Re: MySQL no parameters after upgrade to v3.0
I'm not sure I understand what you're asking for. The help you quote indicates where those settings are: in the Edit Service window. Those are the default values. The Edit Test window has corresponding fields for each test.
It's possible that the MySQL plugin might have been damaged in version 3.0; lots of things changed in that major upgrade, and the plugins were all rebuilt, though the MySQL one wasn't otherwise altered.
Have a look in the Console log; it might provide some helpful clues.
Ah... I see that although the MySQL plugin is present in the application, it is not being loaded for some reason. I will investigate and fix for 3.0.1. Sorry for the inconvenience!
Not to be a pain or anything 8), but any estimate as to when the MySQL service will be fixed? I use it for 5 of my tests.
I have some major time constraints, but I'm hoping to be able to release 3.0.1 around the end of the month.
I have fixed the MySQL plugin issue. Just waiting on some tweaks to the Twitter plugin, then I'll release 3.0.1. Hopefully within a week.
Thanks David, that's all working great now. 8)
