Report Kind -> Save Locally -> Where -> Other == Spinning Wheel / Not Responding
Whenever I choose Other from the drop-down list it goes into a permanent spinning wheel. Activity monitor show Simon as Not Responding. I have waited as long as 10 minutes and still no response. This is making it impossible for me to set up the reports in the location that I want them.
Re: Report Kind -> Save Locally -> Where -> Other == ...
Ah, that is a bug. I've just fixed it for the next release.
Thanks for reporting this issue!
Excellent, thank you. I will wait for the next update and then try again.
No need to wait; here's a pre-release build with the fix. It also includes some report tweaks to better support using Panic's Status Board (more on that later).
Download Simon 3.6a3 now!
You're welcome to continue using this alpha build, or you can switch back to the general release after setting your report destination.
