Re: Reporting context and capturing images
Hi James,
Context: that's a tricky one. It's probably possible, e.g. via a custom filter script, but I'm not sure how. Anyone else have any ideas?
Webcam: that may depend on how the webcam works. Is it possible to capture an image via a script? If so, you could use a custom service script to do that. If the webcam image is on-screen (e.g. you leave an auto-refreshing web page for it frontmost), you could use the existing Screenshot service.
Hi David,
I'm not sure how you have things coded, but would it be possible to implement context as an additional filter that expands the selection by letting the user specify custom text or markup to designate the boundaries (e.g., and )?
Thanks for the suggestions about image capture, I'll play with scripts and see what I can do.
The code didn't work on that last post, but it should have showed HTML boundaries p and slash p.
Yes, a new custom filter could do it... though I'd have to add extra variables to output the range of the difference, since it could occur multiple times in the original text. But that'd be a useful addition too.
I'll add this to the feature ideas list. Thanks for the suggestion!
Good news: version 3.7 (in beta soon) has a new Context filter, to output more context around the output of a previous filter. You can choose a number of characters or a delimiter (or both) to extend the context before and after the text.
There are a number of new filter variables to support this, which may be useful for other filters or notifiers too.
