I have a strange problem in that the time shown in the monitor window under "Check Date" has always been wrong (5 hour fast - minutes are correct). My system clock is set correctly. I've looked but can't find anywhere to change it. What can I do?
thanks
Re: Date/Time problem in monitor
Simon 3.2 has this fix, which probably explains what you're experiencing:
Could be a good time to upgrade to the latest version!
If you can't upgrade yet, you could use relative times instead of absolute dates -- see the View Options.
