Monitor changes in FTP directories
OK I'm new with Simon (using the demo 3.4)
What I'm trying to do is to monitor any changes in a FTP directory (public_html) and if anything changes then alter me via email or twitter.
Can't make it work, is there a limit in the demo version?
Any help would be great thanks
Re: Monitor changes in FTP directories
Welcome!
You can use the FTP Directory Listing service to monitor a FTP directory.
Then use a filter to detect changes (the default Changes one would do, or you could use a different one to ignore uninteresting changes).
Then use the Email notifier to get emails.
Currently the Twitter notifier doesn't work, due to changes by Twitter. We're working on a fix.
The trial period doesn't impose any functionality limits.
Hi David,
Thanks for quick reply.
It's the filters that confuses me. do you mean to set the first dropdown (with none,any,success,unchanged,changed&failure) to changed?
and then the next one to "change" aswell? or am I missing something?
I need to know any change in the ftp directory, an rename of a file, or an uploaded file etc.
The first popup menu indicates the condition for running the filter. So I'd recommend setting it to Success — which means to use the filter for any successful status. If you set it to Changed, it'd only run the filter if a previous filter resulted in a change (which will never be true for the first filter, but is useful for combining multiple filters).
thanks works perfect! now off to learn to read the difference output hehe =)
thanks again this will be a buy
Happy to help.
