Re: Importing and Exporting tests?
There aren't import and export commands (yet), though that's something I occasionally think about adding (hasn't been much demand for it).
Another feature I'm thinking about (and has been a more popular request) is groups, so related tests can be grouped in a folder or similar, and thus hidden by a disclosure triangle or something.
Yet another option is to move the data to a document model, so you can have multiple documents, each containing a set of tests, and open the ones you want. I'm not sure that's appropriate for Simon, though sounds like exactly what you want. I've been experimenting with a document approach in one of my other apps.
Until one of those is done, your best bet would be to manually manage the data. The Simon data is stored in the path "~/Library/Application Support/Dejal/Simon", where "~" means your home folder. So you could quit Simon, rename that folder to something else, and re-launch Simon to create a new set of data with other tests (or duplicate the folder and delete some from each). Then quit Simon, swap folders around, and re-launch when you want to check a different set of tests.
Personally, I'd prefer to just leave all the tests running all the time (or auto-pause some if you don't want them checking). But if you want to keep the number of tests down, that'd be an option.
