no work
Hi Dave
after few mac restarts it doesnt break, begin breaks options appears disabled
cmd+r doesnt help, idle is unchecked,
pls advice
AttachmentSize
экрана 2014-04-20 в 11.59.40.png21.68 KB
экрана 2014-04-20 в 12.00.08.png90.95 KB
экрана 2014-04-20 в 12.00.18.png89.65 KB
Re: no work
Try downloading the app again, in case it is damaged.
You could try quitting then removing the preferences too, to see if that helps.
If those don't help, turn on scheduler logging. Enter the following command in Terminal (in /Applications/Utilities):
defaults write com.dejal.timeout DebugScheduler YES
Then you can see the logging in Console (also in the Utilities folder). If that doesn't make sense to you, paste in the log entries after manually starting a break for me to analyze.
