Re: Editing notifiers does not work
I'll investigate. I don't have a 10.6.x system, so hopefully I'll be able to reproduce the issue on a later OS version. If not, you might have to stick with Simon 3.6.1 until you're ready to upgrade your OS. (No real need to to update to 3.6.3 for existing customers anyway.)
Actually, the issue occurred on Yosemite too. Now fixed. (It was related to adding recognition of version 4 groups; I added it for tests, but not services, filters, etc.)
I haven't checked very thoroughly, but version 3.6.4 indeed seems to fix the reported problem. Thx for prompt action!
