This is the error I get after setting up a service and filter to check whois expiry for a test domain:
osascript[14546:707] Cannot find executable for CFBundle
I am looking to import a list of domains to check whois expiry, and set an ical reminder X days before actual expiration to renew at defined registry associated with that domain.
Re: Whois Monitoring for near expiring domains + ICAL ...
The osascript tool is used to run AppleScripts, so that error likely means there is a bug in your script — perhaps trying to "tell" the wrong app, or something. If you paste your script in here (or email it to me), I or someone else may be able to diagnose further.
Issue resolved via email: was using the wrong script type.
