Preferences keep opening automatically
I have Time Out in my list of applications to open automatically when I start up my Mac. It used to do this seamlessly in the background and just start counting down to the next break with 1.X. Now with 2.0 and 2.1 it always opens the preferences dialog box, and also seems to keep doing it at other times, like after waking from sleep. Not a huge deal, but kind of annoying. Can't find anywhere in the preferences to change that behavior. Am I missing something?
Lee Carlson
Re: Preferences keep opening automatically
Hi Lee,
I have the window appear on launch, as manually launching it and not having the window appear would be confusing.
There is a solution, though: if you hide the Dock icon, no window will appear. (This is a supporter reward.)
