Test a Notifier
Is there a way to 'test' a notifier in the edit notifier section?
In other words, send a test email or text message without a real incident triggering it?
Rob
Re: Test a Notifier
Hi Rob,
Yes, simply select the notifier and click the reload toolbar button, or choose File ▶ Notify Now.
(You can do the same for reports, to manually publish them.)
