Importing Tests and Upgrading to 4.0.3
Hi folks, just upgraded from Simon 3 to 4.0.x. How can I import my old tests? Simon 4 can't seem to find them.
Steve K.
Re: Importing Tests and Upgrading to 4.0.3
Hi Steve,
The tests should carry over, unless you were on Simon Free before?
The Simon data should be located in the path "~/Library/Application Support/Dejal/Simon", where "~" means your home folder. If you were on Simon Express, the data will be automatically moved. If you were on Simon Free, you can move the data yourself.
