I'm not sure why my previous post was removed (and thus unanswered, although it was in moderation because of two links), but I'll post it again in a much shortened version:
I'm moving Simon from a 10.5.8 machine to a 10.8.2 machine. How do I move my tests from one machine to the other?
Re: How to move tests between machines?
I'm sorry for the moderation issue — I'm fighting a flood of spam at present, so pretty much everything is moderated, and I have to disable my spam filter to approve posts. It's quite a battle.
Hopefully you found the answer to this in the Simon FAQ:
I did end up finding that, thanks! I've upgraded to 3.x Platinum in the move, as well.
By the way, you might check out Mollom for spam control. I've found it effective for several Drupal installations.
Thanks for the recommendation; I'll check it out.
