Break reminder tool with micro-breaks
Time Out does not properly detect inactivity
Time Out never resets the timer when I become inactive. I was away for an hour and came back and then I got a 10 minute break.
Re: Time Out does not properly detect inactivity
Time Out 2, which should finally have a beta release in a few months, will have a totally new scheduler. But in the meantime, if you think Time Out isn't resetting when it should, you can enable some extra logging that records the idle state.
Enter the following command in Terminal:
defaults write com.dejal.timeout DebugScheduler YES
Then you can see the logging in Console.
Let me know if you need more assistance with this, or if the logging shows an issue (or you want help interpreting it).
