Re: settings basic website monitoring
Hi Kris,
Take a look at the tests that come with Simon for examples.
To monitor a website, you'd use the "Web (HTTP)" service.
Which filter you use depends on the site and what you want to check. The "Change" filter will detect any change on the page. Often you want to only look at a portion of the page, though, to avoid dynamic content like banners etc. So you would probably use a "Block" filter for that, to look at the HTML between two blocks of text. As the name implies, the "Block Without Changes" filter is the same as the "Block" one without detecting changes; it is useful if you want to narrow down the HTML for another filter.
You'd normally choose the "Response Text" as the filter input; that is the text output by the service; in this case, the HTML page source.
Let me know if you have any further questions. I'm happy to help.
Hi David,
Thanks for the explanation. While the relationships are still not clear (for example, why are there filter options for a FTP or "Is app running" test? Do they apply here?, etc), I was apply to follow your response and set up a simple HTTP monitor.
I'm thinking what might be helpful are blog posts which step through examples. Say once a month, throw up a blog post about an example test scenario. Walk through the settings and explain why you set it up like you did. That may be just as/more helpful than the typical help documentation. Just an idea.
Thanks again and happy holidays!
Filters are very flexible; you can look at the output from any service, and detect changes, failures, or even do other things or use custom logic.
Tutorial blog posts are a good idea. I'd welcome suggestions of scenarios to cover.
