Re: Failures that won't recover
What is the exact error in the Failures page of the Monitor window?
Do you have Smart Change Detection switched on, with text specified for the Start or End blocks? If it can't find that text, it'd give an error saying so (which is a useful technique to ensure that the page includes essential output).
Perhaps attach screenshots of the page errors, if that helps clarify.
