8066] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125229_localhost.crash
27/10/2011 12:52:32.541 Time Out: Idle 18446522619.3 secs; normal due 27/10/2011 13:44, micro due 27/10/2011 13:06
27/10/2011 12:52:32.542 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:52:32.543 Time Out: ...resetting normal timer
27/10/2011 12:52:32.545 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:44
27/10/2011 12:52:32.546 Time Out: ...resetting micro timer
27/10/2011 12:52:32.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:06
27/10/2011 12:52:40.030 com.apple.launchd: (com.aladdin.hasplmd[8067]) Job appears to have crashed: Bus error: 10
27/10/2011 12:52:40.030 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:52:40.047 ReportCrash: Saved crash report for hasplmd[8067] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125240_localhost.crash
27/10/2011 12:52:47.540 Time Out: Idle 18446522634.3 secs; normal due 27/10/2011 13:44, micro due 27/10/2011 13:06
27/10/2011 12:52:47.541 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:52:47.542 Time Out: ...resetting normal timer
27/10/2011 12:52:47.543 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:44
27/10/2011 12:52:47.543 Time Out: ...resetting micro timer
27/10/2011 12:52:47.544 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:06
27/10/2011 12:52:50.230 com.apple.launchd: (com.aladdin.hasplmd[8068]) Job appears to have crashed: Bus error: 10
27/10/2011 12:52:50.230 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:52:50.244 ReportCrash: Saved crash report for hasplmd[8068] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125250_localhost.crash
27/10/2011 12:53:00.431 com.apple.launchd: (com.aladdin.hasplmd[8069]) Job appears to have crashed: Bus error: 10
27/10/2011 12:53:00.431 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:53:00.447 ReportCrash: Saved crash report for hasplmd[8069] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125300_localhost.crash
27/10/2011 12:53:02.541 Time Out: Idle 18446522649.3 secs; normal due 27/10/2011 13:44, micro due 27/10/2011 13:06
27/10/2011 12:53:02.543 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:53:02.543 Time Out: ...resetting normal timer
27/10/2011 12:53:02.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:45
27/10/2011 12:53:02.546 Time Out: ...resetting micro timer
27/10/2011 12:53:02.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:07
27/10/2011 12:53:10.628 com.apple.launchd: (com.aladdin.hasplmd[8070]) Job appears to have crashed: Bus error: 10
27/10/2011 12:53:10.628 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:53:10.641 ReportCrash: Saved crash report for hasplmd[8070] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125310_localhost.crash
27/10/2011 12:53:17.541 Time Out: Idle 18446522664.3 secs; normal due 27/10/2011 13:45, micro due 27/10/2011 13:07
27/10/2011 12:53:17.543 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:53:17.544 Time Out: ...resetting normal timer
27/10/2011 12:53:17.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:45
27/10/2011 12:53:17.546 Time Out: ...resetting micro timer
27/10/2011 12:53:17.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:07
27/10/2011 12:53:20.661 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:53:20.847 com.apple.launchd: (com.aladdin.hasplmd[8071]) Job appears to have crashed: Bus error: 10
27/10/2011 12:53:20.847 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:53:20.893 ReportCrash: Saved crash report for hasplmd[8071] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125320_localhost.crash
27/10/2011 12:53:31.041 com.apple.launchd: (com.aladdin.hasplmd[8073]) Job appears to have crashed: Bus error: 10
27/10/2011 12:53:31.041 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:53:31.054 ReportCrash: Saved crash report for hasplmd[8073] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125331_localhost.crash
27/10/2011 12:53:32.541 Time Out: Idle 18446522679.3 secs; normal due 27/10/2011 13:45, micro due 27/10/2011 13:07
27/10/2011 12:53:32.543 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:53:32.544 Time Out: ...resetting normal timer
27/10/2011 12:53:32.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:45
27/10/2011 12:53:32.547 Time Out: ...resetting micro timer
27/10/2011 12:53:32.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:07
27/10/2011 12:53:41.242 com.apple.launchd: (com.aladdin.hasplmd[8074]) Job appears to have crashed: Bus error: 10
27/10/2011 12:53:41.242 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:53:41.255 ReportCrash: Saved crash report for hasplmd[8074] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125341_localhost.crash
27/10/2011 12:53:47.540 Time Out: Idle 18446522694.3 secs; normal due 27/10/2011 13:45, micro due 27/10/2011 13:07
27/10/2011 12:53:47.541 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:53:47.542 Time Out: ...resetting normal timer
27/10/2011 12:53:47.543 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:45
27/10/2011 12:53:47.543 Time Out: ...resetting micro timer
27/10/2011 12:53:47.544 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:07
27/10/2011 12:53:51.446 com.apple.launchd: (com.aladdin.hasplmd[8075]) Job appears to have crashed: Bus error: 10
27/10/2011 12:53:51.446 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:53:51.463 ReportCrash: Saved crash report for hasplmd[8075] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125351_localhost.crash
27/10/2011 12:54:01.651 com.apple.launchd: (com.aladdin.hasplmd[8079]) Job appears to have crashed: Bus error: 10
27/10/2011 12:54:01.651 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:54:01.667 ReportCrash: Saved crash report for hasplmd[8079] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125401_localhost.crash
27/10/2011 12:54:02.540 Time Out: Idle 18446522709.3 secs; normal due 27/10/2011 13:45, micro due 27/10/2011 13:07
27/10/2011 12:54:02.541 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:54:02.542 Time Out: ...resetting normal timer
27/10/2011 12:54:02.543 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:46
27/10/2011 12:54:02.543 Time Out: ...resetting micro timer
27/10/2011 12:54:02.544 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:08
27/10/2011 12:54:11.845 com.apple.launchd: (com.aladdin.hasplmd[8080]) Job appears to have crashed: Bus error: 10
27/10/2011 12:54:11.845 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:54:11.858 ReportCrash: Saved crash report for hasplmd[8080] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125411_localhost.crash
27/10/2011 12:54:17.544 Time Out: Idle 18446522724.3 secs; normal due 27/10/2011 13:46, micro due 27/10/2011 13:08
27/10/2011 12:54:17.545 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:54:17.546 Time Out: ...resetting normal timer
27/10/2011 12:54:17.547 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:46
27/10/2011 12:54:17.548 Time Out: ...resetting micro timer
27/10/2011 12:54:17.549 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:08
27/10/2011 12:54:21.875 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:54:22.057 com.apple.launchd: (com.aladdin.hasplmd[8081]) Job appears to have crashed: Bus error: 10
27/10/2011 12:54:22.057 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:54:22.107 ReportCrash: Saved crash report for hasplmd[8081] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125422_localhost.crash
27/10/2011 12:54:32.254 com.apple.launchd: (com.aladdin.hasplmd[8083]) Job appears to have crashed: Bus error: 10
27/10/2011 12:54:32.254 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:54:32.269 ReportCrash: Saved crash report for hasplmd[8083] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125432_localhost.crash
27/10/2011 12:54:32.542 Time Out: Idle 18446522739.3 secs; normal due 27/10/2011 13:46, micro due 27/10/2011 13:08
27/10/2011 12:54:32.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:54:32.544 Time Out: ...resetting normal timer
27/10/2011 12:54:32.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:46
27/10/2011 12:54:32.547 Time Out: ...resetting micro timer
27/10/2011 12:54:32.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:08
27/10/2011 12:54:42.449 com.apple.launchd: (com.aladdin.hasplmd[8084]) Job appears to have crashed: Bus error: 10
27/10/2011 12:54:42.449 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:54:42.463 ReportCrash: Saved crash report for hasplmd[8084] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125442_localhost.crash
27/10/2011 12:54:47.541 Time Out: Idle 18446522754.3 secs; normal due 27/10/2011 13:46, micro due 27/10/2011 13:08
27/10/2011 12:54:47.543 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:54:47.544 Time Out: ...resetting normal timer
27/10/2011 12:54:47.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:46
27/10/2011 12:54:47.546 Time Out: ...resetting micro timer
27/10/2011 12:54:47.550 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:08
27/10/2011 12:54:52.646 com.apple.launchd: (com.aladdin.hasplmd[8085]) Job appears to have crashed: Bus error: 10
27/10/2011 12:54:52.646 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:54:52.659 ReportCrash: Saved crash report for hasplmd[8085] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125452_localhost.crash
27/10/2011 12:55:02.542 Time Out: Idle 18446522769.3 secs; normal due 27/10/2011 13:46, micro due 27/10/2011 13:08
27/10/2011 12:55:02.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:55:02.545 Time Out: ...resetting normal timer
27/10/2011 12:55:02.547 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:47
27/10/2011 12:55:02.548 Time Out: ...resetting micro timer
27/10/2011 12:55:02.549 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:09
27/10/2011 12:55:02.841 com.apple.launchd: (com.aladdin.hasplmd[8086]) Job appears to have crashed: Bus error: 10
27/10/2011 12:55:02.841 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:55:02.854 ReportCrash: Saved crash report for hasplmd[8086] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125502_localhost.crash
27/10/2011 12:55:13.038 com.apple.launchd: (com.aladdin.hasplmd[8087]) Job appears to have crashed: Bus error: 10
27/10/2011 12:55:13.038 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:55:13.054 ReportCrash: Saved crash report for hasplmd[8087] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125513_localhost.crash
27/10/2011 12:55:17.542 Time Out: Idle 18446522784.3 secs; normal due 27/10/2011 13:47, micro due 27/10/2011 13:09
27/10/2011 12:55:17.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:55:17.545 Time Out: ...resetting normal timer
27/10/2011 12:55:17.547 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:47
27/10/2011 12:55:17.548 Time Out: ...resetting micro timer
27/10/2011 12:55:17.550 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:09
27/10/2011 12:55:23.067 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:55:23.249 com.apple.launchd: (com.aladdin.hasplmd[8090]) Job appears to have crashed: Bus error: 10
27/10/2011 12:55:23.249 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:55:23.297 ReportCrash: Saved crash report for hasplmd[8090] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125523_localhost.crash
27/10/2011 12:55:32.543 Time Out: Idle 18446522799.3 secs; normal due 27/10/2011 13:47, micro due 27/10/2011 13:09
27/10/2011 12:55:32.545 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:55:32.545 Time Out: ...resetting normal timer
27/10/2011 12:55:32.548 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:47
27/10/2011 12:55:32.548 Time Out: ...resetting micro timer
27/10/2011 12:55:32.550 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:09
27/10/2011 12:55:33.458 com.apple.launchd: (com.aladdin.hasplmd[8092]) Job appears to have crashed: Bus error: 10
27/10/2011 12:55:33.458 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:55:33.472 ReportCrash: Saved crash report for hasplmd[8092] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125533_localhost.crash
27/10/2011 12:55:43.653 com.apple.launchd: (com.aladdin.hasplmd[8094]) Job appears to have crashed: Bus error: 10
27/10/2011 12:55:43.653 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:55:43.670 ReportCrash: Saved crash report for hasplmd[8094] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125543_localhost.crash
27/10/2011 12:55:47.542 Time Out: Idle 18446522814.3 secs; normal due 27/10/2011 13:47, micro due 27/10/2011 13:09
27/10/2011 12:55:47.543 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:55:47.543 Time Out: ...resetting normal timer
27/10/2011 12:55:47.544 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:47
27/10/2011 12:55:47.545 Time Out: ...resetting micro timer
27/10/2011 12:55:47.546 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:09
27/10/2011 12:55:53.851 com.apple.launchd: (com.aladdin.hasplmd[8096]) Job appears to have crashed: Bus error: 10
27/10/2011 12:55:53.851 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:55:53.864 ReportCrash: Saved crash report for hasplmd[8096] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125553_localhost.crash
27/10/2011 12:56:02.542 Time Out: Idle 18446522829.3 secs; normal due 27/10/2011 13:47, micro due 27/10/2011 13:09
27/10/2011 12:56:02.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:56:02.544 Time Out: ...resetting normal timer
27/10/2011 12:56:02.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:48
27/10/2011 12:56:02.547 Time Out: ...resetting micro timer
27/10/2011 12:56:02.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:10
27/10/2011 12:56:04.051 com.apple.launchd: (com.aladdin.hasplmd[8097]) Job appears to have crashed: Bus error: 10
27/10/2011 12:56:04.051 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:56:04.065 ReportCrash: Saved crash report for hasplmd[8097] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125604_localhost.crash
27/10/2011 12:56:14.251 com.apple.launchd: (com.aladdin.hasplmd[8098]) Job appears to have crashed: Bus error: 10
27/10/2011 12:56:14.251 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:56:14.265 ReportCrash: Saved crash report for hasplmd[8098] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125614_localhost.crash
27/10/2011 12:56:17.542 Time Out: Idle 18446522844.3 secs; normal due 27/10/2011 13:48, micro due 27/10/2011 13:10
27/10/2011 12:56:17.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:56:17.545 Time Out: ...resetting normal timer
27/10/2011 12:56:17.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:48
27/10/2011 12:56:17.547 Time Out: ...resetting micro timer
27/10/2011 12:56:17.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:10
27/10/2011 12:56:24.282 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:56:24.465 com.apple.launchd: (com.aladdin.hasplmd[8100]) Job appears to have crashed: Bus error: 10
27/10/2011 12:56:24.465 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:56:24.513 ReportCrash: Saved crash report for hasplmd[8100] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125624_localhost.crash
27/10/2011 12:56:32.543 Time Out: Idle 18446522859.3 secs; normal due 27/10/2011 13:48, micro due 27/10/2011 13:10
27/10/2011 12:56:32.545 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:56:32.545 Time Out: ...resetting normal timer
27/10/2011 12:56:32.547 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:48
27/10/2011 12:56:32.548 Time Out: ...resetting micro timer
27/10/2011 12:56:32.549 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:10
27/10/2011 12:56:34.719 com.apple.launchd: (com.aladdin.hasplmd[8102]) Job appears to have crashed: Bus error: 10
27/10/2011 12:56:34.719 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:56:34.739 ReportCrash: Saved crash report for hasplmd[8102] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125634_localhost.crash
27/10/2011 12:56:44.950 com.apple.launchd: (com.aladdin.hasplmd[8103]) Job appears to have crashed: Bus error: 10
27/10/2011 12:56:44.950 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:56:44.970 ReportCrash: Saved crash report for hasplmd[8103] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125644_localhost.crash
27/10/2011 12:56:47.542 Time Out: Idle 18446522874.3 secs; normal due 27/10/2011 13:48, micro due 27/10/2011 13:10
27/10/2011 12:56:47.543 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:56:47.544 Time Out: ...resetting normal timer
27/10/2011 12:56:47.545 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:48
27/10/2011 12:56:47.545 Time Out: ...resetting micro timer
27/10/2011 12:56:47.547 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:10
27/10/2011 12:56:55.177 com.apple.launchd: (com.aladdin.hasplmd[8104]) Job appears to have crashed: Bus error: 10
27/10/2011 12:56:55.177 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:56:55.194 ReportCrash: Saved crash report for hasplmd[8104] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125655_localhost.crash
27/10/2011 12:57:02.542 Time Out: Idle 18446522889.3 secs; normal due 27/10/2011 13:48, micro due 27/10/2011 13:10
27/10/2011 12:57:02.543 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:57:02.544 Time Out: ...resetting normal timer
27/10/2011 12:57:02.545 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:49
27/10/2011 12:57:02.546 Time Out: ...resetting micro timer
27/10/2011 12:57:02.547 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:11
27/10/2011 12:57:05.392 com.apple.launchd: (com.aladdin.hasplmd[8105]) Job appears to have crashed: Bus error: 10
27/10/2011 12:57:05.392 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:57:05.406 ReportCrash: Saved crash report for hasplmd[8105] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125705_localhost.crash
27/10/2011 12:57:15.620 com.apple.launchd: (com.aladdin.hasplmd[8106]) Job appears to have crashed: Bus error: 10
27/10/2011 12:57:15.620 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:57:15.637 ReportCrash: Saved crash report for hasplmd[8106] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125715_localhost.crash
27/10/2011 12:57:17.543 Time Out: Idle 18446522904.3 secs; normal due 27/10/2011 13:49, micro due 27/10/2011 13:11
27/10/2011 12:57:17.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:57:17.545 Time Out: ...resetting normal timer
27/10/2011 12:57:17.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:49
27/10/2011 12:57:17.546 Time Out: ...resetting micro timer
27/10/2011 12:57:17.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:11
27/10/2011 12:57:25.650 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:57:25.867 com.apple.launchd: (com.aladdin.hasplmd[8107]) Job appears to have crashed: Bus error: 10
27/10/2011 12:57:25.867 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:57:25.924 ReportCrash: Saved crash report for hasplmd[8107] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125725_localhost.crash
27/10/2011 12:57:32.543 Time Out: Idle 18446522919.3 secs; normal due 27/10/2011 13:49, micro due 27/10/2011 13:11
27/10/2011 12:57:32.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:57:32.545 Time Out: ...resetting normal timer
27/10/2011 12:57:32.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:49
27/10/2011 12:57:32.546 Time Out: ...resetting micro timer
27/10/2011 12:57:32.547 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:11
27/10/2011 12:57:36.078 com.apple.launchd: (com.aladdin.hasplmd[8109]) Job appears to have crashed: Bus error: 10
27/10/2011 12:57:36.078 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:57:36.099 ReportCrash: Saved crash report for hasplmd[8109] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125736_localhost.crash
27/10/2011 12:57:46.272 com.apple.launchd: (com.aladdin.hasplmd[8110]) Job appears to have crashed: Bus error: 10
27/10/2011 12:57:46.272 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:57:46.289 ReportCrash: Saved crash report for hasplmd[8110] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125746_localhost.crash
27/10/2011 12:57:47.543 Time Out: Idle 18446522934.3 secs; normal due 27/10/2011 13:49, micro due 27/10/2011 13:11
27/10/2011 12:57:47.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:57:47.544 Time Out: ...resetting normal timer
27/10/2011 12:57:47.545 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:49
27/10/2011 12:57:47.546 Time Out: ...resetting micro timer
27/10/2011 12:57:47.547 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:11
27/10/2011 12:57:56.482 com.apple.launchd: (com.aladdin.hasplmd[8111]) Job appears to have crashed: Bus error: 10
27/10/2011 12:57:56.482 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:57:56.498 ReportCrash: Saved crash report for hasplmd[8111] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125756_localhost.crash
27/10/2011 12:58:02.543 Time Out: Idle 18446522949.3 secs; normal due 27/10/2011 13:49, micro due 27/10/2011 13:11
27/10/2011 12:58:02.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:58:02.545 Time Out: ...resetting normal timer
27/10/2011 12:58:02.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:50
27/10/2011 12:58:02.547 Time Out: ...resetting micro timer
27/10/2011 12:58:02.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:12
27/10/2011 12:58:06.689 com.apple.launchd: (com.aladdin.hasplmd[8112]) Job appears to have crashed: Bus error: 10
27/10/2011 12:58:06.689 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:58:06.704 ReportCrash: Saved crash report for hasplmd[8112] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125806_localhost.crash
27/10/2011 12:58:16.895 com.apple.launchd: (com.aladdin.hasplmd[8113]) Job appears to have crashed: Bus error: 10
27/10/2011 12:58:16.895 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:58:16.911 ReportCrash: Saved crash report for hasplmd[8113] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125816_localhost.crash
27/10/2011 12:58:17.543 Time Out: Idle 18446522964.3 secs; normal due 27/10/2011 13:50, micro due 27/10/2011 13:12
27/10/2011 12:58:17.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:58:17.545 Time Out: ...resetting normal timer
27/10/2011 12:58:17.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:50
27/10/2011 12:58:17.547 Time Out: ...resetting micro timer
27/10/2011 12:58:17.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:12
27/10/2011 12:58:26.926 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:58:27.152 com.apple.launchd: (com.aladdin.hasplmd[8114]) Job appears to have crashed: Bus error: 10
27/10/2011 12:58:27.152 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:58:27.218 ReportCrash: Saved crash report for hasplmd[8114] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125827_localhost.crash
27/10/2011 12:58:32.544 Time Out: Idle 18446522979.3 secs; normal due 27/10/2011 13:50, micro due 27/10/2011 13:12
27/10/2011 12:58:32.545 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:58:32.546 Time Out: ...resetting normal timer
27/10/2011 12:58:32.547 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:50
27/10/2011 12:58:32.548 Time Out: ...resetting micro timer
27/10/2011 12:58:32.549 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:12
27/10/2011 12:58:37.387 com.apple.launchd: (com.aladdin.hasplmd[8116]) Job appears to have crashed: Bus error: 10
27/10/2011 12:58:37.387 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:58:37.401 ReportCrash: Saved crash report for hasplmd[8116] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125837_localhost.crash
27/10/2011 12:58:47.543 Time Out: Idle 18446522994.3 secs; normal due 27/10/2011 13:50, micro due 27/10/2011 13:12
27/10/2011 12:58:47.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:58:47.545 Time Out: ...resetting normal timer
27/10/2011 12:58:47.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:50
27/10/2011 12:58:47.547 Time Out: ...resetting micro timer
27/10/2011 12:58:47.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:12
27/10/2011 12:58:47.606 com.apple.launchd: (com.aladdin.hasplmd[8117]) Job appears to have crashed: Bus error: 10
27/10/2011 12:58:47.606 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:58:47.628 ReportCrash: Saved crash report for hasplmd[8117] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125847_localhost.crash
27/10/2011 12:58:57.845 com.apple.launchd: (com.aladdin.hasplmd[8118]) Job appears to have crashed: Bus error: 10
27/10/2011 12:58:57.845 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:58:57.864 ReportCrash: Saved crash report for hasplmd[8118] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125857_localhost.crash
27/10/2011 12:59:02.543 Time Out: Idle 18446523009.3 secs; normal due 27/10/2011 13:50, micro due 27/10/2011 13:12
27/10/2011 12:59:02.544 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:59:02.545 Time Out: ...resetting normal timer
27/10/2011 12:59:02.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:51
27/10/2011 12:59:02.547 Time Out: ...resetting micro timer
27/10/2011 12:59:02.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:13
27/10/2011 12:59:08.079 com.apple.launchd: (com.aladdin.hasplmd[8119]) Job appears to have crashed: Bus error: 10
27/10/2011 12:59:08.079 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:59:08.095 ReportCrash: Saved crash report for hasplmd[8119] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125908_localhost.crash
27/10/2011 12:59:17.543 Time Out: Idle 18446523024.3 secs; normal due 27/10/2011 13:51, micro due 27/10/2011 13:13
27/10/2011 12:59:17.545 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:59:17.545 Time Out: ...resetting normal timer
27/10/2011 12:59:17.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:51
27/10/2011 12:59:17.547 Time Out: ...resetting micro timer
27/10/2011 12:59:17.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:13
27/10/2011 12:59:18.309 com.apple.launchd: (com.aladdin.hasplmd[8120]) Job appears to have crashed: Bus error: 10
27/10/2011 12:59:18.309 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:59:18.327 ReportCrash: Saved crash report for hasplmd[8120] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125918_localhost.crash
27/10/2011 12:59:28.342 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 12:59:28.563 com.apple.launchd: (com.aladdin.hasplmd[8121]) Job appears to have crashed: Bus error: 10
27/10/2011 12:59:28.563 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:59:28.620 ReportCrash: Saved crash report for hasplmd[8121] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125928_localhost.crash
27/10/2011 12:59:32.544 Time Out: Idle 18446523039.3 secs; normal due 27/10/2011 13:51, micro due 27/10/2011 13:13
27/10/2011 12:59:32.545 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:59:32.546 Time Out: ...resetting normal timer
27/10/2011 12:59:32.547 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:51
27/10/2011 12:59:32.548 Time Out: ...resetting micro timer
27/10/2011 12:59:32.549 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:13
27/10/2011 12:59:38.767 com.apple.launchd: (com.aladdin.hasplmd[8123]) Job appears to have crashed: Bus error: 10
27/10/2011 12:59:38.767 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:59:38.782 ReportCrash: Saved crash report for hasplmd[8123] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125938_localhost.crash
27/10/2011 12:59:47.544 Time Out: Idle 18446523054.3 secs; normal due 27/10/2011 13:51, micro due 27/10/2011 13:13
27/10/2011 12:59:47.545 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 12:59:47.545 Time Out: ...resetting normal timer
27/10/2011 12:59:47.546 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:51
27/10/2011 12:59:47.547 Time Out: ...resetting micro timer
27/10/2011 12:59:47.548 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:13
27/10/2011 12:59:48.983 com.apple.launchd: (com.aladdin.hasplmd[8124]) Job appears to have crashed: Bus error: 10
27/10/2011 12:59:48.983 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:59:49.003 ReportCrash: Saved crash report for hasplmd[8124] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125949_localhost.crash
27/10/2011 12:59:59.188 com.apple.launchd: (com.aladdin.hasplmd[8125]) Job appears to have crashed: Bus error: 10
27/10/2011 12:59:59.188 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 12:59:59.204 ReportCrash: Saved crash report for hasplmd[8125] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-125959_localhost.crash
27/10/2011 13:00:02.544 Time Out: Idle 18446523069.3 secs; normal due 27/10/2011 13:51, micro due 27/10/2011 13:13
27/10/2011 13:00:02.546 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:00:02.546 Time Out: ...resetting normal timer
27/10/2011 13:00:02.548 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:52
27/10/2011 13:00:02.548 Time Out: ...resetting micro timer
27/10/2011 13:00:02.549 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:14
27/10/2011 13:00:09.397 com.apple.launchd: (com.aladdin.hasplmd[8126]) Job appears to have crashed: Bus error: 10
27/10/2011 13:00:09.397 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:00:09.414 ReportCrash: Saved crash report for hasplmd[8126] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130009_localhost.crash
27/10/2011 13:00:17.545 Time Out: Idle 18446523084.3 secs; normal due 27/10/2011 13:52, micro due 27/10/2011 13:14
27/10/2011 13:00:17.546 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:00:17.547 Time Out: ...resetting normal timer
27/10/2011 13:00:17.548 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:52
27/10/2011 13:00:17.549 Time Out: ...resetting micro timer
27/10/2011 13:00:17.550 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:14
27/10/2011 13:00:19.612 com.apple.launchd: (com.aladdin.hasplmd[8127]) Job appears to have crashed: Bus error: 10
27/10/2011 13:00:19.612 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:00:19.626 ReportCrash: Saved crash report for hasplmd[8127] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130019_localhost.crash
27/10/2011 13:00:29.645 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:00:29.853 com.apple.launchd: (com.aladdin.hasplmd[8128]) Job appears to have crashed: Bus error: 10
27/10/2011 13:00:29.853 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:00:29.910 ReportCrash: Saved crash report for hasplmd[8128] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130029_localhost.crash
27/10/2011 13:00:32.545 Time Out: Idle 18446523099.3 secs; normal due 27/10/2011 13:52, micro due 27/10/2011 13:14
27/10/2011 13:00:32.546 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:00:32.546 Time Out: ...resetting normal timer
27/10/2011 13:00:32.548 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:52
27/10/2011 13:00:32.548 Time Out: ...resetting micro timer
27/10/2011 13:00:32.549 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:14
27/10/2011 13:00:40.070 com.apple.launchd: (com.aladdin.hasplmd[8130]) Job appears to have crashed: Bus error: 10
27/10/2011 13:00:40.070 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:00:40.086 ReportCrash: Saved crash report for hasplmd[8130] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130040_localhost.crash
27/10/2011 13:00:47.544 Time Out: Idle 18446523114.3 secs; normal due 27/10/2011 13:52, micro due 27/10/2011 13:14
27/10/2011 13:00:47.545 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:00:47.546 Time Out: ...resetting normal timer
27/10/2011 13:00:47.547 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:52
27/10/2011 13:00:47.548 Time Out: ...resetting micro timer
27/10/2011 13:00:47.549 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:14
27/10/2011 13:00:50.312 com.apple.launchd: (com.aladdin.hasplmd[8131]) Job appears to have crashed: Bus error: 10
27/10/2011 13:00:50.312 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:00:50.330 ReportCrash: Saved crash report for hasplmd[8131] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130050_localhost.crash
27/10/2011 13:01:00.532 com.apple.launchd: (com.aladdin.hasplmd[8132]) Job appears to have crashed: Bus error: 10
27/10/2011 13:01:00.532 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:01:00.545 ReportCrash: Saved crash report for hasplmd[8132] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130100_localhost.crash
27/10/2011 13:01:02.545 Time Out: Idle 18446523129.3 secs; normal due 27/10/2011 13:52, micro due 27/10/2011 13:14
27/10/2011 13:01:02.547 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:01:02.548 Time Out: ...resetting normal timer
27/10/2011 13:01:02.549 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:53
27/10/2011 13:01:02.549 Time Out: ...resetting micro timer
27/10/2011 13:01:02.550 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:15
27/10/2011 13:01:10.748 com.apple.launchd: (com.aladdin.hasplmd[8133]) Job appears to have crashed: Bus error: 10
27/10/2011 13:01:10.748 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:01:10.762 ReportCrash: Saved crash report for hasplmd[8133] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130110_localhost.crash
27/10/2011 13:01:17.545 Time Out: Idle 18446523144.3 secs; normal due 27/10/2011 13:53, micro due 27/10/2011 13:15
27/10/2011 13:01:17.546 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:01:17.547 Time Out: ...resetting normal timer
27/10/2011 13:01:17.548 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:53
27/10/2011 13:01:17.549 Time Out: ...resetting micro timer
27/10/2011 13:01:17.550 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:15
27/10/2011 13:01:20.971 com.apple.launchd: (com.aladdin.hasplmd[8134]) Job appears to have crashed: Bus error: 10
27/10/2011 13:01:20.971 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:01:20.986 ReportCrash: Saved crash report for hasplmd[8134] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130120_localhost.crash
27/10/2011 13:01:31.001 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:01:31.217 com.apple.launchd: (com.aladdin.hasplmd[8135]) Job appears to have crashed: Bus error: 10
27/10/2011 13:01:31.217 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:01:31.271 ReportCrash: Saved crash report for hasplmd[8135] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130131_localhost.crash
27/10/2011 13:01:32.545 Time Out: Idle 18446523159.3 secs; normal due 27/10/2011 13:53, micro due 27/10/2011 13:15
27/10/2011 13:01:32.546 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:01:32.547 Time Out: ...resetting normal timer
27/10/2011 13:01:32.548 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:53
27/10/2011 13:01:32.548 Time Out: ...resetting micro timer
27/10/2011 13:01:32.550 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:15
27/10/2011 13:01:41.413 com.apple.launchd: (com.aladdin.hasplmd[8137]) Job appears to have crashed: Bus error: 10
27/10/2011 13:01:41.413 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:01:41.426 ReportCrash: Saved crash report for hasplmd[8137] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130141_localhost.crash
27/10/2011 13:01:47.546 Time Out: Idle 18446523174.3 secs; normal due 27/10/2011 13:53, micro due 27/10/2011 13:15
27/10/2011 13:01:47.547 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:01:47.547 Time Out: ...resetting normal timer
27/10/2011 13:01:47.548 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:53
27/10/2011 13:01:47.549 Time Out: ...resetting micro timer
27/10/2011 13:01:47.550 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:15
27/10/2011 13:01:51.609 com.apple.launchd: (com.aladdin.hasplmd[8138]) Job appears to have crashed: Bus error: 10
27/10/2011 13:01:51.609 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:01:51.626 ReportCrash: Saved crash report for hasplmd[8138] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130151_localhost.crash
27/10/2011 13:02:01.810 com.apple.launchd: (com.aladdin.hasplmd[8139]) Job appears to have crashed: Bus error: 10
27/10/2011 13:02:01.810 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:02:01.823 ReportCrash: Saved crash report for hasplmd[8139] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130201_localhost.crash
27/10/2011 13:02:02.547 Time Out: Idle 18446523189.3 secs; normal due 27/10/2011 13:53, micro due 27/10/2011 13:15
27/10/2011 13:02:02.549 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:02:02.549 Time Out: ...resetting normal timer
27/10/2011 13:02:02.551 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:54
27/10/2011 13:02:02.552 Time Out: ...resetting micro timer
27/10/2011 13:02:02.553 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:16
27/10/2011 13:02:12.035 com.apple.launchd: (com.aladdin.hasplmd[8140]) Job appears to have crashed: Bus error: 10
27/10/2011 13:02:12.035 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:02:12.055 ReportCrash: Saved crash report for hasplmd[8140] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130212_localhost.crash
27/10/2011 13:02:17.546 Time Out: Idle 18446523204.3 secs; normal due 27/10/2011 13:54, micro due 27/10/2011 13:16
27/10/2011 13:02:17.547 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:02:17.547 Time Out: ...resetting normal timer
27/10/2011 13:02:17.549 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:54
27/10/2011 13:02:17.549 Time Out: ...resetting micro timer
27/10/2011 13:02:17.550 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:16
27/10/2011 13:02:22.269 com.apple.launchd: (com.aladdin.hasplmd[8141]) Job appears to have crashed: Bus error: 10
27/10/2011 13:02:22.269 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:02:22.284 ReportCrash: Saved crash report for hasplmd[8141] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130222_localhost.crash
27/10/2011 13:02:32.300 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:02:32.488 com.apple.launchd: (com.aladdin.hasplmd[8142]) Job appears to have crashed: Bus error: 10
27/10/2011 13:02:32.488 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:02:32.546 Time Out: Idle 18446523219.3 secs; normal due 27/10/2011 13:54, micro due 27/10/2011 13:16
27/10/2011 13:02:32.546 ReportCrash: Saved crash report for hasplmd[8142] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130232_localhost.crash
27/10/2011 13:02:32.547 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:02:32.548 Time Out: ...resetting normal timer
27/10/2011 13:02:32.549 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:54
27/10/2011 13:02:32.550 Time Out: ...resetting micro timer
27/10/2011 13:02:32.551 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:16
27/10/2011 13:02:41.000 kernel: IOSurface: buffer allocation size is zero
27/10/2011 13:02:42.703 com.apple.launchd: (com.aladdin.hasplmd[8146]) Job appears to have crashed: Bus error: 10
27/10/2011 13:02:42.703 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:02:42.725 ReportCrash: Saved crash report for hasplmd[8146] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130242_localhost.crash
27/10/2011 13:02:47.546 Time Out: Idle 18446523234.3 secs; normal due 27/10/2011 13:54, micro due 27/10/2011 13:16
27/10/2011 13:02:47.547 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:02:47.548 Time Out: ...resetting normal timer
27/10/2011 13:02:47.549 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:54
27/10/2011 13:02:47.550 Time Out: ...resetting micro timer
27/10/2011 13:02:47.551 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:16
27/10/2011 13:02:52.924 com.apple.launchd: (com.aladdin.hasplmd[8148]) Job appears to have crashed: Bus error: 10
27/10/2011 13:02:52.924 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:02:52.939 ReportCrash: Saved crash report for hasplmd[8148] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130252_localhost.crash
27/10/2011 13:02:56.041 [0x0-0x42042].com.apple.Safari: DVFreeThread - CFMachPortCreateWithPort hack = 0x6c284240, fPowerNotifyPort= 0x6c282f40
27/10/2011 13:02:56.041 [0x0-0x42042].com.apple.Safari: DVFreeThread - CFMachPortCreateWithPort hack = 0x6c287820, fPowerNotifyPort= 0x6c287720
27/10/2011 13:03:02.546 Time Out: Idle 18446523249.3 secs; normal due 27/10/2011 13:54, micro due 27/10/2011 13:16
27/10/2011 13:03:02.547 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:03:02.548 Time Out: ...resetting normal timer
27/10/2011 13:03:02.549 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:55
27/10/2011 13:03:02.550 Time Out: ...resetting micro timer
27/10/2011 13:03:02.551 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:17
27/10/2011 13:03:03.150 com.apple.launchd: (com.aladdin.hasplmd[8150]) Job appears to have crashed: Bus error: 10
27/10/2011 13:03:03.150 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:03:03.164 ReportCrash: Saved crash report for hasplmd[8150] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130303_localhost.crash
27/10/2011 13:03:10.028 mdworker: zip importer encountered an error (2) scanning "/Users/iaincrawford/Downloads/lowres.zip".
27/10/2011 13:03:13.374 com.apple.launchd: (com.aladdin.hasplmd[8151]) Job appears to have crashed: Bus error: 10
27/10/2011 13:03:13.374 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:03:13.390 ReportCrash: Saved crash report for hasplmd[8151] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130313_localhost.crash
27/10/2011 13:03:17.546 Time Out: Idle 18446523264.3 secs; normal due 27/10/2011 13:55, micro due 27/10/2011 13:17
27/10/2011 13:03:17.547 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:03:17.548 Time Out: ...resetting normal timer
27/10/2011 13:03:17.549 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:55
27/10/2011 13:03:17.549 Time Out: ...resetting micro timer
27/10/2011 13:03:17.550 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:17
27/10/2011 13:03:18.522 mdworker: zip importer encountered an error (2) scanning "/Users/iaincrawford/Downloads/lowres-1.zip".
27/10/2011 13:03:23.598 com.apple.launchd: (com.aladdin.hasplmd[8152]) Job appears to have crashed: Bus error: 10
27/10/2011 13:03:23.598 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:03:23.616 ReportCrash: Saved crash report for hasplmd[8152] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130323_localhost.crash
27/10/2011 13:03:32.547 Time Out: Idle 18446523279.3 secs; normal due 27/10/2011 13:55, micro due 27/10/2011 13:17
27/10/2011 13:03:32.548 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:03:32.548 Time Out: ...resetting normal timer
27/10/2011 13:03:32.549 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:55
27/10/2011 13:03:32.550 Time Out: ...resetting micro timer
27/10/2011 13:03:32.551 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:17
27/10/2011 13:03:33.631 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:03:33.842 com.apple.launchd: (com.aladdin.hasplmd[8153]) Job appears to have crashed: Bus error: 10
27/10/2011 13:03:33.842 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:03:33.900 ReportCrash: Saved crash report for hasplmd[8153] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130333_localhost.crash
27/10/2011 13:03:44.052 com.apple.launchd: (com.aladdin.hasplmd[8155]) Job appears to have crashed: Bus error: 10
27/10/2011 13:03:44.052 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:03:44.068 ReportCrash: Saved crash report for hasplmd[8155] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130344_localhost.crash
27/10/2011 13:03:47.547 Time Out: Idle 18446523294.3 secs; normal due 27/10/2011 13:55, micro due 27/10/2011 13:17
27/10/2011 13:03:47.548 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:03:47.548 Time Out: ...resetting normal timer
27/10/2011 13:03:47.550 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:55
27/10/2011 13:03:47.550 Time Out: ...resetting micro timer
27/10/2011 13:03:47.552 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:17
27/10/2011 13:03:54.278 com.apple.launchd: (com.aladdin.hasplmd[8156]) Job appears to have crashed: Bus error: 10
27/10/2011 13:03:54.278 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:03:54.299 ReportCrash: Saved crash report for hasplmd[8156] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130354_localhost.crash
27/10/2011 13:04:02.547 Time Out: Idle 18446523309.3 secs; normal due 27/10/2011 13:55, micro due 27/10/2011 13:17
27/10/2011 13:04:02.549 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:04:02.549 Time Out: ...resetting normal timer
27/10/2011 13:04:02.551 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:56
27/10/2011 13:04:02.552 Time Out: ...resetting micro timer
27/10/2011 13:04:02.553 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:18
27/10/2011 13:04:04.506 com.apple.launchd: (com.aladdin.hasplmd[8157]) Job appears to have crashed: Bus error: 10
27/10/2011 13:04:04.506 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:04:04.522 ReportCrash: Saved crash report for hasplmd[8157] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130404_localhost.crash
27/10/2011 13:04:14.716 com.apple.launchd: (com.aladdin.hasplmd[8158]) Job appears to have crashed: Bus error: 10
27/10/2011 13:04:14.716 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:04:14.732 ReportCrash: Saved crash report for hasplmd[8158] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130414_localhost.crash
27/10/2011 13:04:17.548 Time Out: Idle 18446523324.3 secs; normal due 27/10/2011 13:56, micro due 27/10/2011 13:18
27/10/2011 13:04:17.549 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:04:17.550 Time Out: ...resetting normal timer
27/10/2011 13:04:17.551 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:56
27/10/2011 13:04:17.552 Time Out: ...resetting micro timer
27/10/2011 13:04:17.553 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:18
27/10/2011 13:04:18.655 [0x0-0x91091].com.phaseone.captureone: Darwin Kernel Version 11.2.0: Tue Aug 9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
27/10/2011 13:04:18.655 [0x0-0x91091].com.phaseone.captureone: cpu i486 (Intel 80486, type=0x7 subtype=0x4 threadtype=0x1)
27/10/2011 13:04:18.655 [0x0-0x91091].com.phaseone.captureone: physical_cpu 2
27/10/2011 13:04:18.655 [0x0-0x91091].com.phaseone.captureone: logical_cpu 4
27/10/2011 13:04:18.655 [0x0-0x91091].com.phaseone.captureone: Toal memory 8192 MB
27/10/2011 13:04:18.655 [0x0-0x91091].com.phaseone.captureone: Single block (V)memory 2051 MB
27/10/2011 13:04:19.038 Capture One: This is Capture One 6.2.2.50756.50514
27/10/2011 13:04:19.038 Capture One: Running in 64 bit!
27/10/2011 13:04:24.204 Capture One: --> Loading system profiles took 0.33 seconds
27/10/2011 13:04:24.910 com.apple.launchd: (com.aladdin.hasplmd[8162]) Job appears to have crashed: Bus error: 10
27/10/2011 13:04:24.910 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:04:24.929 ReportCrash: Saved crash report for hasplmd[8162] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130424_localhost.crash
27/10/2011 13:04:26.722 [0x0-0x91091].com.phaseone.captureone: Darwin Kernel Version 11.2.0: Tue Aug 9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
27/10/2011 13:04:26.722 [0x0-0x91091].com.phaseone.captureone: cpu i486 (Intel 80486, type=0x7 subtype=0x4 threadtype=0x1)
27/10/2011 13:04:26.722 [0x0-0x91091].com.phaseone.captureone: physical_cpu 2
27/10/2011 13:04:26.722 [0x0-0x91091].com.phaseone.captureone: logical_cpu 4
27/10/2011 13:04:26.722 [0x0-0x91091].com.phaseone.captureone: Toal memory 8192 MB
27/10/2011 13:04:26.722 [0x0-0x91091].com.phaseone.captureone: Single block (V)memory 1884 MB
27/10/2011 13:04:26.729 [0x0-0x91091].com.phaseone.captureone: Darwin Kernel Version 11.2.0: Tue Aug 9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
27/10/2011 13:04:26.729 [0x0-0x91091].com.phaseone.captureone: cpu i486 (Intel 80486, type=0x7 subtype=0x4 threadtype=0x1)
27/10/2011 13:04:26.729 [0x0-0x91091].com.phaseone.captureone: physical_cpu 2
27/10/2011 13:04:26.729 [0x0-0x91091].com.phaseone.captureone: logical_cpu 4
27/10/2011 13:04:26.729 [0x0-0x91091].com.phaseone.captureone: Toal memory 8192 MB
27/10/2011 13:04:26.729 [0x0-0x91091].com.phaseone.captureone: Single block (V)memory 1881 MB
27/10/2011 13:04:28.196 Capture One: **** prepareNewStatement:@"SELECT * FROM VERSION" failed!
27/10/2011 13:04:28.565 CaptureCoreServer: initialized:
27/10/2011 13:04:28.565 [0x0-0x91091].com.phaseone.captureone: 2011-10-27 13:04:28.564 CaptureCoreServer[8170:107] initialized:
27/10/2011 13:04:29.144 Capture One: Total variant count: 3054
27/10/2011 13:04:29.144 Capture One: [LOAD] SELECTs took 0.36 s
27/10/2011 13:04:29.230 Capture One: Deleted 12 stale objects from the session.
27/10/2011 13:04:29.230 Capture One: [LOAD] Cleanup SELECTs took 88 ms
27/10/2011 13:04:29.319 Capture One: Unknown key in ImageCore template: IB_S_BASIC_LABEL
27/10/2011 13:04:29.320 Capture One: Unknown key in ImageCore template: IB_S_IMAGE_PEOPLE
27/10/2011 13:04:29.320 Capture One: Unknown key in ImageCore template: IB_S_IMAGE_STATUS
27/10/2011 13:04:29.320 Capture One: Unknown key in ImageCore template: IB_S_IMAGE_EVENT
27/10/2011 13:04:29.372 Capture One: [LOAD] Initialization took 0.11 s
27/10/2011 13:04:30.875 Capture One: Fetched image settings for 3050 images
27/10/2011 13:04:30.875 Capture One: [CACHE LOAD] SELECTs took 0.66 s
27/10/2011 13:04:30.922 Capture One: [CACHE LOAD] Initialization took 47 ms
27/10/2011 13:04:32.547 Time Out: Idle 18446523339.3 secs; normal due 27/10/2011 13:56, micro due 27/10/2011 13:18
27/10/2011 13:04:32.548 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:04:32.548 Time Out: ...resetting normal timer
27/10/2011 13:04:32.550 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:56
27/10/2011 13:04:32.550 Time Out: ...resetting micro timer
27/10/2011 13:04:32.552 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:18
27/10/2011 13:04:32.924 Capture One: [CACHE LOAD] Awakening took 2.00 s
27/10/2011 13:04:32.924 Capture One: [CACHE LOAD] Total load time: 2.71 s
27/10/2011 13:04:33.162 Capture One: [LOAD] Awakening took 0.24 s
27/10/2011 13:04:33.162 Capture One: [LOAD] Total load time: 3.51 s
27/10/2011 13:04:34.435 Capture One: Started thread 0
27/10/2011 13:04:34.435 Capture One: Starting thread 0
27/10/2011 13:04:34.944 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:04:35.162 com.apple.launchd: (com.aladdin.hasplmd[8171]) Job appears to have crashed: Bus error: 10
27/10/2011 13:04:35.162 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:04:35.217 ReportCrash: Saved crash report for hasplmd[8171] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130435_localhost.crash
27/10/2011 13:04:35.369 [0x0-0x91091].com.phaseone.captureone: Entry DeviceAdded routine
27/10/2011 13:04:35.371 [0x0-0x91091].com.phaseone.captureone: Entry DeviceAdded routine
27/10/2011 13:04:35.373 [0x0-0x91091].com.phaseone.captureone: Entry DeviceAdded routine
27/10/2011 13:04:41.000 kernel: NVDA(Compute): Channel exception! exception type = 0xd = GR: SW Notify Error
27/10/2011 13:04:41.000 kernel: IOVendorGLContext::ReportGPURestart
27/10/2011 13:04:41.000 kernel: 0000006e
27/10/2011 13:04:41.000 kernel: 00200000 000050c0 00000474 00000100
27/10/2011 13:04:41.000 kernel: 0000047e 00000368 00000000 0000001b
27/10/2011 13:04:41.000 kernel: 00000000 00000000 01902003
27/10/2011 13:04:41.000 kernel: 00000100 00000000
27/10/2011 13:04:44.863 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x160d06e50 of class __NSCFNumber autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:44.863 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x1848c6f20 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:44.863 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x160c48620 of class NSCalendarDate autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:44.863 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x1848c3ab0 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:45.013 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x160d06e50 of class __NSCFNumber autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:45.013 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x184f57b80 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:45.013 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x184f549e0 of class NSCalendarDate autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:45.013 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x184f53d70 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:45.132 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x160d06e50 of class __NSCFNumber autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:45.132 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x18508da40 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:45.132 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x1850919c0 of class NSCalendarDate autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:45.132 [0x0-0x91091].com.phaseone.captureone: objc[8159]: Object 0x185091ac0 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:04:45.361 com.apple.launchd: (com.aladdin.hasplmd[8176]) Job appears to have crashed: Bus error: 10
27/10/2011 13:04:45.361 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:04:45.376 ReportCrash: Saved crash report for hasplmd[8176] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130445_localhost.crash
27/10/2011 13:04:47.547 Time Out: Idle 18446523354.3 secs; normal due 27/10/2011 13:56, micro due 27/10/2011 13:18
27/10/2011 13:04:47.548 Time Out: ...now officially idle, since 26/10/2011 20:08
27/10/2011 13:04:47.548 Time Out: ...resetting normal timer
27/10/2011 13:04:47.549 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:56
27/10/2011 13:04:47.550 Time Out: ...resetting micro timer
27/10/2011 13:04:47.551 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:18
27/10/2011 13:04:47.616 sandboxd: ([8173]) DumpGPURestart(8173) deny file-write-create /Library/Application Support/SubmitDiagInfo
27/10/2011 13:04:47.653 sandboxd: ([8173]) DumpGPURestart(8173) deny ipc-posix-shm apple.shm.notification_center
27/10/2011 13:04:47.654 sandboxd: ([8173]) DumpGPURestart(8173) deny ipc-posix-shm apple.shm.notification_center
27/10/2011 13:04:47.655 sandboxd: ([8173]) DumpGPURestart(8173) deny ipc-posix-shm apple.shm.notification_center
27/10/2011 13:04:47.656 sandboxd: ([8173]) DumpGPURestart(8173) deny ipc-posix-shm apple.shm.notification_center
27/10/2011 13:04:47.657 sandboxd: ([8173]) DumpGPURestart(8173) deny ipc-posix-shm apple.shm.notification_center
27/10/2011 13:04:47.658 sandboxd: ([8173]) DumpGPURestart(8173) deny file-read-metadata /Library/Managed Preferences
27/10/2011 13:05:25.000 bootlog: BOOT_TIME 1319717125 0
27/10/2011 13:05:49.851 fseventsd: event logs in /.fseventsd out of sync with volume. destroying old logs. (61837 23 61896)
27/10/2011 13:05:49.893 fseventsd: log dir: /.fseventsd getting new uuid: 09851D77-0A3E-41F7-B5EF-E49AE8609C17
27/10/2011 13:05:59.000 kernel: Darwin Kernel Version 11.2.0: Tue Aug 9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
27/10/2011 13:05:59.000 kernel: vm_page_bootstrap: 2006666 free pages and 74102 wired pages
27/10/2011 13:05:59.000 kernel: kext submap [0xffffff7f8072e000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff800072e000]
27/10/2011 13:05:59.000 kernel: zone leak detection enabled
27/10/2011 13:05:59.000 kernel: standard timeslicing quantum is 10000 us
27/10/2011 13:05:59.000 kernel: mig_table_max_displ = 73
27/10/2011 13:05:59.000 kernel: AppleACPICPU: ProcessorId=1 LocalApicId=0 Enabled
27/10/2011 13:05:59.000 kernel: AppleACPICPU: ProcessorId=2 LocalApicId=1 Enabled
27/10/2011 13:05:59.000 kernel: AppleACPICPU: ProcessorId=3 LocalApicId=4 Enabled
27/10/2011 13:05:59.000 kernel: AppleACPICPU: ProcessorId=4 LocalApicId=5 Enabled
27/10/2011 13:05:59.000 kernel: AppleACPICPU: ProcessorId=5 LocalApicId=0 Disabled
27/10/2011 13:05:59.000 kernel: AppleACPICPU: ProcessorId=6 LocalApicId=0 Disabled
27/10/2011 13:05:59.000 kernel: AppleACPICPU: ProcessorId=7 LocalApicId=0 Disabled
27/10/2011 13:05:59.000 kernel: AppleACPICPU: ProcessorId=8 LocalApicId=0 Disabled
27/10/2011 13:05:59.000 kernel: calling mpo_policy_init for TMSafetyNet
27/10/2011 13:05:59.000 kernel: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
27/10/2011 13:05:59.000 kernel: calling mpo_policy_init for Sandbox
27/10/2011 13:05:59.000 kernel: Security policy loaded: Seatbelt sandbox policy (Sandbox)
27/10/2011 13:05:59.000 kernel: calling mpo_policy_init for Quarantine
27/10/2011 13:05:59.000 kernel: Security policy loaded: Quarantine policy (Quarantine)
27/10/2011 13:05:59.000 kernel: Copyright (c) 1982, 1986, 1989, 1991, 1993
27/10/2011 13:05:59.000 kernel: The Regents of the University of California. All rights reserved.
27/10/2011 13:05:59.000 kernel: MAC Framework successfully initialized
27/10/2011 13:05:59.000 kernel: using 16384 buffer headers and 10240 cluster IO buffer headers
27/10/2011 13:05:59.000 kernel: IOAPIC: Version 0x20 Vectors 64:87
27/10/2011 13:05:59.000 kernel: ACPI: System State [S0 S3 S4 S5] (S3)
27/10/2011 13:05:59.000 kernel: PFM64 (36 cpu) 0xf10000000, 0xf0000000
27/10/2011 13:05:59.000 kernel: [ PCI configuration begin ]
27/10/2011 13:05:59.000 kernel: AppleIntelCPUPowerManagement: Turbo Ratios 0035
27/10/2011 13:05:59.000 kernel: AppleIntelCPUPowerManagement: (built 21:08:10 Aug 9 2011) initialization complete
27/10/2011 13:05:59.000 kernel: console relocated to 0xf10030000
27/10/2011 13:05:59.000 kernel: PCI configuration changed (bridge=3 device=2 cardbus=0)
27/10/2011 13:05:59.000 kernel: [ PCI configuration end, bridges 7 devices 16 ]
27/10/2011 13:05:59.000 kernel: [ PCI configuration end, bridges 8 devices 22 ]
27/10/2011 13:05:59.000 kernel: mbinit: done [96 MB total pool size, (64/32) split]
27/10/2011 13:05:59.000 kernel: Pthread support ABORTS when sync kernel primitives misused
27/10/2011 13:05:59.000 kernel: com.apple.AppleFSCompressionTypeZlib kmod start
27/10/2011 13:05:59.000 kernel: com.apple.AppleFSCompressionTypeDataless kmod start
27/10/2011 13:05:59.000 kernel: 2.4.0 Little Snitch: starting
27/10/2011 13:05:59.000 kernel: com.apple.AppleFSCompressionTypeZlib load succeeded
27/10/2011 13:05:59.000 kernel: com.apple.AppleFSCompressionTypeDataless load succeeded
27/10/2011 13:05:59.000 kernel: AppleIntelCPUPowerManagementClient: ready
27/10/2011 13:05:59.000 kernel: FireWire (OHCI) Lucent ID 5901 built-in now active, GUID 7c6d62fffef983fa; max speed s800.
27/10/2011 13:05:59.000 kernel: BTCOEXIST off
27/10/2011 13:05:59.000 kernel: wl0: Broadcom BCM4353 802.11 Wireless Controller
27/10/2011 13:05:59.000 kernel: 5.100.98.75
27/10/2011 13:05:59.000 kernel: USBMSC Identifier (non-unique): 000000009833 0x5ac 0x8403 0x9833
27/10/2011 13:05:59.000 kernel: rooting via boot-uuid from /chosen: 68F6BA59-CE96-3E8B-B205-53F678EC9D51
27/10/2011 13:05:59.000 kernel: Waiting on IOProviderClassIOResourcesIOResourceMatchboot-uuid-media
27/10/2011 13:05:59.000 kernel: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HTS545050B9SA02 Media/IOGUIDPartitionScheme/Untitled@2
27/10/2011 13:05:59.000 kernel: BSD root: disk0s2, major 14, minor 2
27/10/2011 13:05:59.000 kernel: jnl: unknown-dev: replay_journal: from: 39101440 to: 4656128 (joffset 0xe8e000)
27/10/2011 13:05:59.000 kernel: [IOBluetoothHCIController::setConfigState] calling registerService
27/10/2011 13:05:59.000 kernel: jnl: unknown-dev: journal replay done.
27/10/2011 13:05:59.000 kernel: Kernel is LP64
27/10/2011 13:05:59.000 kernel: hfs: Removed 16 orphaned / unlinked files and 86 directories
27/10/2011 13:05:59.000 kernel: Cannot get audit control port
27/10/2011 13:05:59.000 kernel: macx_swapon SUCCESS
27/10/2011 13:05:34.636 com.apple.launchd: *** launchd[1] has started up. ***
27/10/2011 13:05:49.789 com.apple.launchd: (com.xrite.device.xrdd.plist) Unknown key for string: CFBundleVersion
27/10/2011 13:05:49.789 com.apple.launchd: (com.xrite.device.xrdd.plist) Unknown key: CFBundleVersion
27/10/2011 13:05:58.217 com.apple.pfctl: No ALTQ support in kernel
27/10/2011 13:05:58.217 com.apple.pfctl: ALTQ related functions disabled
27/10/2011 13:05:59.202 com.apple.SecurityServer: Session 100000 created
27/10/2011 13:05:59.617 UserEventAgent: starting CaptiveNetworkSupport as SystemEventAgent built Jun 13 2011 17:29:21
27/10/2011 13:05:59.620 UserEventAgent: WirelessAirPortDeviceNameCopy(): no BSD interface name found for object 12039
27/10/2011 13:05:59.620 UserEventAgent: CaptiveNetworkSupport:CaptiveSCCopyWiFiDevices:388 WiFi Device Name == NULL
27/10/2011 13:06:00.329 com.apple.ucupdate.plist: ucupdate: Checked 1 update, no match found.
27/10/2011 13:06:00.531 UserEventAgent: CertsKeychainMonitor: configuring
27/10/2011 13:06:01.000 kernel: Waiting for DSMOS...
27/10/2011 13:06:02.000 kernel: BCM5701Enet: Ethernet address 7c:6d:62:8c:2f:95
27/10/2011 13:06:02.000 kernel: AirPort_Brcm4331: Ethernet address 34:15:9e:93:44:93
27/10/2011 13:06:02.000 kernel: IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
27/10/2011 13:06:02.000 kernel: IO80211Interface::efiNVRAMPublished():
27/10/2011 13:06:10.993 mDNSResponder: mDNSResponder mDNSResponder-320.10 (Aug 2 2011 19:56:51) starting OSXVers 11
27/10/2011 13:06:11.014 com.apple.usbmuxd: usbmuxd-263 on Aug 23 2011 at 00:44:06, running 64 bit
27/10/2011 13:06:21.567 airportd: _processDLILEvent: en1 attached (down)
27/10/2011 13:06:22.000 kernel: Created virtif 0xffffff80163e1a00 p2p0
27/10/2011 13:06:22.000 kernel: AGC: 3.0.16, HW version=1.9.21, flags:0, features:20600
27/10/2011 13:06:22.000 kernel: Previous Shutdown Cause: 3
27/10/2011 13:06:22.168 com.apple.kextd: Can't load /System/Library/Extensions/MonitorControl_drv.kext - no code for running kernel's architecture.
27/10/2011 13:06:22.271 com.apple.kextd: Load MonitorControl.drv failed; removing personalities from kernel.
27/10/2011 13:06:22.316 com.apple.kextd: Can't load /System/Library/Extensions/System.kext/PlugIns/IOKit6.0.kext - no code for running kernel's architecture.
27/10/2011 13:06:22.323 com.apple.kextd: Load com.apple.kernel.iokit failed; removing personalities from kernel.
27/10/2011 13:06:23.000 kernel: NVDANV50HAL loaded and registered.
27/10/2011 13:06:23.000 kernel: fNumVRAMBlocks is 4
27/10/2011 13:06:23.000 kernel: DSMOS has arrived
27/10/2011 13:06:24.000 kernel: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
27/10/2011 13:06:25.343 mds: (Normal) FMW: FMW 0 0
27/10/2011 13:06:26.468 UserEventAgent: CaptiveNetworkSupport:CreateInterfaceWatchList:2788 WiFi Devices Found. :)
27/10/2011 13:06:26.468 UserEventAgent: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - PreProbe
27/10/2011 13:06:26.474 UserEventAgent: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - PreProbe
27/10/2011 13:06:26.476 UserEventAgent: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - PreProbe
27/10/2011 13:06:27.324 configd: bootp_session_transmit: bpf_write(en1) failed: Network is down (50)
27/10/2011 13:06:27.324 configd: DHCP en1: INIT-REBOOT transmit failed
27/10/2011 13:06:27.349 configd: network configuration changed.
27/10/2011 13:06:27.350 configd: setting hostname to "Macintosh-2.local"
27/10/2011 13:06:29.096 com.apple.SecurityServer: Entering service
27/10/2011 13:06:29.142 com.apple.SystemStarter: Starting ProTec6b Daemon
27/10/2011 13:06:29.151 UserEventAgent: ServermgrdRegistration cannot load config data
27/10/2011 13:06:29.158 UserEventAgent: get_backup_share_points no AFP
27/10/2011 13:06:29.166 mDNSResponder: D2D_IPC: Loaded
27/10/2011 13:06:29.166 mDNSResponder: D2DInitialize succeeded
27/10/2011 13:06:29.168 configd: network configuration changed.
27/10/2011 13:06:29.161 systemkeychain: done file: /var/run/systemkeychaincheck.done
27/10/2011 13:06:29.172 configd: network configuration changed.
27/10/2011 13:06:29.196 _mdnsresponder: audit warning: allsoft
27/10/2011 13:06:29.200 _mdnsresponder: audit warning: soft /var/audit
27/10/2011 13:06:29.298 loginwindow: Login Window Application Started
27/10/2011 13:06:30.000 kernel: nstat_lookup_entry failed: 2
27/10/2011 13:06:30.327 _mdnsresponder: audit warning: closefile /var/audit/20111027120540.20111027120629
27/10/2011 13:06:30.000 kernel: MacAuthEvent en1 Auth result for: 00:26:44:15:80:77 MAC AUTH succeeded
27/10/2011 13:06:30.000 kernel: wlEvent: en1 en1 Link UP
27/10/2011 13:06:30.000 kernel: AirPort: Link Up on en1
27/10/2011 13:06:30.000 kernel: en1: BSSID changed to 00:26:44:15:80:77
27/10/2011 13:06:31.000 kernel: AirPort: RSN handshake complete on en1
27/10/2011 13:06:31.816 netbiosd: Unable to start NetBIOS name service:
27/10/2011 13:06:33.000 kernel: AppleBCM5701Ethernet: 0 0 setFixedSpeed - logic error, speed any?
27/10/2011 13:06:37.188 configd: network configuration changed.
27/10/2011 13:06:37.210 configd: setting hostname to "unknown-34-15-9e-93-44-93.config"
27/10/2011 13:06:37.218 UserEventAgent: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - Probe
27/10/2011 13:06:37.218 UserEventAgent: CaptiveNetworkSupport:CNSPreferences:60 Creating new preferences
27/10/2011 13:06:37.219 UserEventAgent: CaptiveNetworkSupport:CaptiveStartDetect:2343 Bypassing probe on BeBox16 because it is protected and not on the exception list
27/10/2011 13:06:37.222 UserEventAgent: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - Unknown
27/10/2011 13:06:37.224 configd: network configuration changed.
27/10/2011 13:06:37.165 ntpd: proto: precision = 1.000 usec
27/10/2011 13:06:39.878 rpcsvchost: sandbox_init: com.apple.msrpc.netlogon.sb succeeded
27/10/2011 13:06:40.000 kernel: EDID does not contain Extended EDID, not valid for audio
27/10/2011 13:06:44.969 UserEventAgent: CertsKeychainMonitor: ready to process keychain & timer events
27/10/2011 13:06:55.894 loginwindow: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
27/10/2011 13:07:04.371 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:07:04.529 com.apple.launchd: (com.aladdin.hasplmd[54]) Job appears to have crashed: Bus error: 10
27/10/2011 13:07:04.652 com.apple.launchd: (com.aladdin.hasplmd[129]) Job appears to have crashed: Bus error: 10
27/10/2011 13:07:04.652 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:07:06.858 ReportCrash: Saved crash report for hasplmd[129] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130706_localhost.crash
27/10/2011 13:07:06.858 ReportCrash: Saved crash report for hasplmd[54] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130706-1_localhost.crash
27/10/2011 13:07:14.789 com.apple.launchd: (com.aladdin.hasplmd[133]) Job appears to have crashed: Bus error: 10
27/10/2011 13:07:14.789 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:07:14.802 ReportCrash: Saved crash report for hasplmd[133] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130714_localhost.crash
27/10/2011 13:07:15.554 com.apple.launchctl.LoginWindow: com.apple.findmymacmessenger: Already loaded
27/10/2011 13:07:15.620 airportd: _doAutoJoin: Already associated to “BeBox16”. Bailing on auto-join.
27/10/2011 13:07:15.648 Nalpeirond6b: /Library/StartupItems/ProTec6b/Nalpeirond6b: daemon has successfully started
27/10/2011 13:07:15.661 com.apple.SecurityServer: Session 100006 created
27/10/2011 13:07:15.663 loginwindow: Login Window Started Security Agent
27/10/2011 13:07:15.786 SecurityAgent: Echo enabled
27/10/2011 13:07:15.797 _mdnsresponder: audit warning: closefile /var/audit/20111027120629.20111027120715
27/10/2011 13:07:15.797 _mdnsresponder: audit warning: soft /var/audit
27/10/2011 13:07:15.807 _mdnsresponder: audit warning: allsoft
27/10/2011 13:07:16.377 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 9 seconds
27/10/2011 13:07:16.427 fseventsd: event logs in /Volumes/I_CRAWFORD 002/.fseventsd out of sync with volume. destroying old logs. (61742 0 61900)
27/10/2011 13:07:16.448 fseventsd: log dir: /Volumes/I_CRAWFORD 002/.fseventsd getting new uuid: 81C89939-ADC8-4AFA-9BCE-AE06D61AFC17
27/10/2011 13:07:16.450 fseventsd: Events arrived for /Volumes/I_CRAWFORD 002 after an unmount request! Re-initializing.
27/10/2011 13:07:16.450 fseventsd: creating a dls for /Volumes/I_CRAWFORD 002 but it already has one...
27/10/2011 13:07:16.623 TabletDriver: Finish launching /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/ConsumerTouchDriver.app
27/10/2011 13:07:16.623 com.wacom.pentablet: Oct 27 13:07:16 unknown-34-15-9e-93-44-93.config TabletDriver[140] : Finish launching /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/ConsumerTouchDriver.app
27/10/2011 13:07:16.668 TabletDriver: Finish launching /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/TabletDriver.app
27/10/2011 13:07:16.668 com.wacom.pentablet: Oct 27 13:07:16 unknown-34-15-9e-93-44-93.config TabletDriver[140] : Finish launching /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/TabletDriver.app
27/10/2011 13:07:16.000 kernel: hfs: early journal init: volume on disk1s2 is read-only and journal is dirty. Can not mount volume.
27/10/2011 13:07:16.000 kernel: hfs_mountfs: hfs_early_journal_init failed, erroring out
27/10/2011 13:07:16.000 kernel: hfs_mount: hfs_mountfs returned 22
27/10/2011 13:07:16.000 kernel: jnl: disk1s2: replay_journal: from: 72385024 to: 73147392 (joffset 0x1d1c000)
27/10/2011 13:07:16.000 kernel: jnl: disk1s2: journal replay done.
27/10/2011 13:07:16.961 com.apple.launchd: ([0x0-0x7007].com.wacom.TabletDriver[168]) The following job tried to hijack the service "com.wacom.CoordinatorMessageServer" from this job: [0x0-0x8008].com.wacom.TabletDriver
27/10/2011 13:07:19.979 com.apple.launchd: ([0x0-0x7007].com.wacom.TabletDriver[168]) Exited: Terminated: 15
27/10/2011 13:07:21.038 TabletDriver: Finish launching /Library/Application Support/Tablet/WacomTabletDriver.app/Contents/Resources/TabletDriver.app
27/10/2011 13:07:21.038 com.wacom.wacomtablet: Oct 27 13:07:21 unknown-34-15-9e-93-44-93.config TabletDriver[139] : Finish launching /Library/Application Support/Tablet/WacomTabletDriver.app/Contents/Resources/TabletDriver.app
27/10/2011 13:07:24.563 SecurityAgent: User info context values set for iaincrawford
27/10/2011 13:07:25.520 com.apple.launchd: (com.aladdin.hasplmd[175]) Job appears to have crashed: Bus error: 10
27/10/2011 13:07:25.520 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:07:25.533 ReportCrash: Saved crash report for hasplmd[175] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130725_localhost.crash
27/10/2011 13:07:27.882 SecurityAgent: Login Window login proceeding
27/10/2011 13:07:28.574 loginwindow: Login Window - Returned from Security Agent
27/10/2011 13:07:28.604 loginwindow: USER_PROCESS: 38 console
27/10/2011 13:07:28.660 airportd: _doAutoJoin: Already associated to “BeBox16”. Bailing on auto-join.
27/10/2011 13:07:28.787 applepushserviced: Unable to bootstrap_lookup connection port for 'com.apple.iCalPush': unknown error code
27/10/2011 13:07:28.792 com.apple.launchd: ([0x0-0x6006].com.wacom.Consumer_TouchDriver[167]) Exited with code: 255
27/10/2011 13:07:28.795 com.apple.launchd: (com.wacom.wacomtablet[139]) Exited with code: 255
27/10/2011 13:07:28.796 com.apple.launchd: (com.wacom.pentablet[140]) Exited with code: 255
27/10/2011 13:07:28.823 com.apple.launchd.peruser.501: (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
27/10/2011 13:07:28.825 com.apple.launchctl.Aqua: load: option requires an argument -- D
27/10/2011 13:07:28.826 com.apple.launchctl.Aqua: usage: launchctl load [-wF] [-D ] paths...
27/10/2011 13:07:29.305 UserEventAgent: CaptiveNetworkSupport:CNSServerRegisterUserAgent:187 new user agent port: 14603
27/10/2011 13:07:29.545 com.apple.launchd.peruser.501: (com.apple.launchctl.Aqua[178]) Exited with code: 1
27/10/2011 13:07:29.849 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 6 seconds
27/10/2011 13:07:31.742 WindowServer: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
27/10/2011 13:07:31.770 com.apple.dock.extra: Could not connect the action buttonPressed: to target of class NSApplication
27/10/2011 13:07:31.771 com.apple.dock.extra: 2011-10-27 13:07:31.762 com.apple.dock.extra[215:1707] Could not connect the action buttonPressed: to target of class NSApplication
27/10/2011 13:07:31.771 com.apple.dock.extra: Could not connect the action buttonPressed: to target of class NSApplication
27/10/2011 13:07:31.772 com.apple.dock.extra: Could not connect the action buttonPressed: to target of class NSApplication
27/10/2011 13:07:31.772 com.apple.dock.extra: 2011-10-27 13:07:31.770 com.apple.dock.extra[215:1707] Could not connect the action buttonPressed: to target of class NSApplication
27/10/2011 13:07:31.772 com.apple.dock.extra: 2011-10-27 13:07:31.771 com.apple.dock.extra[215:1707] Could not connect the action buttonPressed: to target of class NSApplication
27/10/2011 13:07:31.774 com.apple.dock.extra: Could not connect the action buttonPressed: to target of class NSApplication
27/10/2011 13:07:31.775 com.apple.dock.extra: 2011-10-27 13:07:31.772 com.apple.dock.extra[215:1707] Could not connect the action buttonPressed: to target of class NSApplication
27/10/2011 13:07:31.843 [0x0-0xd00d].com.phaseone.captureone: Darwin Kernel Version 11.2.0: Tue Aug 9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
27/10/2011 13:07:31.843 [0x0-0xd00d].com.phaseone.captureone: cpu i486 (Intel 80486, type=0x7 subtype=0x4 threadtype=0x1)
27/10/2011 13:07:31.843 [0x0-0xd00d].com.phaseone.captureone: physical_cpu 2
27/10/2011 13:07:31.843 [0x0-0xd00d].com.phaseone.captureone: logical_cpu 4
27/10/2011 13:07:31.843 [0x0-0xd00d].com.phaseone.captureone: Toal memory 8192 MB
27/10/2011 13:07:31.843 [0x0-0xd00d].com.phaseone.captureone: Single block (V)memory 6851 MB
27/10/2011 13:07:34.706 Capture One: This is Capture One 6.2.2.50756.50514
27/10/2011 13:07:34.706 Capture One: Running in 64 bit!
27/10/2011 13:07:36.022 com.apple.launchd: (com.aladdin.hasplmd[223]) Job appears to have crashed: Bus error: 10
27/10/2011 13:07:36.022 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:07:36.041 ReportCrash: Saved crash report for hasplmd[223] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130736_localhost.crash
27/10/2011 13:07:36.495 iCal: Lock Contention on CalendarStore Initialization
27/10/2011 13:07:37.301 talagent: CGSConnectionRelinquishWindowRights(cid, newWindowNumber, reservedRights): CGError 1001 on line 619
27/10/2011 13:07:37.647 Mail: Using V2 Layout
27/10/2011 13:07:38.900 iCal: ServerNotifications: Setting delegate to APSD
27/10/2011 13:07:44.556 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 13:59
27/10/2011 13:07:44.557 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:21
27/10/2011 13:07:45.104 Capture One: --> Loading system profiles took 4.78 seconds
27/10/2011 13:07:46.170 com.apple.launchd: (com.aladdin.hasplmd[247]) Job appears to have crashed: Bus error: 10
27/10/2011 13:07:46.170 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:07:46.184 ReportCrash: Saved crash report for hasplmd[247] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130746_localhost.crash
27/10/2011 13:07:49.652 iCal: Subscription request completed
27/10/2011 13:07:54.837 [0x0-0xd00d].com.phaseone.captureone: Darwin Kernel Version 11.2.0: Tue Aug 9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
27/10/2011 13:07:54.837 [0x0-0xd00d].com.phaseone.captureone: cpu i486 (Intel 80486, type=0x7 subtype=0x4 threadtype=0x1)
27/10/2011 13:07:54.837 [0x0-0xd00d].com.phaseone.captureone: physical_cpu 2
27/10/2011 13:07:54.837 [0x0-0xd00d].com.phaseone.captureone: logical_cpu 4
27/10/2011 13:07:54.837 [0x0-0xd00d].com.phaseone.captureone: Toal memory 8192 MB
27/10/2011 13:07:54.837 [0x0-0xd00d].com.phaseone.captureone: Single block (V)memory 6195 MB
27/10/2011 13:07:54.844 [0x0-0xd00d].com.phaseone.captureone: Darwin Kernel Version 11.2.0: Tue Aug 9 20:54:00 PDT 2011; root:xnu-1699.24.8~1/RELEASE_X86_64
27/10/2011 13:07:54.844 [0x0-0xd00d].com.phaseone.captureone: cpu i486 (Intel 80486, type=0x7 subtype=0x4 threadtype=0x1)
27/10/2011 13:07:54.844 [0x0-0xd00d].com.phaseone.captureone: physical_cpu 2
27/10/2011 13:07:54.844 [0x0-0xd00d].com.phaseone.captureone: logical_cpu 4
27/10/2011 13:07:54.844 [0x0-0xd00d].com.phaseone.captureone: Toal memory 8192 MB
27/10/2011 13:07:54.844 [0x0-0xd00d].com.phaseone.captureone: Single block (V)memory 6193 MB
27/10/2011 13:07:56.071 [0x0-0xf00f].com.apple.iTunes: The plugin 'Quartz Composer Visualizer' failed to load because it has the wrong CPU architecture for this version of iTunes. (3585)
27/10/2011 13:07:56.320 com.apple.launchd: (com.aladdin.hasplmd[250]) Job appears to have crashed: Bus error: 10
27/10/2011 13:07:56.320 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:07:56.333 ReportCrash: Saved crash report for hasplmd[250] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130756_localhost.crash
27/10/2011 13:07:59.561 Time Out: Idle 18446461654.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:07:59.562 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:07:59.812 Capture One: **** prepareNewStatement:@"SELECT * FROM VERSION" failed!
27/10/2011 13:08:00.775 Capture One: Total variant count: 3054
27/10/2011 13:08:00.775 Capture One: [LOAD] SELECTs took 0.44 s
27/10/2011 13:08:00.870 Capture One: Deleted 12 stale objects from the session.
27/10/2011 13:08:00.870 Capture One: [LOAD] Cleanup SELECTs took 94 ms
27/10/2011 13:08:00.898 CaptureCoreServer: initialized:
27/10/2011 13:08:00.899 [0x0-0xd00d].com.phaseone.captureone: 2011-10-27 13:08:00.896 CaptureCoreServer[255:107] initialized:
27/10/2011 13:08:00.934 Capture One: Unknown key in ImageCore template: IB_S_BASIC_LABEL
27/10/2011 13:08:00.934 Capture One: Unknown key in ImageCore template: IB_S_IMAGE_PEOPLE
27/10/2011 13:08:00.934 Capture One: Unknown key in ImageCore template: IB_S_IMAGE_STATUS
27/10/2011 13:08:00.934 Capture One: Unknown key in ImageCore template: IB_S_IMAGE_EVENT
27/10/2011 13:08:01.000 Capture One: [LOAD] Initialization took 0.12 s
27/10/2011 13:08:02.725 Capture One: Fetched image settings for 3050 images
27/10/2011 13:08:02.725 Capture One: [CACHE LOAD] SELECTs took 0.78 s
27/10/2011 13:08:02.778 Capture One: [CACHE LOAD] Initialization took 54 ms
27/10/2011 13:08:04.969 Capture One: [CACHE LOAD] Awakening took 2.19 s
27/10/2011 13:08:04.969 Capture One: [CACHE LOAD] Total load time: 3.02 s
27/10/2011 13:08:05.297 Capture One: [LOAD] Awakening took 0.33 s
27/10/2011 13:08:05.297 Capture One: [LOAD] Total load time: 4.01 s
27/10/2011 13:08:06.370 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:08:06.438 Capture One: Started thread 0
27/10/2011 13:08:06.439 Capture One: Starting thread 0
27/10/2011 13:08:06.576 com.apple.launchd: (com.aladdin.hasplmd[261]) Job appears to have crashed: Bus error: 10
27/10/2011 13:08:06.576 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:08:06.641 ReportCrash: Saved crash report for hasplmd[261] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130806_localhost.crash
27/10/2011 13:08:07.222 [0x0-0xd00d].com.phaseone.captureone: Entry DeviceAdded routine
27/10/2011 13:08:07.223 [0x0-0xd00d].com.phaseone.captureone: Entry DeviceAdded routine
27/10/2011 13:08:07.224 [0x0-0xd00d].com.phaseone.captureone: Entry DeviceAdded routine
27/10/2011 13:08:07.444 Adobe Photoshop CS5: CFURLCreateWithString was passed this invalid URL string: '/System/Library/Frameworks/' (a file system path instead of an URL string). The URL created will not work with most file URL functions. CFURLCreateWithFileSystemPath or CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
27/10/2011 13:08:07.645 [0x0-0x12012].com.adobe.Photoshop: ScriptUI: 1[0]: 2.146014 (FlexServer performance info) 0.200 seconds to load /Applications/Adobe Photoshop CS5/Plug-ins/Extensions/ScriptingSupport.plugin/Contents/Resources
27/10/2011 13:08:07.868 [0x0-0x12012].com.adobe.Photoshop: ScriptUI: 3[0]: 2.369001 (FlexServer performance info) 0.250 seconds for server SWF to initialize
27/10/2011 13:08:07.963 [0x0-0x12012].com.adobe.Photoshop: ScriptUI: 6[0]: 2.463391 (FlexServer performance info) 0.100 seconds to load /Applications/Adobe%20Photoshop%20CS5/Plug-ins/Extensions/ScriptingSupport.plugin/Contents/Resources/ScriptUIFlexPhotoshop.swf
27/10/2011 13:08:13.000 kernel: NVDA(Compute): Channel exception! exception type = 0xd = GR: SW Notify Error
27/10/2011 13:08:13.000 kernel: IOVendorGLContext::ReportGPURestart
27/10/2011 13:08:13.000 kernel: 0000006e
27/10/2011 13:08:13.000 kernel: 00200000 000050c0 00000474 00000100
27/10/2011 13:08:13.000 kernel: 0000047e 00000368 00000000 00000013
27/10/2011 13:08:13.000 kernel: 00000000 00000000 01902003
27/10/2011 13:08:13.000 kernel: 00000100 00000000
27/10/2011 13:08:14.560 Time Out: Idle 18446461669.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:08:14.561 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:08:15.300 [0x0-0xd00d].com.phaseone.captureone: objc[189]: Object 0x160c07050 of class __NSCFNumber autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:08:15.300 [0x0-0xd00d].com.phaseone.captureone: objc[189]: Object 0x183da8e80 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:08:15.300 [0x0-0xd00d].com.phaseone.captureone: objc[189]: Object 0x18402fa60 of class NSCalendarDate autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:08:15.300 [0x0-0xd00d].com.phaseone.captureone: objc[189]: Object 0x184047060 of class __NSCFString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
27/10/2011 13:08:15.844 sandboxd: ([267]) DumpGPURestart(267) deny file-write-create /Library/Application Support/SubmitDiagInfo
27/10/2011 13:08:15.970 sandboxd: ([267]) DumpGPURestart(267) deny ipc-posix-shm apple.shm.notification_center
27/10/2011 13:08:15.971 sandboxd: ([267]) DumpGPURestart(267) deny ipc-posix-shm apple.shm.notification_center
27/10/2011 13:08:15.973 sandboxd: ([267]) DumpGPURestart(267) deny ipc-posix-shm apple.shm.notification_center
27/10/2011 13:08:15.974 sandboxd: ([267]) DumpGPURestart(267) deny ipc-posix-shm apple.shm.notification_center
27/10/2011 13:08:15.975 sandboxd: ([267]) DumpGPURestart(267) deny ipc-posix-shm apple.shm.notification_center
27/10/2011 13:08:15.977 sandboxd: ([267]) DumpGPURestart(267) deny file-read-metadata /Library/Managed Preferences
27/10/2011 13:08:16.167 librariand: changing log level to 5
27/10/2011 13:08:16.730 com.apple.launchd: (com.aladdin.hasplmd[270]) Job appears to have crashed: Bus error: 10
27/10/2011 13:08:16.730 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:08:16.744 ReportCrash: Saved crash report for hasplmd[270] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130816_localhost.crash
27/10/2011 13:08:26.918 com.apple.launchd: (com.aladdin.hasplmd[274]) Job appears to have crashed: Bus error: 10
27/10/2011 13:08:26.918 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:08:26.933 ReportCrash: Saved crash report for hasplmd[274] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130826_localhost.crash
27/10/2011 13:08:29.191 librariand: copy_framework_connection(framework_client.c:241): couldn't connect to server: 61: 61 (Connection refused)
27/10/2011 13:08:29.191 librariand: IPCSyncingEnabled(framework_client.c:706): failed to run server: -1
27/10/2011 13:08:29.276 com.apple.launchd.peruser.501: (0x7f9b4ad08b00.anonymous.CS5ServiceManag[266]) The following job tried to hijack the service "com.adobe.csi.CS5ServiceManager" from this job: com.adobe.CS5ServiceManager
27/10/2011 13:08:29.479 iScreenServer: iScreenServer version=2.0.4 date=Jul 21 2011 16:27:13 protocol 2
27/10/2011 13:08:29.485 iScreenServer: 10.7
27/10/2011 13:08:29.573 Adobe Acrobat Updater Helper: Adobe Acrobat Updater encountered errorCode 260
27/10/2011 13:08:29.574 Time Out: Idle 18446461684.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:08:29.576 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:08:29.581 Adobe Acrobat Updater Helper: Adobe Acrobat Updater encountered errorCode 1001
27/10/2011 13:08:30.319 [0x0-0x2b02b].LUTLoader: QPixmap::fromMimeSource: Cannot find pixmap "loading.png" in the mime source factory
27/10/2011 13:08:30.490 TabletDriver: Finish launching /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/ConsumerTouchDriver.app
27/10/2011 13:08:30.494 com.wacom.pentablet: Oct 27 13:08:30 unknown-34-15-9e-93-44-93.config TabletDriver[287] : Finish launching /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/ConsumerTouchDriver.app
27/10/2011 13:08:30.570 TabletDriver: Finish launching /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/TabletDriver.app
27/10/2011 13:08:30.571 com.wacom.pentablet: Oct 27 13:08:30 unknown-34-15-9e-93-44-93.config TabletDriver[287] : Finish launching /Library/Application Support/Tablet/PenTabletDriver.app/Contents/Resources/TabletDriver.app
27/10/2011 13:08:31.164 [0x0-0x2d02d].com.xrite.i1ProfilerTray: [ "Thu Oct 27 13:08:31 2011" ] ERROR "SumoSDKWrapperBase.cpp:746 : Failed to get device"
27/10/2011 13:08:31.672 com.apple.launchd.peruser.501: ([0x0-0x2b02b].LUTLoader[299]) Exited with code: 9
27/10/2011 13:08:32.759 com.apple.launchd.peruser.501: ([0x0-0x35035].com.wacom.TabletDriver[305]) The following job tried to hijack the service "com.wacom.CoordinatorMessageServer" from this job: [0x0-0x36036].com.wacom.TabletDriver
27/10/2011 13:08:33.666 librariand: no ubiquity account configured, not creating collection
27/10/2011 13:08:33.666 librariand: error in handle_client_request: LibrarianErrorDomain/10/Unable to configure the collection.
27/10/2011 13:08:36.172 com.apple.launchd.peruser.501: ([0x0-0x35035].com.wacom.TabletDriver[305]) Exited: Terminated: 15
27/10/2011 13:08:37.192 TabletDriver: Finish launching /Library/Application Support/Tablet/WacomTabletDriver.app/Contents/Resources/TabletDriver.app
27/10/2011 13:08:37.193 com.wacom.wacomtablet: Oct 27 13:08:37 unknown-34-15-9e-93-44-93.config TabletDriver[286] : Finish launching /Library/Application Support/Tablet/WacomTabletDriver.app/Contents/Resources/TabletDriver.app
27/10/2011 13:08:37.541 com.apple.launchd: (com.aladdin.hasplmd[317]) Job appears to have crashed: Bus error: 10
27/10/2011 13:08:37.541 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:08:37.563 ReportCrash: Saved crash report for hasplmd[317] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130837_localhost.crash
27/10/2011 13:08:40.183 librariand: no ubiquity account configured, not creating collection
27/10/2011 13:08:40.183 librariand: error in handle_client_request: LibrarianErrorDomain/10/Unable to configure the collection.
27/10/2011 13:08:42.075 com.apple.Finder: Dropbox: Entered INJECT_pthread_entry
27/10/2011 13:08:42.075 com.apple.Finder: Dropbox: Installing event loop timer
27/10/2011 13:08:42.075 com.apple.Finder: Dropbox: proc: 0x10fabbe5b
27/10/2011 13:08:42.075 com.apple.Finder: Dropbox: upp: 0x10fabbe5b
27/10/2011 13:08:42.075 com.apple.Finder: Dropbox: InstallEventLoopTimer: 0x7fff8fe460de
27/10/2011 13:08:42.075 com.apple.Finder: Dropbox: GetMainEventLoop: 0x7fff8fe07861
27/10/2011 13:08:42.075 com.apple.Finder: Dropbox: timer installed!
27/10/2011 13:08:42.075 com.apple.Finder: Dropbox: Loading /Library/DropboxHelperTools/Dropbox_u501/DropboxBundle.bundle/Contents/MacOS/DropboxBundle
27/10/2011 13:08:42.075 com.apple.Finder: module initializer in main thread?: 1
27/10/2011 13:08:42.077 com.apple.Finder: Dropbox: dlopen returned: 0x7ff9eca23e20
27/10/2011 13:08:44.600 Time Out: Idle 18446461699.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:08:44.604 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:08:47.967 com.apple.launchd: (com.aladdin.hasplmd[332]) Job appears to have crashed: Bus error: 10
27/10/2011 13:08:47.967 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:08:48.002 ReportCrash: Saved crash report for hasplmd[332] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130847_localhost.crash
27/10/2011 13:08:50.721 mdworker: zip importer encountered an error (2) scanning "/Users/iaincrawford/Downloads/lowres.zip".
27/10/2011 13:08:58.190 com.apple.launchd: (com.aladdin.hasplmd[333]) Job appears to have crashed: Bus error: 10
27/10/2011 13:08:58.190 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:08:58.248 ReportCrash: Saved crash report for hasplmd[333] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130858_localhost.crash
27/10/2011 13:08:59.560 Time Out: Idle 18446461714.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:08:59.562 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:09:08.223 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:09:08.436 com.apple.launchd: (com.aladdin.hasplmd[335]) Job appears to have crashed: Bus error: 10
27/10/2011 13:09:08.436 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:09:08.529 ReportCrash: Saved crash report for hasplmd[335] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130908_localhost.crash
27/10/2011 13:09:14.561 Time Out: Idle 18446461729.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:09:14.562 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:09:18.655 com.apple.launchd: (com.aladdin.hasplmd[340]) Job appears to have crashed: Bus error: 10
27/10/2011 13:09:18.655 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:09:18.678 ReportCrash: Saved crash report for hasplmd[340] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130918_localhost.crash
27/10/2011 13:09:28.865 com.apple.launchd: (com.aladdin.hasplmd[342]) Job appears to have crashed: Bus error: 10
27/10/2011 13:09:28.865 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:09:28.974 ReportCrash: Saved crash report for hasplmd[342] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130928_localhost.crash
27/10/2011 13:09:29.561 Time Out: Idle 18446461744.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:09:29.562 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:09:39.080 com.apple.launchd: (com.aladdin.hasplmd[343]) Job appears to have crashed: Bus error: 10
27/10/2011 13:09:39.080 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:09:39.129 ReportCrash: Saved crash report for hasplmd[343] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130939_localhost.crash
27/10/2011 13:09:44.561 Time Out: Idle 18446461759.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:09:44.562 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:09:49.281 com.apple.launchd: (com.aladdin.hasplmd[344]) Job appears to have crashed: Bus error: 10
27/10/2011 13:09:49.281 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:09:49.331 ReportCrash: Saved crash report for hasplmd[344] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130949_localhost.crash
27/10/2011 13:09:59.483 com.apple.launchd: (com.aladdin.hasplmd[345]) Job appears to have crashed: Bus error: 10
27/10/2011 13:09:59.483 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:09:59.499 ReportCrash: Saved crash report for hasplmd[345] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-130959_localhost.crash
27/10/2011 13:09:59.561 Time Out: Idle 18446461774.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:09:59.563 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:10:09.515 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:10:09.708 com.apple.launchd: (com.aladdin.hasplmd[348]) Job appears to have crashed: Bus error: 10
27/10/2011 13:10:09.708 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:10:09.772 ReportCrash: Saved crash report for hasplmd[348] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131009_localhost.crash
27/10/2011 13:10:14.562 Time Out: Idle 18446461789.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:10:14.563 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:10:19.932 com.apple.launchd: (com.aladdin.hasplmd[350]) Job appears to have crashed: Bus error: 10
27/10/2011 13:10:19.932 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:10:19.953 ReportCrash: Saved crash report for hasplmd[350] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131019_localhost.crash
27/10/2011 13:10:29.561 Time Out: Idle 18446461804.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:10:29.563 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:10:30.144 com.apple.launchd: (com.aladdin.hasplmd[352]) Job appears to have crashed: Bus error: 10
27/10/2011 13:10:30.144 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:10:30.188 ReportCrash: Saved crash report for hasplmd[352] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131030_localhost.crash
27/10/2011 13:10:40.347 com.apple.launchd: (com.aladdin.hasplmd[353]) Job appears to have crashed: Bus error: 10
27/10/2011 13:10:40.347 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:10:40.365 ReportCrash: Saved crash report for hasplmd[353] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131040_localhost.crash
27/10/2011 13:10:44.562 Time Out: Idle 18446461819.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:10:44.563 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:10:50.540 com.apple.launchd: (com.aladdin.hasplmd[354]) Job appears to have crashed: Bus error: 10
27/10/2011 13:10:50.540 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:10:50.562 ReportCrash: Saved crash report for hasplmd[354] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131050_localhost.crash
27/10/2011 13:10:59.563 Time Out: Idle 18446461834.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:10:59.564 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:11:00.745 com.apple.launchd: (com.aladdin.hasplmd[355]) Job appears to have crashed: Bus error: 10
27/10/2011 13:11:00.745 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:11:00.767 ReportCrash: Saved crash report for hasplmd[355] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131100_localhost.crash
27/10/2011 13:11:10.362 Safari: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
27/10/2011 13:11:10.363 Safari: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
27/10/2011 13:11:10.780 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:11:10.988 com.apple.launchd: (com.aladdin.hasplmd[356]) Job appears to have crashed: Bus error: 10
27/10/2011 13:11:10.988 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:11:11.066 ReportCrash: Saved crash report for hasplmd[356] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131111_localhost.crash
27/10/2011 13:11:11.981 mdworker: zip importer encountered an error (2) scanning "/Users/iaincrawford/Downloads/lowres-2.zip".
27/10/2011 13:11:14.562 Time Out: Idle 18446461849.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:11:14.564 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:11:21.205 com.apple.launchd: (com.aladdin.hasplmd[359]) Job appears to have crashed: Bus error: 10
27/10/2011 13:11:21.205 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:11:21.227 ReportCrash: Saved crash report for hasplmd[359] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131121_localhost.crash
27/10/2011 13:11:29.563 Time Out: Idle 18446461864.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:11:29.564 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:11:31.404 com.apple.launchd: (com.aladdin.hasplmd[361]) Job appears to have crashed: Bus error: 10
27/10/2011 13:11:31.404 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:11:31.423 ReportCrash: Saved crash report for hasplmd[361] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131131_localhost.crash
27/10/2011 13:11:41.092 helpd: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
27/10/2011 13:11:41.093 helpd: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
27/10/2011 13:11:41.630 com.apple.launchd: (com.aladdin.hasplmd[365]) Job appears to have crashed: Bus error: 10
27/10/2011 13:11:41.630 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:11:41.652 ReportCrash: Saved crash report for hasplmd[365] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131141_localhost.crash
27/10/2011 13:11:44.587 Time Out: Idle 18446461879.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:11:44.589 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:11:51.833 com.apple.launchd: (com.aladdin.hasplmd[367]) Job appears to have crashed: Bus error: 10
27/10/2011 13:11:51.833 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:11:51.854 ReportCrash: Saved crash report for hasplmd[367] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131151_localhost.crash
27/10/2011 13:11:59.564 Time Out: Idle 18446461894.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:11:59.565 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:11:59.857 Numbers: Object (0x3087ff0 of class __NSCFDictionary) named "NSMutableDictionary-0" was already registered with another name "NSMutableDictionary-2".
27/10/2011 13:11:59.857 Numbers: Object (0x3087ff0 of class __NSCFDictionary) named "NSMutableDictionary-0" was already registered with another name "NSMutableDictionary-3".
27/10/2011 13:12:00.106 Numbers: Object (0x3087ff0 of class __NSCFDictionary) named "NSMutableDictionary-0" was already registered with another name "NSDictionary-0".
27/10/2011 13:12:00.106 Numbers: Object (0x3087ff0 of class __NSCFDictionary) named "NSMutableDictionary-0" was already registered with another name "NSMutableDictionary-4".
27/10/2011 13:12:00.114 Numbers: Object (0x3087ff0 of class __NSCFDictionary) named "NSMutableDictionary-0" was already registered with another name "NSMutableDictionary-5".
27/10/2011 13:12:00.136 Numbers: Object (0x3087ff0 of class __NSCFDictionary) named "NSMutableDictionary-0" was already registered with another name "NSMutableDictionary-7".
27/10/2011 13:12:00.141 Numbers: Object (0x3087ff0 of class __NSCFDictionary) named "NSMutableDictionary-0" was already registered with another name "NSMutableDictionary-8".
27/10/2011 13:12:00.147 Numbers: Object (0x3087ff0 of class __NSCFDictionary) named "NSMutableDictionary-0" was already registered with another name "NSMutableDictionary-9".
27/10/2011 13:12:00.168 Numbers: NameKeyHashSet and ObjectHashMap out of sync: object map entry for __NSCFDictionary 0x3087ff0 references name "NSMutableDictionary-0" instead of "NSMutableDictionary-7"
27/10/2011 13:12:00.169 Numbers: NameKeyHashSet and ObjectHashMap out of sync: object map entry for __NSCFDictionary 0x3087ff0 references name "NSMutableDictionary-0" instead of "NSMutableDictionary-8"
27/10/2011 13:12:00.169 Numbers: NameKeyHashSet and ObjectHashMap out of sync: object map entry for __NSCFDictionary 0x3087ff0 references name "NSMutableDictionary-0" instead of "NSMutableDictionary-9"
27/10/2011 13:12:00.169 Numbers: NameKeyHashSet and ObjectHashMap out of sync: object map entry for __NSCFDictionary 0x3087ff0 references name "NSMutableDictionary-0" instead of "NSMutableDictionary-2"
27/10/2011 13:12:00.169 Numbers: NameKeyHashSet and ObjectHashMap out of sync: object map entry for __NSCFDictionary 0x3087ff0 references name "NSMutableDictionary-0" instead of "NSDictionary-0"
27/10/2011 13:12:00.169 Numbers: NameKeyHashSet and ObjectHashMap out of sync: object map entry for __NSCFDictionary 0x3087ff0 references name "NSMutableDictionary-0" instead of "NSMutableDictionary-3"
27/10/2011 13:12:00.170 Numbers: NameKeyHashSet and ObjectHashMap out of sync: object map entry for __NSCFDictionary 0x3087ff0 references name "NSMutableDictionary-0" instead of "NSMutableDictionary-4"
27/10/2011 13:12:00.170 Numbers: NameKeyHashSet and ObjectHashMap out of sync: object map entry for __NSCFDictionary 0x3087ff0 references name "NSMutableDictionary-0" instead of "NSMutableDictionary-5"
27/10/2011 13:12:01.960 librariand: no ubiquity account configured, not creating collection
27/10/2011 13:12:01.960 librariand: error in handle_client_request: LibrarianErrorDomain/10/Unable to configure the collection.
27/10/2011 13:12:02.068 com.apple.launchd: (com.aladdin.hasplmd[371]) Job appears to have crashed: Bus error: 10
27/10/2011 13:12:02.068 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:12:02.097 ReportCrash: Saved crash report for hasplmd[371] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131202_localhost.crash
27/10/2011 13:12:12.098 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:12:12.275 com.apple.launchd: (com.aladdin.hasplmd[375]) Job appears to have crashed: Bus error: 10
27/10/2011 13:12:12.275 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:12:12.336 ReportCrash: Saved crash report for hasplmd[375] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131212_localhost.crash
27/10/2011 13:12:14.563 Time Out: Idle 18446461909.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:12:14.564 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:12:22.473 com.apple.launchd: (com.aladdin.hasplmd[377]) Job appears to have crashed: Bus error: 10
27/10/2011 13:12:22.473 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:12:22.490 ReportCrash: Saved crash report for hasplmd[377] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131222_localhost.crash
27/10/2011 13:12:29.564 Time Out: Idle 18446461924.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:12:29.566 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:12:32.677 com.apple.launchd: (com.aladdin.hasplmd[378]) Job appears to have crashed: Bus error: 10
27/10/2011 13:12:32.677 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:12:32.695 ReportCrash: Saved crash report for hasplmd[378] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131232_localhost.crash
27/10/2011 13:12:42.876 com.apple.launchd: (com.aladdin.hasplmd[381]) Job appears to have crashed: Bus error: 10
27/10/2011 13:12:42.876 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:12:42.891 ReportCrash: Saved crash report for hasplmd[381] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131242_localhost.crash
27/10/2011 13:12:44.563 Time Out: Idle 18446461939.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:12:44.564 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:12:53.083 com.apple.launchd: (com.aladdin.hasplmd[382]) Job appears to have crashed: Bus error: 10
27/10/2011 13:12:53.083 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:12:53.106 ReportCrash: Saved crash report for hasplmd[382] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131253_localhost.crash
27/10/2011 13:12:59.564 Time Out: Idle 18446461954.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:21
27/10/2011 13:12:59.565 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:12:59.566 Time Out: ...resetting micro timer
27/10/2011 13:12:59.567 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:26
27/10/2011 13:13:01.010 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:01.010 Capture One: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
27/10/2011 13:13:01.097 Capture One: [SAVE] Patching existing database
27/10/2011 13:13:01.097 Capture One: [SAVE] Init took 0 ms
27/10/2011 13:13:01.097 Capture One: Deleted 4 PKs from Variant
27/10/2011 13:13:01.098 Capture One: Deleted 4 PKs from VariantSettings
27/10/2011 13:13:01.098 Capture One: Deleted 4 PKs from ImageSettings
27/10/2011 13:13:01.098 Capture One: Deleted 4 PKs from Metadata
27/10/2011 13:13:01.098 Capture One: Deleted 8 PKs from VariantLayer
27/10/2011 13:13:01.098 Capture One: [SAVE] Deletes took 1 ms
27/10/2011 13:13:01.195 Capture One: [SAVE] Inserts took 0.11 s (PK assignment took 0.11 s, -willSaves took 2 ms)
27/10/2011 13:13:01.295 Capture One: [SAVE] Updates took 0.19 s (-willSaves took 56 ms)
27/10/2011 13:13:01.317 Capture One: [SAVE] Commit took 5 ms
27/10/2011 13:13:01.317 Capture One: [SAVE] Total save time 0.36 s
27/10/2011 13:13:01.318 Capture One: Autosave took 0.36 s (min=0.36 s, max=0.36 s)
27/10/2011 13:13:01.319 Capture One: [BACKGROUND SAVE] Saving
27/10/2011 13:13:01.319 Capture One: [BACKGROUND SAVE] Pruning 4 imageSettings hierarchies from the cache
27/10/2011 13:13:01.685 Capture One: [BACKGROUND SAVE] Pruning 4 imageSettings hierarchies from the cache
27/10/2011 13:13:02.158 Capture One: [BACKGROUND SAVE] Total save time 2.36 s (min=2.36 s, max=2.36 s)
27/10/2011 13:13:03.334 com.apple.launchd: (com.aladdin.hasplmd[383]) Job appears to have crashed: Bus error: 10
27/10/2011 13:13:03.334 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:13:03.351 ReportCrash: Saved crash report for hasplmd[383] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131303_localhost.crash
27/10/2011 13:13:13.433 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:13:13.720 com.apple.launchd: (com.aladdin.hasplmd[384]) Job appears to have crashed: Bus error: 10
27/10/2011 13:13:13.720 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:13:13.994 ReportCrash: Saved crash report for hasplmd[384] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131313_localhost.crash
27/10/2011 13:13:14.564 Time Out: Idle 18446461969.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:26
27/10/2011 13:13:14.565 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:13:14.566 Time Out: ...resetting micro timer
27/10/2011 13:13:14.567 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:27
27/10/2011 13:13:20.759 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:20.781 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:20.855 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:20.869 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:20.943 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:20.955 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:20.976 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:24.020 com.apple.launchd: (com.aladdin.hasplmd[386]) Job appears to have crashed: Bus error: 10
27/10/2011 13:13:24.020 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:13:24.042 ReportCrash: Saved crash report for hasplmd[386] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131324_localhost.crash
27/10/2011 13:13:27.563 Capture One: [SAVE] Patching existing database
27/10/2011 13:13:27.563 Capture One: [SAVE] Init took 1 ms
27/10/2011 13:13:27.694 Capture One: [SAVE] Inserts took 0.18 s (PK assignment took 81 ms, -willSaves took 18 ms)
27/10/2011 13:13:27.696 Capture One: [SAVE] Updates took 3 ms (-willSaves took 1 ms)
27/10/2011 13:13:27.718 Capture One: [SAVE] Commit took 2 ms
27/10/2011 13:13:27.719 Capture One: [SAVE] Total save time 0.22 s
27/10/2011 13:13:27.719 Capture One: Autosave took 0.22 s (min=0.22 s, max=0.36 s)
27/10/2011 13:13:27.720 Capture One: [BACKGROUND SAVE] Saving
27/10/2011 13:13:28.077 Capture One: [BACKGROUND SAVE] Total save time 0.57 s (min=0.57 s, max=2.36 s)
27/10/2011 13:13:29.564 Time Out: Idle 18446461984.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:27
27/10/2011 13:13:29.565 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:13:29.566 Time Out: ...resetting micro timer
27/10/2011 13:13:29.567 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:27
27/10/2011 13:13:34.230 com.apple.launchd: (com.aladdin.hasplmd[387]) Job appears to have crashed: Bus error: 10
27/10/2011 13:13:34.230 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:13:34.252 ReportCrash: Saved crash report for hasplmd[387] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131334_localhost.crash
27/10/2011 13:13:44.437 com.apple.launchd: (com.aladdin.hasplmd[388]) Job appears to have crashed: Bus error: 10
27/10/2011 13:13:44.437 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:13:44.455 ReportCrash: Saved crash report for hasplmd[388] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131344_localhost.crash
27/10/2011 13:13:44.564 Time Out: Idle 18446461999.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:27
27/10/2011 13:13:44.565 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:13:44.566 Time Out: ...resetting micro timer
27/10/2011 13:13:44.567 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:27
27/10/2011 13:13:54.645 com.apple.launchd: (com.aladdin.hasplmd[389]) Job appears to have crashed: Bus error: 10
27/10/2011 13:13:54.645 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:13:54.667 ReportCrash: Saved crash report for hasplmd[389] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131354_localhost.crash
27/10/2011 13:13:57.095 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:57.109 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:57.120 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:57.143 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:57.171 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:57.180 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:57.216 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:57.219 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:57.250 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:57.272 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:57.302 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:13:59.565 Time Out: Idle 18446462014.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:27
27/10/2011 13:13:59.566 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:13:59.567 Time Out: ...resetting micro timer
27/10/2011 13:13:59.568 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:27
27/10/2011 13:14:04.874 com.apple.launchd: (com.aladdin.hasplmd[391]) Job appears to have crashed: Bus error: 10
27/10/2011 13:14:04.874 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:14:04.896 ReportCrash: Saved crash report for hasplmd[391] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131404_localhost.crash
27/10/2011 13:14:14.568 Time Out: Idle 18446462029.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:27
27/10/2011 13:14:14.573 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:14:14.576 Time Out: ...resetting micro timer
27/10/2011 13:14:14.579 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:28
27/10/2011 13:14:14.908 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:14:15.123 com.apple.launchd: (com.aladdin.hasplmd[395]) Job appears to have crashed: Bus error: 10
27/10/2011 13:14:15.123 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:14:15.210 ReportCrash: Saved crash report for hasplmd[395] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131415_localhost.crash
27/10/2011 13:14:16.968 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:17.086 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:17.127 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.020 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.030 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.045 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.063 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.079 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.088 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.107 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.120 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.130 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.145 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.156 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.166 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.174 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.192 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.200 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.216 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.225 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.233 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.241 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.251 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.267 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:18.284 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:19.942 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:19.957 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:19.973 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:19.984 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.001 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.018 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.027 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.043 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.060 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.077 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.093 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.101 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.123 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.139 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.149 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.157 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.164 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.177 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.188 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.203 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.213 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.220 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.226 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.234 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.241 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.249 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.262 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.274 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.293 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.308 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.319 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.335 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.345 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.365 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.384 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.395 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.403 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.416 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.444 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.818 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.834 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.858 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.877 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.899 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.923 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.945 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.963 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:20.984 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.040 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.059 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.104 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.129 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.166 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.194 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.249 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.275 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.308 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.339 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.382 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.410 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.466 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.827 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:21.975 Capture One: [SAVE] Patching existing database
27/10/2011 13:14:21.975 Capture One: [SAVE] Init took 1 ms
27/10/2011 13:14:21.980 Capture One: Deleted 5 PKs from Stack
27/10/2011 13:14:21.981 Capture One: [SAVE] Deletes took 0 ms
27/10/2011 13:14:21.985 Capture One: [SAVE] Updates took 2 ms (-willSaves took 1 ms)
27/10/2011 13:14:22.015 Capture One: [SAVE] Commit took 0 ms
27/10/2011 13:14:22.015 Capture One: [SAVE] Total save time 32 ms
27/10/2011 13:14:22.015 Capture One: Autosave took 32 ms (min=32 ms, max=0.36 s)
27/10/2011 13:14:22.016 Capture One: [BACKGROUND SAVE] Saving
27/10/2011 13:14:22.141 Capture One: [BACKGROUND SAVE] Total save time 0.25 s (min=0.25 s, max=2.36 s)
27/10/2011 13:14:25.721 com.apple.launchd: (com.aladdin.hasplmd[401]) Job appears to have crashed: Bus error: 10
27/10/2011 13:14:25.721 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:14:26.286 ReportCrash: Saved crash report for hasplmd[401] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131425_localhost.crash
27/10/2011 13:14:29.567 Time Out: Idle 18446462044.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:28
27/10/2011 13:14:29.568 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:14:29.569 Time Out: ...resetting micro timer
27/10/2011 13:14:29.570 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:28
27/10/2011 13:14:35.929 com.apple.launchd: (com.aladdin.hasplmd[405]) Job appears to have crashed: Bus error: 10
27/10/2011 13:14:35.929 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:14:35.948 ReportCrash: Saved crash report for hasplmd[405] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131435_localhost.crash
27/10/2011 13:14:44.565 Time Out: Idle 18446462059.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:28
27/10/2011 13:14:44.566 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:14:44.567 Time Out: ...resetting micro timer
27/10/2011 13:14:44.568 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:28
27/10/2011 13:14:46.149 com.apple.launchd: (com.aladdin.hasplmd[406]) Job appears to have crashed: Bus error: 10
27/10/2011 13:14:46.149 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:14:46.170 ReportCrash: Saved crash report for hasplmd[406] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131446_localhost.crash
27/10/2011 13:14:56.375 com.apple.launchd: (com.aladdin.hasplmd[407]) Job appears to have crashed: Bus error: 10
27/10/2011 13:14:56.375 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:14:56.396 ReportCrash: Saved crash report for hasplmd[407] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131456_localhost.crash
27/10/2011 13:14:57.051 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:14:59.566 Time Out: Idle 18446462074.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:28
27/10/2011 13:14:59.568 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:14:59.568 Time Out: ...resetting micro timer
27/10/2011 13:14:59.569 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:28
27/10/2011 13:15:06.582 com.apple.launchd: (com.aladdin.hasplmd[409]) Job appears to have crashed: Bus error: 10
27/10/2011 13:15:06.582 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:15:06.604 ReportCrash: Saved crash report for hasplmd[409] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131506_localhost.crash
27/10/2011 13:15:12.288 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:12.329 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:14.686 Time Out: Idle 18446462089.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:28
27/10/2011 13:15:14.696 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:15:14.705 Time Out: ...resetting micro timer
27/10/2011 13:15:14.707 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:29
27/10/2011 13:15:16.616 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:15:16.840 com.apple.launchd: (com.aladdin.hasplmd[410]) Job appears to have crashed: Bus error: 10
27/10/2011 13:15:16.840 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:15:16.925 ReportCrash: Saved crash report for hasplmd[410] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131516_localhost.crash
27/10/2011 13:15:21.123 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:21.139 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:21.155 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:21.248 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:21.259 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:21.276 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:21.348 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:21.398 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:27.054 com.apple.launchd: (com.aladdin.hasplmd[412]) Job appears to have crashed: Bus error: 10
27/10/2011 13:15:27.054 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:15:27.076 ReportCrash: Saved crash report for hasplmd[412] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131527_localhost.crash
27/10/2011 13:15:29.170 Capture One: [SAVE] Patching existing database
27/10/2011 13:15:29.171 Capture One: [SAVE] Init took 1 ms
27/10/2011 13:15:29.253 Capture One: [SAVE] Inserts took 0.11 s (PK assignment took 80 ms, -willSaves took 9 ms)
27/10/2011 13:15:29.254 Capture One: [SAVE] Updates took 2 ms (-willSaves took 1 ms)
27/10/2011 13:15:29.276 Capture One: [SAVE] Commit took 2 ms
27/10/2011 13:15:29.276 Capture One: [SAVE] Total save time 0.15 s
27/10/2011 13:15:29.277 Capture One: Autosave took 0.15 s (min=32 ms, max=0.36 s)
27/10/2011 13:15:29.278 Capture One: [BACKGROUND SAVE] Saving
27/10/2011 13:15:29.426 Capture One: [BACKGROUND SAVE] Total save time 0.29 s (min=0.25 s, max=2.36 s)
27/10/2011 13:15:29.566 Time Out: Idle 18446462104.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:29
27/10/2011 13:15:29.567 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:15:29.568 Time Out: ...resetting micro timer
27/10/2011 13:15:29.569 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:29
27/10/2011 13:15:37.232 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.249 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.261 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.290 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.323 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.332 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.333 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.351 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.359 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.366 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.373 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.383 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.392 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.433 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.471 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.483 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.493 com.apple.launchd: (com.aladdin.hasplmd[415]) Job appears to have crashed: Bus error: 10
27/10/2011 13:15:37.493 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:15:37.495 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.504 Capture One: kCGErrorIllegalArgument: CGSRegisterCursorWithImages: Invalid hot spot (outside of size)
27/10/2011 13:15:37.522 ReportCrash: Saved crash report for hasplmd[415] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131537_localhost.crash
27/10/2011 13:15:40.134 Capture One: [SAVE] Patching existing database
27/10/2011 13:15:40.135 Capture One: [SAVE] Init took 2 ms
27/10/2011 13:15:40.136 Capture One: [SAVE] Updates took 0 ms (-willSaves took 0 ms)
27/10/2011 13:15:40.160 Capture One: [SAVE] Commit took 0 ms
27/10/2011 13:15:40.160 Capture One: [SAVE] Total save time 59 ms
27/10/2011 13:15:40.160 Capture One: Autosave took 60 ms (min=32 ms, max=0.36 s)
27/10/2011 13:15:40.161 Capture One: [BACKGROUND SAVE] Saving
27/10/2011 13:15:40.254 Capture One: [BACKGROUND SAVE] Total save time 0.28 s (min=0.25 s, max=2.36 s)
27/10/2011 13:15:44.566 Time Out: Idle 18446462119.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:29
27/10/2011 13:15:44.568 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:15:44.569 Time Out: ...resetting micro timer
27/10/2011 13:15:44.570 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:29
27/10/2011 13:15:47.691 com.apple.launchd: (com.aladdin.hasplmd[416]) Job appears to have crashed: Bus error: 10
27/10/2011 13:15:47.691 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:15:47.714 ReportCrash: Saved crash report for hasplmd[416] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131547_localhost.crash
27/10/2011 13:15:57.890 com.apple.launchd: (com.aladdin.hasplmd[417]) Job appears to have crashed: Bus error: 10
27/10/2011 13:15:57.890 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:15:57.909 ReportCrash: Saved crash report for hasplmd[417] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131557_localhost.crash
27/10/2011 13:15:59.567 Time Out: Idle 18446462134.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:29
27/10/2011 13:15:59.568 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:15:59.568 Time Out: ...resetting micro timer
27/10/2011 13:15:59.570 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:29
27/10/2011 13:16:08.095 com.apple.launchd: (com.aladdin.hasplmd[418]) Job appears to have crashed: Bus error: 10
27/10/2011 13:16:08.095 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:16:08.113 ReportCrash: Saved crash report for hasplmd[418] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131608_localhost.crash
27/10/2011 13:16:14.566 Time Out: Idle 18446462149.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:29
27/10/2011 13:16:14.567 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:16:14.568 Time Out: ...resetting micro timer
27/10/2011 13:16:14.570 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:30
27/10/2011 13:16:18.131 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:16:18.350 com.apple.launchd: (com.aladdin.hasplmd[419]) Job appears to have crashed: Bus error: 10
27/10/2011 13:16:18.350 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:16:18.416 ReportCrash: Saved crash report for hasplmd[419] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131618_localhost.crash
27/10/2011 13:16:21.600 Safari: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
27/10/2011 13:16:22.195 Safari: kCGErrorTypeCheck: CGSDispatchDatagramsFromStream : Bad datagram type 576
27/10/2011 13:16:22.195 Safari: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
27/10/2011 13:16:22.195 Safari: CGSResetPortStream: Resetting corrupt stream on connection 0xf343.
27/10/2011 13:16:22.424 EvernoteHelper: No result from Safari loading plugins.
27/10/2011 13:16:23.330 mdworker: zip importer encountered an error (2) scanning "/Users/iaincrawford/Downloads/lowres-3.zip".
27/10/2011 13:16:28.575 com.apple.launchd: (com.aladdin.hasplmd[424]) Job appears to have crashed: Bus error: 10
27/10/2011 13:16:28.575 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:16:28.592 ReportCrash: Saved crash report for hasplmd[424] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131628_localhost.crash
27/10/2011 13:16:29.566 Time Out: Idle 18446462164.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:30
27/10/2011 13:16:29.568 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:16:29.568 Time Out: ...resetting micro timer
27/10/2011 13:16:29.571 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:30
27/10/2011 13:16:38.792 com.apple.launchd: (com.aladdin.hasplmd[426]) Job appears to have crashed: Bus error: 10
27/10/2011 13:16:38.792 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:16:38.831 ReportCrash: Saved crash report for hasplmd[426] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131638_localhost.crash
27/10/2011 13:16:44.566 Time Out: Idle 18446462179.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:30
27/10/2011 13:16:44.568 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:16:44.568 Time Out: ...resetting micro timer
27/10/2011 13:16:44.570 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:30
27/10/2011 13:16:47.128 mdworker: zip importer encountered an error (2) scanning "/Users/iaincrawford/Downloads/lowres-4.zip".
27/10/2011 13:16:49.003 com.apple.launchd: (com.aladdin.hasplmd[427]) Job appears to have crashed: Bus error: 10
27/10/2011 13:16:49.003 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:16:49.021 ReportCrash: Saved crash report for hasplmd[427] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131649_localhost.crash
27/10/2011 13:16:59.222 com.apple.launchd: (com.aladdin.hasplmd[430]) Job appears to have crashed: Bus error: 10
27/10/2011 13:16:59.222 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:16:59.242 ReportCrash: Saved crash report for hasplmd[430] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131659_localhost.crash
27/10/2011 13:16:59.567 Time Out: Idle 18446462194.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:30
27/10/2011 13:16:59.568 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:16:59.568 Time Out: ...resetting micro timer
27/10/2011 13:16:59.570 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:30
27/10/2011 13:17:09.434 com.apple.launchd: (com.aladdin.hasplmd[431]) Job appears to have crashed: Bus error: 10
27/10/2011 13:17:09.434 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:17:09.453 ReportCrash: Saved crash report for hasplmd[431] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131709_localhost.crash
27/10/2011 13:17:14.566 Time Out: Idle 18446462209.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:30
27/10/2011 13:17:14.567 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:17:14.568 Time Out: ...resetting micro timer
27/10/2011 13:17:14.569 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:31
27/10/2011 13:17:19.465 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:17:19.668 com.apple.launchd: (com.aladdin.hasplmd[433]) Job appears to have crashed: Bus error: 10
27/10/2011 13:17:19.668 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:17:19.736 ReportCrash: Saved crash report for hasplmd[433] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131719_localhost.crash
27/10/2011 13:17:29.567 Time Out: Idle 18446462224.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:31
27/10/2011 13:17:29.568 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:17:29.569 Time Out: ...resetting micro timer
27/10/2011 13:17:29.570 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:31
27/10/2011 13:17:29.890 com.apple.launchd: (com.aladdin.hasplmd[435]) Job appears to have crashed: Bus error: 10
27/10/2011 13:17:29.890 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:17:29.912 ReportCrash: Saved crash report for hasplmd[435] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131729_localhost.crash
27/10/2011 13:17:34.644 warmd: [__warmctl_evt_desktop_up_block_invoke_0:478] Desktop up bcstop timer fired!
27/10/2011 13:17:40.128 com.apple.launchd: (com.aladdin.hasplmd[437]) Job appears to have crashed: Bus error: 10
27/10/2011 13:17:40.128 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:17:40.147 ReportCrash: Saved crash report for hasplmd[437] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131740_localhost.crash
27/10/2011 13:17:44.568 Time Out: Idle 18446462239.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:31
27/10/2011 13:17:44.570 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:17:44.570 Time Out: ...resetting micro timer
27/10/2011 13:17:44.572 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:31
27/10/2011 13:17:50.299 com.apple.launchd: (com.aladdin.hasplmd[440]) Job appears to have crashed: Bus error: 10
27/10/2011 13:17:50.299 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:17:50.313 ReportCrash: Saved crash report for hasplmd[440] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131750_localhost.crash
27/10/2011 13:17:53.556 librariand: client connection is invalid: Connection invalid
27/10/2011 13:17:53.557 CaptureCoreServer: connectionDidDie
27/10/2011 13:17:53.558 [0x0-0xd00d].com.phaseone.captureone: 2011-10-27 13:17:53.555 CaptureCoreServer[255:107] connectionDidDie
27/10/2011 13:17:53.559 CaptureCoreServer: Exiting...
27/10/2011 13:17:53.560 [0x0-0xd00d].com.phaseone.captureone: 2011-10-27 13:17:53.557 CaptureCoreServer[255:107] Exiting...
27/10/2011 13:17:53.679 [0x0-0xd00d].com.phaseone.captureone: ImgCoreSocket error: Unknown error: 316
27/10/2011 13:17:53.680 com.apple.launchd.peruser.501: ([0x0-0xd00d].com.phaseone.captureone[189]) Job appears to have crashed: Illegal instruction: 4
27/10/2011 13:17:53.826 [0x0-0xd00d].com.phaseone.captureone: arg 0: 45888 ""
27/10/2011 13:17:53.826 [0x0-0xd00d].com.phaseone.captureone: Initialized
27/10/2011 13:17:53.826 [0x0-0xd00d].com.phaseone.captureone: 2011-10-27 13:07:55> System ready
27/10/2011 13:17:53.826 [0x0-0xd00d].com.phaseone.captureone: 2011-10-27 13:17:53> Connection failed.
27/10/2011 13:17:53.826 [0x0-0xd00d].com.phaseone.captureone: 2011-10-27 13:17:53> Exiting
27/10/2011 13:17:53.826 [0x0-0xd00d].com.phaseone.captureone: 2011-10-27 13:17:53> Shutting down
27/10/2011 13:17:54.928 ReportCrash: Saved crash report for Capture One[189] version Capture One 6.2.2 (6.2.2.50756) to /Users/iaincrawford/Library/Logs/DiagnosticReports/Capture One_2011-10-27-131754_Macintosh-2.crash
27/10/2011 13:17:59.568 Time Out: Idle 18446462254.6 secs; normal due 27/10/2011 13:59, micro due 27/10/2011 13:31
27/10/2011 13:17:59.569 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:17:59.569 Time Out: ...resetting normal timer
27/10/2011 13:17:59.570 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:09
27/10/2011 13:17:59.571 Time Out: ...resetting micro timer
27/10/2011 13:17:59.572 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:31
27/10/2011 13:18:00.472 com.apple.launchd: (com.aladdin.hasplmd[443]) Job appears to have crashed: Bus error: 10
27/10/2011 13:18:00.472 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:18:00.485 ReportCrash: Saved crash report for hasplmd[443] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131800_localhost.crash
27/10/2011 13:18:10.640 com.apple.launchd: (com.aladdin.hasplmd[444]) Job appears to have crashed: Bus error: 10
27/10/2011 13:18:10.640 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:18:10.653 ReportCrash: Saved crash report for hasplmd[444] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131810_localhost.crash
27/10/2011 13:18:14.569 Time Out: Idle 18446462269.6 secs; normal due 27/10/2011 14:09, micro due 27/10/2011 13:31
27/10/2011 13:18:14.571 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:18:14.572 Time Out: ...resetting normal timer
27/10/2011 13:18:14.574 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:10
27/10/2011 13:18:14.574 Time Out: ...resetting micro timer
27/10/2011 13:18:14.576 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:32
27/10/2011 13:18:20.671 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:18:20.818 com.apple.launchd: (com.aladdin.hasplmd[445]) Job appears to have crashed: Bus error: 10
27/10/2011 13:18:20.818 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:18:20.869 ReportCrash: Saved crash report for hasplmd[445] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131820_localhost.crash
27/10/2011 13:18:29.568 Time Out: Idle 18446462284.6 secs; normal due 27/10/2011 14:10, micro due 27/10/2011 13:32
27/10/2011 13:18:29.569 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:18:29.570 Time Out: ...resetting normal timer
27/10/2011 13:18:29.572 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:10
27/10/2011 13:18:29.572 Time Out: ...resetting micro timer
27/10/2011 13:18:29.574 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:32
27/10/2011 13:18:30.985 com.apple.launchd: (com.aladdin.hasplmd[447]) Job appears to have crashed: Bus error: 10
27/10/2011 13:18:30.985 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:18:31.001 ReportCrash: Saved crash report for hasplmd[447] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131831_localhost.crash
27/10/2011 13:18:41.149 com.apple.launchd: (com.aladdin.hasplmd[448]) Job appears to have crashed: Bus error: 10
27/10/2011 13:18:41.149 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:18:41.162 ReportCrash: Saved crash report for hasplmd[448] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131841_localhost.crash
27/10/2011 13:18:44.570 Time Out: Idle 18446462299.6 secs; normal due 27/10/2011 14:10, micro due 27/10/2011 13:32
27/10/2011 13:18:44.572 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:18:44.573 Time Out: ...resetting normal timer
27/10/2011 13:18:44.575 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:10
27/10/2011 13:18:44.576 Time Out: ...resetting micro timer
27/10/2011 13:18:44.577 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:32
27/10/2011 13:18:51.323 com.apple.launchd: (com.aladdin.hasplmd[449]) Job appears to have crashed: Bus error: 10
27/10/2011 13:18:51.323 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:18:51.336 ReportCrash: Saved crash report for hasplmd[449] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131851_localhost.crash
27/10/2011 13:18:59.569 Time Out: Idle 18446462314.6 secs; normal due 27/10/2011 14:10, micro due 27/10/2011 13:32
27/10/2011 13:18:59.570 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:18:59.571 Time Out: ...resetting normal timer
27/10/2011 13:18:59.572 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:10
27/10/2011 13:18:59.572 Time Out: ...resetting micro timer
27/10/2011 13:18:59.574 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:32
27/10/2011 13:19:01.486 com.apple.launchd: (com.aladdin.hasplmd[450]) Job appears to have crashed: Bus error: 10
27/10/2011 13:19:01.486 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:19:01.499 ReportCrash: Saved crash report for hasplmd[450] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131901_localhost.crash
27/10/2011 13:19:11.659 com.apple.launchd: (com.aladdin.hasplmd[451]) Job appears to have crashed: Bus error: 10
27/10/2011 13:19:11.659 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:19:11.672 ReportCrash: Saved crash report for hasplmd[451] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131911_localhost.crash
27/10/2011 13:19:14.570 Time Out: Idle 18446462329.6 secs; normal due 27/10/2011 14:10, micro due 27/10/2011 13:32
27/10/2011 13:19:14.572 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:19:14.573 Time Out: ...resetting normal timer
27/10/2011 13:19:14.575 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:11
27/10/2011 13:19:14.576 Time Out: ...resetting micro timer
27/10/2011 13:19:14.577 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:33
27/10/2011 13:19:21.691 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:19:21.841 com.apple.launchd: (com.aladdin.hasplmd[452]) Job appears to have crashed: Bus error: 10
27/10/2011 13:19:21.841 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:19:21.893 ReportCrash: Saved crash report for hasplmd[452] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131921_localhost.crash
27/10/2011 13:19:29.571 Time Out: Idle 18446462344.6 secs; normal due 27/10/2011 14:11, micro due 27/10/2011 13:33
27/10/2011 13:19:29.573 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:19:29.573 Time Out: ...resetting normal timer
27/10/2011 13:19:29.575 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:11
27/10/2011 13:19:29.576 Time Out: ...resetting micro timer
27/10/2011 13:19:29.578 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:33
27/10/2011 13:19:32.006 com.apple.launchd: (com.aladdin.hasplmd[454]) Job appears to have crashed: Bus error: 10
27/10/2011 13:19:32.006 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:19:32.020 ReportCrash: Saved crash report for hasplmd[454] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131932_localhost.crash
27/10/2011 13:19:42.174 com.apple.launchd: (com.aladdin.hasplmd[455]) Job appears to have crashed: Bus error: 10
27/10/2011 13:19:42.174 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:19:42.187 ReportCrash: Saved crash report for hasplmd[455] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131942_localhost.crash
27/10/2011 13:19:44.569 Time Out: Idle 18446462359.6 secs; normal due 27/10/2011 14:11, micro due 27/10/2011 13:33
27/10/2011 13:19:44.570 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:19:44.570 Time Out: ...resetting normal timer
27/10/2011 13:19:44.572 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:11
27/10/2011 13:19:44.572 Time Out: ...resetting micro timer
27/10/2011 13:19:44.573 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:33
27/10/2011 13:19:52.340 com.apple.launchd: (com.aladdin.hasplmd[456]) Job appears to have crashed: Bus error: 10
27/10/2011 13:19:52.340 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:19:52.353 ReportCrash: Saved crash report for hasplmd[456] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-131952_localhost.crash
27/10/2011 13:19:59.570 Time Out: Idle 18446462374.6 secs; normal due 27/10/2011 14:11, micro due 27/10/2011 13:33
27/10/2011 13:19:59.572 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:19:59.572 Time Out: ...resetting normal timer
27/10/2011 13:19:59.574 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:11
27/10/2011 13:19:59.575 Time Out: ...resetting micro timer
27/10/2011 13:19:59.577 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:33
27/10/2011 13:20:02.503 com.apple.launchd: (com.aladdin.hasplmd[457]) Job appears to have crashed: Bus error: 10
27/10/2011 13:20:02.503 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:20:02.517 ReportCrash: Saved crash report for hasplmd[457] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132002_localhost.crash
27/10/2011 13:20:12.679 com.apple.launchd: (com.aladdin.hasplmd[459]) Job appears to have crashed: Bus error: 10
27/10/2011 13:20:12.679 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:20:12.693 ReportCrash: Saved crash report for hasplmd[459] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132012_localhost.crash
27/10/2011 13:20:13.291 _spotlight: audit warning: allsoft
27/10/2011 13:20:13.291 _spotlight: audit warning: soft /var/audit
27/10/2011 13:20:13.292 _spotlight: audit warning: closefile /var/audit/20111027120715.20111027122013
27/10/2011 13:20:14.571 Time Out: Idle 18446462389.6 secs; normal due 27/10/2011 14:11, micro due 27/10/2011 13:33
27/10/2011 13:20:14.573 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:20:14.574 Time Out: ...resetting normal timer
27/10/2011 13:20:14.576 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:12
27/10/2011 13:20:14.577 Time Out: ...resetting micro timer
27/10/2011 13:20:14.578 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:34
27/10/2011 13:20:22.712 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:20:22.860 com.apple.launchd: (com.aladdin.hasplmd[469]) Job appears to have crashed: Bus error: 10
27/10/2011 13:20:22.860 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:20:22.905 ReportCrash: Saved crash report for hasplmd[469] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132022_localhost.crash
27/10/2011 13:20:29.570 Time Out: Idle 18446462404.6 secs; normal due 27/10/2011 14:12, micro due 27/10/2011 13:34
27/10/2011 13:20:29.572 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:20:29.573 Time Out: ...resetting normal timer
27/10/2011 13:20:29.574 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:12
27/10/2011 13:20:29.575 Time Out: ...resetting micro timer
27/10/2011 13:20:29.577 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:34
27/10/2011 13:20:33.040 com.apple.launchd: (com.aladdin.hasplmd[471]) Job appears to have crashed: Bus error: 10
27/10/2011 13:20:33.040 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:20:33.061 ReportCrash: Saved crash report for hasplmd[471] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132033_localhost.crash
27/10/2011 13:20:43.219 com.apple.launchd: (com.aladdin.hasplmd[472]) Job appears to have crashed: Bus error: 10
27/10/2011 13:20:43.219 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:20:43.232 ReportCrash: Saved crash report for hasplmd[472] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132043_localhost.crash
27/10/2011 13:20:44.571 Time Out: Idle 18446462419.6 secs; normal due 27/10/2011 14:12, micro due 27/10/2011 13:34
27/10/2011 13:20:44.573 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:20:44.574 Time Out: ...resetting normal timer
27/10/2011 13:20:44.576 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:12
27/10/2011 13:20:44.577 Time Out: ...resetting micro timer
27/10/2011 13:20:44.579 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:34
27/10/2011 13:20:53.385 com.apple.launchd: (com.aladdin.hasplmd[476]) Job appears to have crashed: Bus error: 10
27/10/2011 13:20:53.385 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:20:53.398 ReportCrash: Saved crash report for hasplmd[476] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132053_localhost.crash
27/10/2011 13:20:59.572 Time Out: Idle 18446462434.6 secs; normal due 27/10/2011 14:12, micro due 27/10/2011 13:34
27/10/2011 13:20:59.574 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:20:59.575 Time Out: ...resetting normal timer
27/10/2011 13:20:59.577 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:12
27/10/2011 13:20:59.578 Time Out: ...resetting micro timer
27/10/2011 13:20:59.579 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:34
27/10/2011 13:21:03.551 com.apple.launchd: (com.aladdin.hasplmd[477]) Job appears to have crashed: Bus error: 10
27/10/2011 13:21:03.551 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:21:03.564 ReportCrash: Saved crash report for hasplmd[477] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132103_localhost.crash
27/10/2011 13:21:13.725 com.apple.launchd: (com.aladdin.hasplmd[478]) Job appears to have crashed: Bus error: 10
27/10/2011 13:21:13.725 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:21:13.738 ReportCrash: Saved crash report for hasplmd[478] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132113_localhost.crash
27/10/2011 13:21:14.571 Time Out: Idle 18446462449.6 secs; normal due 27/10/2011 14:12, micro due 27/10/2011 13:34
27/10/2011 13:21:14.573 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:21:14.574 Time Out: ...resetting normal timer
27/10/2011 13:21:14.576 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:13
27/10/2011 13:21:14.577 Time Out: ...resetting micro timer
27/10/2011 13:21:14.579 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:35
27/10/2011 13:21:23.757 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:21:23.916 com.apple.launchd: (com.aladdin.hasplmd[479]) Job appears to have crashed: Bus error: 10
27/10/2011 13:21:23.916 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:21:23.966 ReportCrash: Saved crash report for hasplmd[479] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132123_localhost.crash
27/10/2011 13:21:29.572 Time Out: Idle 18446462464.6 secs; normal due 27/10/2011 14:13, micro due 27/10/2011 13:35
27/10/2011 13:21:29.574 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:21:29.574 Time Out: ...resetting normal timer
27/10/2011 13:21:29.576 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:13
27/10/2011 13:21:29.577 Time Out: ...resetting micro timer
27/10/2011 13:21:29.578 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:35
27/10/2011 13:21:34.086 com.apple.launchd: (com.aladdin.hasplmd[482]) Job appears to have crashed: Bus error: 10
27/10/2011 13:21:34.086 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:21:34.099 ReportCrash: Saved crash report for hasplmd[482] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132134_localhost.crash
27/10/2011 13:21:36.048 Safari: Evernote Safari Clipper Plugin version 154267 at your service!
27/10/2011 13:21:36.178 Safari: EVERNOTE: This is where I try to get the Safari toolbar button inserted.
27/10/2011 13:21:36.178 Safari: EVERNOTE: Have we already done our first time insertion: 1
27/10/2011 13:21:36.178 Safari: EVERNOTE: Updating toolbar from prefs.
27/10/2011 13:21:36.178 Safari: EVERNOTE: Found Safari 4 toolbar prefs
27/10/2011 13:21:36.179 Safari: EVERNOTE: Safari toolbar items: (
BackForwardToolbarIdentifier,
DetachedAddBookmarkToolbarIdentifier,
MailPageToolbarIdentifier,
InputFieldsWithoutButtonToolbarIdentifier,
ShowDownloadsToolbarIdentifier
27/10/2011 13:21:36.179 Safari: EVERNOTE: Did not find Elephant in Safari toolbar items.
27/10/2011 13:21:36.179 Safari: EVERNOTE: Our toolbar item list: (
"com.evernote.SafariClipperPlugin.ClipToEvernote",
27/10/2011 13:21:36.179 Safari: EVERNOTE: Found Elephant in our own toolbar items list at index 4
27/10/2011 13:21:36.179 Safari: EVERNOTE: Inserting Elephant at index 4
27/10/2011 13:21:36.240 Safari: EVERNOTE: Finished toolbar customization.
27/10/2011 13:21:44.247 com.apple.launchd: (com.aladdin.hasplmd[483]) Job appears to have crashed: Bus error: 10
27/10/2011 13:21:44.247 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:21:44.260 ReportCrash: Saved crash report for hasplmd[483] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132144_localhost.crash
27/10/2011 13:21:44.572 Time Out: Idle 18446462479.6 secs; normal due 27/10/2011 14:13, micro due 27/10/2011 13:35
27/10/2011 13:21:44.574 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:21:44.575 Time Out: ...resetting normal timer
27/10/2011 13:21:44.577 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:13
27/10/2011 13:21:44.578 Time Out: ...resetting micro timer
27/10/2011 13:21:44.579 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:35
27/10/2011 13:21:54.412 com.apple.launchd: (com.aladdin.hasplmd[484]) Job appears to have crashed: Bus error: 10
27/10/2011 13:21:54.412 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:21:54.425 ReportCrash: Saved crash report for hasplmd[484] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132154_localhost.crash
27/10/2011 13:21:59.572 Time Out: Idle 18446462494.6 secs; normal due 27/10/2011 14:13, micro due 27/10/2011 13:35
27/10/2011 13:21:59.575 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:21:59.575 Time Out: ...resetting normal timer
27/10/2011 13:21:59.578 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:13
27/10/2011 13:21:59.578 Time Out: ...resetting micro timer
27/10/2011 13:21:59.580 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:35
27/10/2011 13:22:04.577 com.apple.launchd: (com.aladdin.hasplmd[485]) Job appears to have crashed: Bus error: 10
27/10/2011 13:22:04.577 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:22:04.589 ReportCrash: Saved crash report for hasplmd[485] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132204_localhost.crash
27/10/2011 13:22:14.573 Time Out: Idle 18446462509.6 secs; normal due 27/10/2011 14:13, micro due 27/10/2011 13:35
27/10/2011 13:22:14.575 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:22:14.575 Time Out: ...resetting normal timer
27/10/2011 13:22:14.577 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:14
27/10/2011 13:22:14.578 Time Out: ...resetting micro timer
27/10/2011 13:22:14.580 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:36
27/10/2011 13:22:14.745 com.apple.launchd: (com.aladdin.hasplmd[486]) Job appears to have crashed: Bus error: 10
27/10/2011 13:22:14.745 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:22:14.758 ReportCrash: Saved crash report for hasplmd[486] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132214_localhost.crash
27/10/2011 13:22:24.778 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:22:24.927 com.apple.launchd: (com.aladdin.hasplmd[487]) Job appears to have crashed: Bus error: 10
27/10/2011 13:22:24.927 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:22:24.976 ReportCrash: Saved crash report for hasplmd[487] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132224_localhost.crash
27/10/2011 13:22:29.572 Time Out: Idle 18446462524.6 secs; normal due 27/10/2011 14:14, micro due 27/10/2011 13:36
27/10/2011 13:22:29.574 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:22:29.575 Time Out: ...resetting normal timer
27/10/2011 13:22:29.577 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:14
27/10/2011 13:22:29.577 Time Out: ...resetting micro timer
27/10/2011 13:22:29.580 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:36
27/10/2011 13:22:35.094 com.apple.launchd: (com.aladdin.hasplmd[489]) Job appears to have crashed: Bus error: 10
27/10/2011 13:22:35.094 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:22:35.107 ReportCrash: Saved crash report for hasplmd[489] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132235_localhost.crash
27/10/2011 13:22:44.571 Time Out: Idle 18446462539.6 secs; normal due 27/10/2011 14:14, micro due 27/10/2011 13:36
27/10/2011 13:22:44.573 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:22:44.574 Time Out: ...resetting normal timer
27/10/2011 13:22:44.575 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:14
27/10/2011 13:22:44.576 Time Out: ...resetting micro timer
27/10/2011 13:22:44.577 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:36
27/10/2011 13:22:45.268 com.apple.launchd: (com.aladdin.hasplmd[491]) Job appears to have crashed: Bus error: 10
27/10/2011 13:22:45.268 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:22:45.283 ReportCrash: Saved crash report for hasplmd[491] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132245_localhost.crash
27/10/2011 13:22:55.435 com.apple.launchd: (com.aladdin.hasplmd[492]) Job appears to have crashed: Bus error: 10
27/10/2011 13:22:55.435 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:22:55.448 ReportCrash: Saved crash report for hasplmd[492] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132255_localhost.crash
27/10/2011 13:22:59.573 Time Out: Idle 18446462554.6 secs; normal due 27/10/2011 14:14, micro due 27/10/2011 13:36
27/10/2011 13:22:59.575 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:22:59.576 Time Out: ...resetting normal timer
27/10/2011 13:22:59.578 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:14
27/10/2011 13:22:59.579 Time Out: ...resetting micro timer
27/10/2011 13:22:59.580 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:36
27/10/2011 13:23:05.602 com.apple.launchd: (com.aladdin.hasplmd[493]) Job appears to have crashed: Bus error: 10
27/10/2011 13:23:05.602 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:23:05.615 ReportCrash: Saved crash report for hasplmd[493] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132305_localhost.crash
27/10/2011 13:23:14.573 Time Out: Idle 18446462569.6 secs; normal due 27/10/2011 14:14, micro due 27/10/2011 13:36
27/10/2011 13:23:14.576 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:23:14.576 Time Out: ...resetting normal timer
27/10/2011 13:23:14.578 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:15
27/10/2011 13:23:14.579 Time Out: ...resetting micro timer
27/10/2011 13:23:14.581 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:37
27/10/2011 13:23:15.771 com.apple.launchd: (com.aladdin.hasplmd[494]) Job appears to have crashed: Bus error: 10
27/10/2011 13:23:15.771 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:23:15.784 ReportCrash: Saved crash report for hasplmd[494] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132315_localhost.crash
27/10/2011 13:23:25.803 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:23:25.950 com.apple.launchd: (com.aladdin.hasplmd[495]) Job appears to have crashed: Bus error: 10
27/10/2011 13:23:25.950 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:23:25.997 ReportCrash: Saved crash report for hasplmd[495] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132325_localhost.crash
27/10/2011 13:23:29.573 Time Out: Idle 18446462584.6 secs; normal due 27/10/2011 14:15, micro due 27/10/2011 13:37
27/10/2011 13:23:29.575 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:23:29.575 Time Out: ...resetting normal timer
27/10/2011 13:23:29.578 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:15
27/10/2011 13:23:29.578 Time Out: ...resetting micro timer
27/10/2011 13:23:29.581 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:37
27/10/2011 13:23:36.124 com.apple.launchd: (com.aladdin.hasplmd[498]) Job appears to have crashed: Bus error: 10
27/10/2011 13:23:36.124 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:23:36.137 ReportCrash: Saved crash report for hasplmd[498] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132336_localhost.crash
27/10/2011 13:23:44.574 Time Out: Idle 18446462599.6 secs; normal due 27/10/2011 14:15, micro due 27/10/2011 13:37
27/10/2011 13:23:44.576 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:23:44.577 Time Out: ...resetting normal timer
27/10/2011 13:23:44.579 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:15
27/10/2011 13:23:44.579 Time Out: ...resetting micro timer
27/10/2011 13:23:44.582 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:37
27/10/2011 13:23:46.290 com.apple.launchd: (com.aladdin.hasplmd[499]) Job appears to have crashed: Bus error: 10
27/10/2011 13:23:46.290 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:23:46.303 ReportCrash: Saved crash report for hasplmd[499] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132346_localhost.crash
27/10/2011 13:23:56.458 com.apple.launchd: (com.aladdin.hasplmd[500]) Job appears to have crashed: Bus error: 10
27/10/2011 13:23:56.458 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:23:56.470 ReportCrash: Saved crash report for hasplmd[500] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132356_localhost.crash
27/10/2011 13:23:59.574 Time Out: Idle 18446462614.6 secs; normal due 27/10/2011 14:15, micro due 27/10/2011 13:37
27/10/2011 13:23:59.576 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:23:59.577 Time Out: ...resetting normal timer
27/10/2011 13:23:59.579 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:15
27/10/2011 13:23:59.580 Time Out: ...resetting micro timer
27/10/2011 13:23:59.581 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:37
27/10/2011 13:24:06.623 com.apple.launchd: (com.aladdin.hasplmd[508]) Job appears to have crashed: Bus error: 10
27/10/2011 13:24:06.623 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:24:06.637 ReportCrash: Saved crash report for hasplmd[508] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132406_localhost.crash
27/10/2011 13:24:14.573 Time Out: Idle 18446462629.6 secs; normal due 27/10/2011 14:15, micro due 27/10/2011 13:37
27/10/2011 13:24:14.575 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:24:14.576 Time Out: ...resetting normal timer
27/10/2011 13:24:14.578 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:16
27/10/2011 13:24:14.579 Time Out: ...resetting micro timer
27/10/2011 13:24:14.581 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:38
27/10/2011 13:24:16.788 com.apple.launchd: (com.aladdin.hasplmd[509]) Job appears to have crashed: Bus error: 10
27/10/2011 13:24:16.788 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:24:16.801 ReportCrash: Saved crash report for hasplmd[509] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132416_localhost.crash
27/10/2011 13:24:26.816 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:24:26.966 com.apple.launchd: (com.aladdin.hasplmd[510]) Job appears to have crashed: Bus error: 10
27/10/2011 13:24:26.966 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:24:27.022 ReportCrash: Saved crash report for hasplmd[510] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132427_localhost.crash
27/10/2011 13:24:29.574 Time Out: Idle 18446462644.6 secs; normal due 27/10/2011 14:16, micro due 27/10/2011 13:38
27/10/2011 13:24:29.576 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:24:29.577 Time Out: ...resetting normal timer
27/10/2011 13:24:29.579 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:16
27/10/2011 13:24:29.580 Time Out: ...resetting micro timer
27/10/2011 13:24:29.581 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:38
27/10/2011 13:24:37.133 com.apple.launchd: (com.aladdin.hasplmd[512]) Job appears to have crashed: Bus error: 10
27/10/2011 13:24:37.133 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:24:37.146 ReportCrash: Saved crash report for hasplmd[512] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132437_localhost.crash
27/10/2011 13:24:44.573 Time Out: Idle 18446462659.6 secs; normal due 27/10/2011 14:16, micro due 27/10/2011 13:38
27/10/2011 13:24:44.575 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:24:44.576 Time Out: ...resetting normal timer
27/10/2011 13:24:44.578 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:16
27/10/2011 13:24:44.579 Time Out: ...resetting micro timer
27/10/2011 13:24:44.581 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:38
27/10/2011 13:24:47.297 com.apple.launchd: (com.aladdin.hasplmd[513]) Job appears to have crashed: Bus error: 10
27/10/2011 13:24:47.298 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:24:47.310 ReportCrash: Saved crash report for hasplmd[513] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132447_localhost.crash
27/10/2011 13:24:57.462 com.apple.launchd: (com.aladdin.hasplmd[514]) Job appears to have crashed: Bus error: 10
27/10/2011 13:24:57.462 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:24:57.475 ReportCrash: Saved crash report for hasplmd[514] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132457_localhost.crash
27/10/2011 13:24:59.575 Time Out: Idle 18446462674.6 secs; normal due 27/10/2011 14:16, micro due 27/10/2011 13:38
27/10/2011 13:24:59.577 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:24:59.578 Time Out: ...resetting normal timer
27/10/2011 13:24:59.580 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:16
27/10/2011 13:24:59.581 Time Out: ...resetting micro timer
27/10/2011 13:24:59.583 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:38
27/10/2011 13:25:07.629 com.apple.launchd: (com.aladdin.hasplmd[515]) Job appears to have crashed: Bus error: 10
27/10/2011 13:25:07.629 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:25:07.642 ReportCrash: Saved crash report for hasplmd[515] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132507_localhost.crash
27/10/2011 13:25:14.574 Time Out: Idle 18446462689.6 secs; normal due 27/10/2011 14:16, micro due 27/10/2011 13:38
27/10/2011 13:25:14.577 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:25:14.577 Time Out: ...resetting normal timer
27/10/2011 13:25:14.579 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:17
27/10/2011 13:25:14.580 Time Out: ...resetting micro timer
27/10/2011 13:25:14.582 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:39
27/10/2011 13:25:17.795 com.apple.launchd: (com.aladdin.hasplmd[516]) Job appears to have crashed: Bus error: 10
27/10/2011 13:25:17.795 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:25:17.813 ReportCrash: Saved crash report for hasplmd[516] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132517_localhost.crash
27/10/2011 13:25:27.826 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:25:27.986 com.apple.launchd: (com.aladdin.hasplmd[518]) Job appears to have crashed: Bus error: 10
27/10/2011 13:25:27.986 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:25:28.036 ReportCrash: Saved crash report for hasplmd[518] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132528_localhost.crash
27/10/2011 13:25:29.575 Time Out: Idle 18446462704.6 secs; normal due 27/10/2011 14:17, micro due 27/10/2011 13:39
27/10/2011 13:25:29.577 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:25:29.578 Time Out: ...resetting normal timer
27/10/2011 13:25:29.580 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:17
27/10/2011 13:25:29.581 Time Out: ...resetting micro timer
27/10/2011 13:25:29.583 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:39
27/10/2011 13:25:34.576 login: USER_PROCESS: 524 ttys000
27/10/2011 13:25:38.150 com.apple.launchd: (com.aladdin.hasplmd[528]) Job appears to have crashed: Bus error: 10
27/10/2011 13:25:38.150 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:25:38.168 ReportCrash: Saved crash report for hasplmd[528] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132538_localhost.crash
27/10/2011 13:25:44.573 Time Out: Idle 18446462719.6 secs; normal due 27/10/2011 14:17, micro due 27/10/2011 13:39
27/10/2011 13:25:44.575 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:25:44.575 Time Out: ...resetting normal timer
27/10/2011 13:25:44.577 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:17
27/10/2011 13:25:44.577 Time Out: ...resetting micro timer
27/10/2011 13:25:44.579 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:39
27/10/2011 13:25:48.320 com.apple.launchd: (com.aladdin.hasplmd[531]) Job appears to have crashed: Bus error: 10
27/10/2011 13:25:48.320 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:25:48.333 ReportCrash: Saved crash report for hasplmd[531] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132548_localhost.crash
27/10/2011 13:25:58.481 com.apple.launchd: (com.aladdin.hasplmd[536]) Job appears to have crashed: Bus error: 10
27/10/2011 13:25:58.481 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:25:58.494 ReportCrash: Saved crash report for hasplmd[536] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132558_localhost.crash
27/10/2011 13:25:59.573 Time Out: Idle 18446462734.6 secs; normal due 27/10/2011 14:17, micro due 27/10/2011 13:39
27/10/2011 13:25:59.574 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:25:59.575 Time Out: ...resetting normal timer
27/10/2011 13:25:59.576 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:17
27/10/2011 13:25:59.576 Time Out: ...resetting micro timer
27/10/2011 13:25:59.578 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:39
27/10/2011 13:26:08.648 com.apple.launchd: (com.aladdin.hasplmd[537]) Job appears to have crashed: Bus error: 10
27/10/2011 13:26:08.648 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:26:08.661 ReportCrash: Saved crash report for hasplmd[537] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132608_localhost.crash
27/10/2011 13:26:14.575 Time Out: Idle 18446462749.6 secs; normal due 27/10/2011 14:17, micro due 27/10/2011 13:39
27/10/2011 13:26:14.577 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:26:14.578 Time Out: ...resetting normal timer
27/10/2011 13:26:14.580 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:18
27/10/2011 13:26:14.581 Time Out: ...resetting micro timer
27/10/2011 13:26:14.583 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:40
27/10/2011 13:26:18.815 com.apple.launchd: (com.aladdin.hasplmd[541]) Job appears to have crashed: Bus error: 10
27/10/2011 13:26:18.815 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:26:18.831 ReportCrash: Saved crash report for hasplmd[541] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132618_localhost.crash
27/10/2011 13:26:28.846 ReportCrash: DebugSymbols was unable to start a spotlight query: spotlight is not responding or disabled.
27/10/2011 13:26:28.994 com.apple.launchd: (com.aladdin.hasplmd[545]) Job appears to have crashed: Bus error: 10
27/10/2011 13:26:28.994 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:26:29.041 ReportCrash: Saved crash report for hasplmd[545] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132629_localhost.crash
27/10/2011 13:26:29.576 Time Out: Idle 18446462764.6 secs; normal due 27/10/2011 14:18, micro due 27/10/2011 13:40
27/10/2011 13:26:29.578 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:26:29.579 Time Out: ...resetting normal timer
27/10/2011 13:26:29.580 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:18
27/10/2011 13:26:29.581 Time Out: ...resetting micro timer
27/10/2011 13:26:29.582 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:40
27/10/2011 13:26:39.163 com.apple.launchd: (com.aladdin.hasplmd[547]) Job appears to have crashed: Bus error: 10
27/10/2011 13:26:39.163 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:26:39.177 ReportCrash: Saved crash report for hasplmd[547] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132639_localhost.crash
27/10/2011 13:26:44.575 Time Out: Idle 18446462779.6 secs; normal due 27/10/2011 14:18, micro due 27/10/2011 13:40
27/10/2011 13:26:44.577 Time Out: ...now officially idle, since 27/10/2011 13:07
27/10/2011 13:26:44.578 Time Out: ...resetting normal timer
27/10/2011 13:26:44.580 Time Out: Rescheduled normal break for 3120 seconds; next due at 27/10/2011 14:18
27/10/2011 13:26:44.581 Time Out: ...resetting micro timer
27/10/2011 13:26:44.583 Time Out: Rescheduled micro break for 840 seconds; next due at 27/10/2011 13:40
27/10/2011 13:26:49.340 com.apple.launchd: (com.aladdin.hasplmd[548]) Job appears to have crashed: Bus error: 10
27/10/2011 13:26:49.340 com.apple.launchd: (com.aladdin.hasplmd) Throttling respawn: Will start in 10 seconds
27/10/2011 13:26:49.357 ReportCrash: Saved crash report for hasplmd[548] version ??? (???) to /Library/Logs/DiagnosticReports/hasplmd_2011-10-27-132649_localhost.crash
Re: Is Timeout compatible with Lion 10.7.1?
Thanks for the log, iain.
It indicates that Time Out thinks your computer has been idle for a very long time... an impossibly long time, really: the las one says 18446462779.6 seconds, which is about 574 years if my calculations are correct! So it looks like the idle time detection isn't working.
So since Time Out thinks it is always idle, it keeps resetting the break timers, and thus you never get breaks. I'm not sure why the idle time is wrong, though.
Question: do you have the screensaver enabled, or set to "Never"? Or are you using some third-party tool that prevents idleness (e.g. Caffeine)? It's possible one of those is interfering.
Okay, everyone from this thread, please try this version: Time Out 1.6.3b1. If it gets a crazy-large idle time, it tries to get it another way.
Please let me know whether or not breaks start working, and post more log entries for confirmation.
I received the email with the link to 1.6.3b1, thank you! But I just wished to follow up, my original issue was that 1.6.1 was not working in Lion 10.7.1. When I moved to 1.6.2, it did start working correctly. I haven't applied the beta of 1.6.3, I figured since it's working I'll wait for the full release.
Also, in case this helps anyone, 1.6.2 was working in OS 10.7.1, and since updating to OS 10.7.2, continues to work fine. I'm sorry that I can't really provide a reason WHY it starting working but there it is!
Thanks for the update. I'll probably release 1.6.3 today.
