Re: Growl Notifier Not Registering
Now that Simon requires an Intel Mac, I can probably update the framework to the newer version.
I'll make a note of that for the next update.
The Growl notifier is working for me, so if you are able to manually register it somehow, it should work.
I suspect you had your copy of Simon registered with Growl before that feature was broken. Have you attempted to remove Simon from Growl and see if it gets registered again?
I could register Simon manually, but I need to know the notification types to register -- the specific names you use when you create the notifications.
I haven't tried, no... but will do so when I investigate this.
The Simon notification for Growl is called simply "Simon Notification".
This AppleScript will register Simon with Growl:
tell application id "com.Growl.GrowlHelperApp"
set theAppName to "Simon"
set the allNotificationsList to ¬
{"Simon Notification"}
set the enabledNotificationsList to ¬
register as application theAppName ¬
all notifications allNotificationsList ¬
default notifications enabledNotificationsList ¬
icon of application "Simon"
end tell
Once registered, the Growl notifier works.
