Possible to set volume level on sounds?
Just wondering if there is any way to set the volume level specifically for Time Out? I often have the volume on my computer up quite high and would prefer not to be deafened by my Time Out sound when it occurs!
Re: Possible to set volume level on sounds?
Never mind. I had the app store version installed and just discovered that the non-app store version actually does have a volume control.
Glad you found that. I wasn't able to update the App Store edition (Time Out Free) as the current app can't be sandboxed for the App Store. Time Out 2 will be available both directly and via the App Store.
